    Possibly fried duet with an in spec power supply
    2.3k
    • Luckypriestundefined
      Luckypriest
      3rd picture
      • fcwiltundefined
        fcwilt
        What is that yellow wire connected to?
          A Former User
          (Yellow seems to be PE from the PSU to the groung pin on the C14 inlet on his panel)
          Its near impossible to see any details on the picture, so please try to get a better focused picture with even lighting. Is it a rev 1.02 board?
            Luckypriest
            Sorry my current phone camera is utter and complete garbage at focusing. it is a revision 1.02, I wasnt able to get a clear picture of the lettering though.
              Luckypriest
              Sorry as I said I really am trying to be helpful, I've looked over the whole board with a magnifying glass, don't see any components that look discolored. Re-verified the output from the power supply and its still slightly over 12.
                Hi please try to get a better close up of the board itself.
                  Luckypriest
                  @Phaedrux Please see attached photos, stole wife's phone. Any troubleshooting you would like me to do? I know theres no way in heck I qualify for warranty but this is killing me since I was so careful. I wish I had test hooked it up back then.
                  110946870_2982828091826199_5013588580827785555_n.jpg 113313376_287103806065608_8190242207007458521_n.jpg 115889547_337422690984703_5168083175848808659_n.jpg
                    A Former User
                    Thats better, but still can't make out much besides the obvious burned sticker on the cpu.
                    Could just be lighting but with nothing else sticking out maybe this is slightly off coloured?
                    and was usb still connected when you turned on the 12v?
                      Luckypriest
                      USB wasnt connected when it came on, but was shortly after. Could that cause something similar? Not sure I've heard of that being an issue before. Looked at that pin and it looks fine, and the USB is currently working.
                        A Former User @Luckypriest
                        @Luckypriest said in Possibly fried duet with an in spec power supply:
                        maybe, ref https://duet3d.dozuki.com/Wiki/USB_ground_loops but still a little odd set of symptoms.
                        Luckypriestundefined 1 Reply Last reply Reply Quote 0
                          Luckypriest
                          Found a similar case to mine and walked through the erasing / rewriting the firmware steps which succeeded, followed by:
                            Luckypriest @A Former User
                            @bearer said in Possibly fried duet with an in spec power supply:
                            Fascinating read actually, did not know that. Don't think it applies here as it was a laptop anyway.
                              followed by:
                              you also put an up to date DuetWiFiServer.bin on the SD card (in /sys) and ran M997 S1 to update the wifi firmware?
                                Luckypriest
                                Dont believe I did, the guide I glanced at didnt have that step. Is the server you linked the newest one?
                                  @Luckypriest yes, its v1.23 which is the newest one (its not been changed since 2.05(?) so the one in the 3.0 release is fine to use)
                                    Luckypriest
                                    It cycled through all the baud rates with me connected and then says installation failed due to comm write error. Was there anything else I needed to do with this?
                                      don't think so, you could review https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Updating_WiFi_firmware to see if I spaced out on something though.
                                      but tbh i didn't expect it to work, somehting have had to give when the sticker almost caught fire.
                                        Luckypriest
                                        Interestingly enough, however, after running that the wifi module is disabled, trying to add my SSID gives the message failed to add SSID to remembered list. After that the wireless module is back to always stating that it is being started.
                                          @Luckypriest you could restart the board, enable wifi debug with M111 P14 S1 and repeat the upgrade and connection attempt but #longshot
                                            Luckypriest
                                            Also when USB is plugged in both the lights for 3.3v and 5v are on.
