    Automatic Bed Leveling with Conditional Gcode Iterations
    Gcode meta commands
    9.8k
    • Kolbiundefined
      Kolbi
      This is a long and winding thread on my attempt to figure out the best way to construct beg.g for my independent controlled Z axis printer. Bottom line up front, two efficient ways were created to do such.
      ; bed.g
      ; 4 Passes performed. Reccomend 2 passes as minimum.
      M561                                             ; clear any bed transform
      G28                                              ; home
      while iterations <= 3                            ; perform 4 passes
          G30 P0 X25 Y100 Z-99999                      ; probe near a leadscrew, half way along Y axis
          G30 P1 X235 Y100 Z-99999 S2                  ; probe near a leadscrew and calibrate 2 motors
          G90                                          ; back to absolute mode
      G1 H2 Z8 F2600                                   ; raise head 8mm to ensure it is above the Z probe trigger height
      G1 X104 Y100 F6000                               ; put head over the centre of the bed, or wherever you want to probe
      G30
      and
      ; 0:/sys/bed.g
      ; Called to perform automatic bed compensation via G32
      M561                                                       ; Clear any existing bed transform.
      G28                                                        ; Home all axis.
      M558 F50 A5 S0.003                                         ; Slow z-probe, up to 5 probes until disparity is 0.003 or less - else yield average.
      while iterations <=2                                       ; Perform 3 passes.
         G30 P0 X25 Y105 Z-99999                                 ; Probe near a leadscrew, halfway along Y-axis.
         G30 P1 X225 Y105 Z-99999 S2                             ; Probe near a leadscrew and calibrate 2 motors.
         G1 X105 F10000                                          ; Move to the center of the bed.
         G30                                                     ; Probe the bed at the current XY position.
         M400                                                    ; Finish all moves, clear the buffer.
      M558 F50 A5 S-1                                            ; Slow the z-probe, perform 5 probes and yield the average.
      while move.calibration.initial.deviation >= 0.003          ; Perform additional leveling if previous deviation was over 0.003mm.
         if iterations = 5                                       ; Perform 5 addition checks, if needed.
            M300 S3000 P500                                      ; Sound alert, the required deviation could not be achieved.
            M558 F200 A1                                         ; Set normal z-probe speed.
            abort "!!! ABORTED !!! Failed to achieve < 0.002 deviation. Current deviation is " ^ move.calibration.initial.deviation ^ "mm."
         G30 P0 X25 Y105 Z-99999                                 ; Probe near the left leadscrew, halfway along Y-axis.
         G30 P1 X225 Y105 Z-99999 S2                             ; Probe near the right leadscrew and calibrate 2 motors.
         G1 X105 F10000                                          ; Move the nozzle to the center of the bed.
      echo "Gantry deviation of " ^ move.calibration.initial.deviation ^ "mm obtained."
      G1 Z8                                                      ; Raise nozzle 8mm to ensure it is above the Z probe trigger height.
      -Original post follows:
      I was looking into the M30 command & bed.g file, in regards to leveling the gantry, and had a question. I usually find I have to run the below (G30 set twice as shown) to get to a low disparity, such as:
      G90
      This works fine but could the same, or possible more accurate, be accomplished like this?
      G30 P1 X235 Y100 Z-99999                         ; probe near a leadscrew and calibrate 2 motors
      G30 P2 X25 Y100 Z-99999                          ; probe near a leadscrew, half way along Y axis
      G30 P3 X235 Y100 Z-99999 S4                      ; probe near a leadscrew and calibrate 2 motors
      Cheers,
      Kolbi
        If that did work, I don't think it would be more accurate. Plus I don't think that would work as expected.
        Doubling up the passes in bed.g isn't uncommon. It will really depend on how out of true the tilt is and how close to the lead screws you can probe.
        Kolbiundefined 1 Reply Last reply Reply Quote 1
        • Kolbiundefined
          Kolbi @Phaedrux
          Thanks @Phaedrux, was just wondering if there was a better way to skin the cat.
            I'd probably do it 3 times for good measure and then at the end probe the center of the bed with G30 to re-establish Z0. But that's just me.
