    Simplify3D over Cura
    3D Printing General Chat
    8
    16
    769
    • Corexyundefined
      Corexy
      So Idea Maker is better than Cura?
      • Jacotheronundefined
        Jacotheron
        I have recently migrated from S3D to PrusaSlicer (Cura clone), for basically the same reasons as @arhi said. S3D was good, but have been surpassed by most, if not all, of the free slicers available. Next version of PrusaSlicer will have a bunch of new features, making it even better (ironing the top layer, painting supports and many others).
        One area where S3D is better than PrusaSlicer, is the speed at which it slices. That said, a bunch of the features I use, are labeled as making slicing slower due to increased calculations (and is not available in S3D).
        At this time, I am recommending moving away from from S3D.
        • Kolbiundefined
          Kolbi
          I can not really judge if anything is better than Cura because I never used it on a consistent basis - I tried, but never liked it really.
          For my use - based on comfort, dependability, and familiarity, I'd rank as:
          1st - ideaMaker
          2nd - S3D
          Close 2nd - Prusa-slicer
          Only complaints, and very minor at that, I'd give ideaMaker is the odd exporting of configuration files, can't get rid of their machine's configurations, and it won't send the gcode directly to the duet.
          • arhiundefined
            arhi @nbGU
            @nbGU said in Simplify3D over Cura:
            Also thanks for the heads up on the label printers, its a minefield trying to choose one 🙂
            I purchased that one and I'm not happy with it. 2x changed (inside first 6 months, free as I have 2y waranty on it), and it don't laminate the tape properly, they come apart quickly 😞 ... the similar one with exactly the same tape does much better job ... that's rather old model but I seen it still being sold online on different "action" prices..
            Dunno what you are going to label but for e.g. I'm biting my leg for not adding a bit more cache to get one that can also print on heat-shrink tubes. For labeling cables heatshrink tubes are waaaaaaaaaaay better solution than tape
            • arhiundefined
              arhi @Corexy
              @Corexy said in Simplify3D over Cura:
              IMHO way better, but at the end of the day, it's a matter of taste. Cura's open design allows for a ton of plugins and I can't say I tried making a plugin for Cura nor that I tested many of the available ones. Idea Maker is on the other hand CLOSED source, proprietary software, so it is free, but is not open. IMHO as is it is much better than Cura but I would not put money on that statement as I don't know Cura that good, I never liked it; something about Cura never worked for me. Only thing I'd say that I can 100% back is that everyone should TRY Idea Maker and decide for themselves!! Or even better, I think I mentioned already, everyone that is in 3D printing for more then a side hobby should, every 6-12 months, go trough all of the free ones and try them out.
              • arhiundefined
                arhi @Jacotheron
                @Jacotheron said in Simplify3D over Cura:
                you mean Slic3r clone 😄
                😄 Try IdeaMaker 😄 it's as fast as S3D or faster, you can configure how many cores you want it using while slicing 🙂 Of course, if you select cpu heavy options like adaptive infill it will be slow but S3D don't have those fancy options so can't really compare 😄
                • arhiundefined
                  arhi @Kolbi
                  @Kolbi said in Simplify3D over Cura:
                  rather big complaint is that it does not talk to octoprint nor rrf, second rather big complaint from me is that it cannot set origin to be at the center of the table. You can configure template to have offset so when you put object on center of the table it will print on center of the table but preview will still show it in the left bottom corner. I could not even get IM to exec external script to upload file using CURL (what I made S3D do to upload files to octoprint and rrf).
                  wrt configuration, I'm not sure what you mean, you can export all three things separately?
                  Kolbiundefined 1 Reply Last reply Reply Quote 0
                  • Kolbiundefined
                    Kolbi @arhi
                    @arhi Sure, I do export and backup all my stuff once it's solidified as a solid setup, but it is not the most intuitive gui for such and always feels odd to me - that's all 😉
                      Personally I wouldn't recommend anyone bother with paying for S3D at this point. If you're getting started, learn to use both Cura and Slic3r/PrusaSlicer, save your money and get more filament. There's really nothing that S3D has on them these days. S3D needs to get an update out the door and show what the value is.
                      Cura has a crazy amount of control if you start to unhide the features, so it's a great slicer that can grow with you as you learn. Supports and modifier meshes are better than anything S3D can do at this point.
                      So don't spend money on S3D assuming it will make prints better or provide you something that the free slicers can't because that's not really the case anymore. If I was going to spend money on a slicer these days I would try Kissslicer, at least they are doing some innovative stuff and have frequent releases. S3D from what I gather is currently dysfunctional and is just as likely to go out of business as release a new version.
                      For those that are comfortable using it and have been using it for a long time that's awesome. It's a competent slicer to be sure, but I wouldn't say it's worth the money compared to the competition these days.
                      • Kolbiundefined
                        Kolbi @Phaedrux
                        @Phaedrux This is true on S3D, unless they come out with the great update....
                        It still comes in 2nd on my list due to the fact that I've been using it for some years (very comfortable with it) and it has never really failed me.
                        But YES, if just starting - I would advise not to learn it as it seems DIW.
