    Splitting Z-axis steppers
    884
    • StevePS3undefined
      StevePS3
      Maybe this is the problem, I did not change any jumpers. I didn't think I needed to. I thought that I could just do the M584 X0 Y1 Z2:4 E3. I've not read anywhere that said I needed to change jumpers.
      fcwiltundefined engikeneerundefined 2 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @StevePS3
        @StevePS3
        Well IF you had both Z steppers connected to the two Z connectors you had to remove the two little black jumpers on the second Z connector.
        IF you removed a cable to a Z stepper from the second Z connector you need to restore the jumpers.
        See the upper right corner of this screen shot of the Duet WiFi board.
        • engikeneerundefined
          engikeneer @StevePS3
          @StevePS3 What @fcwilt said...
          FYI, the two Z-motor headers on the Duet are wired in series, hence the need for the jumpers to complete the circuit. There's a note about this on the Duet wiring diagrams:
          https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams
          @Phaedrux (/someone with the power) - Might be worth putting a quick reminder about this on the Independent Z motor's page to make things clearer 🙂
          i3 clone with a bunch of mods
          • StevePS3undefined
            StevePS3
            Ahhhh. That makes sense. Thanks, let me try that.
            • StevePS3undefined
              StevePS3
              OK, So I have put the jumpers back and I've updated the config.g
              M569 P2 S0 ; physical drive 2 goes backwards
              M569 P3 S0 ; physical drive 3 goes forwards
              M584 X1 Y0 Z2:4 E3 ; set drive mapping
              M671 X0:0 Y-20:220 S0.5 ; leadscrews at front (connected to Z) and back (connected to E1) of Y axis
              M92 X100.00 Y100.00 Z400.00 E420.00 ; set steps per mm
              M203 X18000.00 Y18000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
              M906 X900 Y900 Z1100 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30
              Other than that I've done nothing so far. I though that it was best to get the leadscrews working before I worries about endstops.
              Now the stepper plugged into the E2 is working but the stepper plugged into Z is totally passive.
              • StevePS3undefined
                StevePS3
                OK, I saw one of the comments and I swapped it to 4:2 and that works.
                • StevePS3undefined
                  StevePS3
                  I now have the two endstop positions working but with each enstop probe, both motors are turning. Is that correct? If so then how is this levelling the bed?
                  • StevePS3undefined
                    StevePS3
                    OK, sorted. I had to change the M574 command to use an S2 probe rather than an S1. All working now, thanks everyone.
                      Glad you got it sorted. I'll add a note to the page about adding the jumpers back to the second Z driver port as it certainly may not be obvious to the uninitiated.
                      By the way, if you already have a probe you don't really need to use the dual z endstop method at all, but if it's working for you, rock on.
                        A Former User @StevePS3
                        This post is deleted!