            Kolbiundefined 1 Reply Last reply Reply Quote 0
            • Kolbiundefined
              Kolbi @Phaedrux
              @Phaedrux hehe, this is my bed.g:
              ; bed.g
              G28 W                                            ; home
              G1 H2 Z8 F2600                                   ; raise head 4mm to ensure it is above the Z probe trigger height
              G30                                              ; lower head, stop when probe triggered and set Z to trigger height
              • Kolbiundefined
                Kolbi
                @Phaedrux A cleaner way to do it:
                ; bed.g
                G28                                              ; home
                G30
                  Now you're cooking with gas!
                  • mwolterundefined
                    mwolter
                    @Kolbi
                    Since you're delving into conditional gcode you could look at something like this which only continues probing if necessary. Apologize for the length of this post but I included all sub macros for completeness. homexy.g also uses a virtual tool to indicate homing is in progress to avoid unnecessary Z axis movement. In case you're wondering, the sub macros are used to reduce duplicate code and unnecessarily updating several macros.
                    if !move.axes[0].homed || !move.axes[1].homed	; If the printer hasn't been homed, home it
                     M98 P"0:/sys/homeyx.g"	; home y and x
                    M98 P"0:/sys/homez.g"			; always home z
                    M558 P9 H5 F120 T24000			; increase dive height incase bed is severely out of alignment
                    M98 P"bed_threeScrews.g"		; perform bed tramming
                    echo "Bed Tramming Cycle: 1 - Difference was " ^ move.calibration.initial.deviation ^ "mm"
                    M98 P"0:/macros/Utilities/Config/bltouch_config"	; Apply default BLTouch config
                    while move.calibration.initial.deviation >= 0.01	; perform additional tramming if previous deviation was over 0.01mm
                     if iterations = 5
                      abort "Too many auto tramming attempts"
                     echo "Bed Tramming Cycle: " ^ iterations + 2 ^ " - Difference was " ^ move.calibration.initial.deviation ^ "mm"
                     continue
                    G28 Z							; home z
                    bltouch_config
                    M558 P9 C"^io7.in" H2 F120 T24000 	; set Z probe type to bltouch and the dive height + speeds
                    M98 P"0:/macros/Utilities/Config/bltouch_offset_config"
                    ; G31 - +Z Nozzle closer to bed, -Z Nozzle further from bed
                    G31 X0 Y-20.23 Z2.1 P500		; 200710 mosquito liquid
                    bed_threeScrews.g
                    G30 P0 X10 Y18 Z-99999			; probe near a front left leadscrew
                    G30 P1 X10 Y300 Z-99999			; probe near a back left leadscrew
                    G30 P2 X320 Y166 Z-99999 S3		; probe near a right leadscrew and level
                    homexy.g
                    ; homeyx.g
                    ; called to home x and y axes
                    ; Warning: do not home individual axes by calling G28 X or G28 Y. It will cause errors. Instead run the macro file directly. IE M98 P"0:/sys/homex.g"
                    M563 P9 S"HomeAll"		; create tool 9 to indicate homeall is in progress
                    G91              		; relative positioning
                    G1 Z5 F6000 H2   		; lift Z relative to current position
                    M98 P"0:/sys/homey.g"		; home y
                    M98 P"0:/sys/homex.g"		; home x
                    G90             		; absolute positioning
                    M563 P9 D-1 H-1			; delete tool 9 to indicate homeall is done
                    homex.g
                    if #tools != 10	; not homeall?
                    G1 H1 X357 F6000 ; move quickly to X axis endstop and stop there (first pass)
                    G1 X-5 F3600     ; go back a few mm
                    G1 H1 X357 F360  ; move slowly to X axis endstop once more (second pass)
                      G1 Z-5 F6000 H2  ; lower Z again
                    homez.g
                    ; Home Z - inline with autolevel axis
                    G1 X165 Y193 F24000	; go to middle of the bed probe point and home Z. BLTouch on right
                    M558 F1200		; Set probing at faster feed rate
                    G30			; quickly home Z by probing the bed
                    M400			; clear buffer
                    M98 P"0:/macros/Utilities/Config/bltouch_config"	; Return bltouch to defaults
                    G30			; slowly home Z by probing the bed
                    M400			; clear buffer
                    Phaedruxundefined Kolbiundefined 2 Replies Last reply Reply Quote 4
                      Phaedrux Moderator @mwolter
                      @mwolter Beautiful.
                      • Kolbiundefined
                        Kolbi @mwolter
                        @mwolter Nice, thanks for that.
                        Being away from my printer at the moment, but I would guess the following would be a correct implementation for my dual Z setup:
                        !!! Please see my final code, this is not correct !!!
