    Possibly fried duet with an in spec power supply
    2.3k
      A Former User
      Thats better, but still can't make out much besides the obvious burned sticker on the cpu.
      Could just be lighting but with nothing else sticking out maybe this is slightly off coloured?
      and was usb still connected when you turned on the 12v?
      • Luckypriestundefined
        Luckypriest
        USB wasnt connected when it came on, but was shortly after. Could that cause something similar? Not sure I've heard of that being an issue before. Looked at that pin and it looks fine, and the USB is currently working.
          A Former User @Luckypriest
          @Luckypriest said in Possibly fried duet with an in spec power supply:
          maybe, ref https://duet3d.dozuki.com/Wiki/USB_ground_loops but still a little odd set of symptoms.
          Luckypriestundefined 1 Reply Last reply Reply Quote 0
            Luckypriest
            Found a similar case to mine and walked through the erasing / rewriting the firmware steps which succeeded, followed by:
              Luckypriest @A Former User
              @bearer said in Possibly fried duet with an in spec power supply:
              Fascinating read actually, did not know that. Don't think it applies here as it was a laptop anyway.
                followed by:
                you also put an up to date DuetWiFiServer.bin on the SD card (in /sys) and ran M997 S1 to update the wifi firmware?
                  Luckypriest
                  Dont believe I did, the guide I glanced at didnt have that step. Is the server you linked the newest one?
                    @Luckypriest yes, its v1.23 which is the newest one (its not been changed since 2.05(?) so the one in the 3.0 release is fine to use)
                      Luckypriest
                      It cycled through all the baud rates with me connected and then says installation failed due to comm write error. Was there anything else I needed to do with this?
                        don't think so, you could review https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Updating_WiFi_firmware to see if I spaced out on something though.
                        but tbh i didn't expect it to work, somehting have had to give when the sticker almost caught fire.
                          Luckypriest
                          Interestingly enough, however, after running that the wifi module is disabled, trying to add my SSID gives the message failed to add SSID to remembered list. After that the wireless module is back to always stating that it is being started.
                            @Luckypriest you could restart the board, enable wifi debug with M111 P14 S1 and repeat the upgrade and connection attempt but #longshot
                              Luckypriest
                              Also when USB is plugged in both the lights for 3.3v and 5v are on.
                                thats normal. it gets 5v from usb and 3.3v is derived from the 5v supply
                                  Luckypriest
                                  Right but other shorted issues always reference one of those being out, so I just wanted to clarify. When you say try reinstalling after turning on debugging(which succeeded btw), do you mean M997 S1?
                                    Luckypriest
                                    If that is the case the output was identical, not sure what debugging added to the mix.
                                      Luckypriest
                                      Infrared thermometer reads ~38c on the cpu chip with just USB power.
                                      I'm willing to take the blame, but I really dont see what I did. Is it possible I got a lemon?
                                        if nothing then we know the uart from the cpu or the wifi module is damaged as the update should at the very least print the bootloader from the wifi module afaik.
                                        afaik the boards are automatically tested during production, so while possible, its unlikely - but this is where I take a step to the side and let the Duet people deal with it.
                                        while you wait you might want to look into if you have any consumer protection rights that goes beyond 6 month warranty if the board was purchased september '19
                                          droftarts administrators @Luckypriest
                                          @Luckypriest Sorry you Duet board has failed. With a burn mark like that on the processor, I'm pretty sure that it's not going to be recoverable, and only a processor swap is going to get it fully working again. Duet3D don't really do repairs such as this, but there are some in the community who may: https://forum.duet3d.com/topic/13875/community-repairs
                                          As to what caused the problem, I'm not sure. If nothing else was plugged in but USB and 12V, and it wasn't a USB ground loop, I'd look for solder bridges or shorts on the board, looking at both sides. Are you sure there was nothing under the board that could have shorted against the pins? Post a good, well-lit, high resolution picture of both sides of the board. It's better to take picture from further away, and zoom in on the board, rather than take a picture too close and have some parts out of focus, even if this is slightly lower resolution.
                                          Unfortunately, if you bought the board in September 2017, it's well outside the warranty period, and even 2-year consumer protection (if that even applies). It is the older version of the board (v1.02) without fuse protection, too.
                                          However, if you contact sales@duet3d.com, we have a small stock of refurbished Duets that may reduce the cost of replacement.
                                            Luckypriest
                                            @droftarts
                                            it was sitting on my 100% polycarbonate(?) plastic of some sort build plate that I was waiting to try, thats why I'm so dumbfounded. I didnt see anything like bad solder joints on the underside myself, let me get some better pictures.
                                            https://imgur.com/a/wOF7ReN
                                            @bearer Thanks for all your help, seriously.