                        ; bed.g
                        G28                                                     ; home
                         if iterations = 5                                      ; perform 5 checks
                          abort "!!!Failed to achieve < 0.01 deviation within 5 movements. Current deviation is " ^ move.calibration.initial.deviation ^ "mm."
                         continue
                        mwolterundefined 1 Reply Last reply Reply Quote 0
                        • fcwiltundefined
                          fcwilt
                          @mwolter said in Automatic Bed Leveling with Conditional Gcode Iterations:
                          G1 Z{move.axes[2].userPosition+20} F1200
                          Why that command as opposed to G91 G1 Z20?
                          And why did you implement homing such that you could not safely use G28 X or G28 Y?
                          It would not be hard to structure it so you could.
                          mwolterundefined 1 Reply Last reply Reply Quote 1
                          • mwolterundefined
                            mwolter @fcwilt
                            @fcwilt Using that command I can be sure it raised 20mm from the previous height. Probably overkill 🙂 It was a quick add before posting this and thought it would help with changing the magnetic bed but it makes for an odd extra movement of the bed between performing the homez and bed leveling. I'll rework the macros to utilize the virtual homeall tool to skip the unnecessary bed movement and update the macros above.
                            • mwolterundefined
                              mwolter @Kolbi
                              @Kolbi There are too many spaces before the G30 commands and it would cause issues. Would recommend doing one leveling pass before the while command. I haven't tested the following code but it should be close.
                              G28                                          ; home
                               if iterations = 5
                               continue
                              G28 Z					; home z
                              • Kolbiundefined
                                Kolbi @mwolter
                                @mwolter Thanks for covering my 6, I just caught that and was typing this:
                                ; bed.g
                                G28                                                     ; home
                                 echo "Gantry deviation of " ^ move.calibration.initial.deviation ^ "mm obtained within " ^ iterations + 2 ^ " tramming cycles."
                                 continue
                                • Kolbiundefined
                                  Kolbi
                                  @mwolter I guess the trailing code is not a hard requirement? By trailing code I'm referring to this:
                                   continue
                                  • mwolterundefined
                                    mwolter @Kolbi
                                    @Kolbi nope
                                    • mwolterundefined
                                      mwolter
                                      Removed the following and added it to homeall.g since I typically do a home all before changing the bed.
                                      G1 Z{move.axes[2].userPosition+20} F1200		; move z up 20mm for magnetic bed replacement
                                      homeall.g
                                      ; homeall.g
                                      ; called to home all axes (G28)
                                      M98 P"0:/sys/homez.g"	; home z
                                      G1 Z{move.axes[2].userPosition+50} F1200		; move z up 50mm for magnetic bed replacement
                                      • Kolbiundefined
                                        Kolbi
                                        Thanks @mwolter!
                                        For brevity, here is my final working version:
                                        ; bed.g
                                        M561                                                      ; Clear any bed transform
                                        G28                                                       ; Home
                                        while iterations <=1                                      ; Do minimum of 2 passes
                                           G30 P0 X25 Y100 Z-99999                                ; Probe near a leadscrew, half way along Y axis
                                           G30 P1 X235 Y100 Z-99999 S2                            ; Probe near a leadscrew and calibrate 2 motors
                                           G90
                                        while move.calibration.initial.deviation >= 0.002         ; perform additional tramming if previous deviation was over 0.002mm
                                           if iterations = 5                                      ; Perform 5 checks
                                              M300 S3000 P500                                     ; Sound alert, required deviation could not be achieved
                                              abort "!!! ABORTED !!! Failed to achieve < 0.002 deviation within 5 movements. Current deviation is " ^ move.calibration.initial.deviation ^ "mm."
                                           G90                                                    ; Back to absolute mode
                                        G1 H2 Z8 F2600                                            ; Raise head 8mm to ensure it is above the Z probe trigger height
                                        G1 X104 Y100 F6000                                        ; Put head over the centre of the bed, or wherever you want to probe
                                        G30
                                        • fcwiltundefined
                                          fcwilt @mwolter
                                          Thanks for the reply.
                                          Why do you think G91 G1 Z20 doesn't do that same thing?
                                          • mwolterundefined
                                            mwolter @fcwilt
                                            @fcwilt
                                            It’s just a different way of doing it and like I mentioned, this way I can be sure it’s raised 20mm from its current position. The G30 command actually sets Z to about 3m. So G1 Z20 will only raise Z by 17mm.
