    Automatic Bed Leveling with Conditional Gcode Iterations
    Gcode meta commands
    9.2k
    • Kolbiundefined
      Kolbi
      @Phaedrux A cleaner way to do it:
      ; bed.g
      ; 4 Passes performed. Reccomend 2 passes as minimum.
      M561                                             ; clear any bed transform
      G28                                              ; home
      while iterations <= 3                            ; perform 4 passes
          G30 P0 X25 Y100 Z-99999                      ; probe near a leadscrew, half way along Y axis
          G30 P1 X235 Y100 Z-99999 S2                  ; probe near a leadscrew and calibrate 2 motors
          G90                                          ; back to absolute mode
      G1 H2 Z8 F2600                                   ; raise head 8mm to ensure it is above the Z probe trigger height
      G1 X104 Y100 F6000                               ; put head over the centre of the bed, or wherever you want to probe
      G30
        Now you're cooking with gas!
        Kolbiundefined 1 Reply Last reply Reply Quote 0
        • mwolterundefined
          mwolter
          @Kolbi
          Since you're delving into conditional gcode you could look at something like this which only continues probing if necessary. Apologize for the length of this post but I included all sub macros for completeness. homexy.g also uses a virtual tool to indicate homing is in progress to avoid unnecessary Z axis movement. In case you're wondering, the sub macros are used to reduce duplicate code and unnecessarily updating several macros.
          if !move.axes[0].homed || !move.axes[1].homed	; If the printer hasn't been homed, home it
           M98 P"0:/sys/homeyx.g"	; home y and x
          M98 P"0:/sys/homez.g"			; always home z
          M558 P9 H5 F120 T24000			; increase dive height incase bed is severely out of alignment
          M98 P"bed_threeScrews.g"		; perform bed tramming
          echo "Bed Tramming Cycle: 1 - Difference was " ^ move.calibration.initial.deviation ^ "mm"
          M98 P"0:/macros/Utilities/Config/bltouch_config"	; Apply default BLTouch config
          while move.calibration.initial.deviation >= 0.01	; perform additional tramming if previous deviation was over 0.01mm
           if iterations = 5
            abort "Too many auto tramming attempts"
           echo "Bed Tramming Cycle: " ^ iterations + 2 ^ " - Difference was " ^ move.calibration.initial.deviation ^ "mm"
           continue
          G28 Z							; home z
          bltouch_config
          M558 P9 C"^io7.in" H2 F120 T24000 	; set Z probe type to bltouch and the dive height + speeds
          M98 P"0:/macros/Utilities/Config/bltouch_offset_config"
          ; G31 - +Z Nozzle closer to bed, -Z Nozzle further from bed
          G31 X0 Y-20.23 Z2.1 P500		; 200710 mosquito liquid
          bed_threeScrews.g
          G30 P0 X10 Y18 Z-99999			; probe near a front left leadscrew
          G30 P1 X10 Y300 Z-99999			; probe near a back left leadscrew
          G30 P2 X320 Y166 Z-99999 S3		; probe near a right leadscrew and level
          homexy.g
          ; homeyx.g
          ; called to home x and y axes
          ; Warning: do not home individual axes by calling G28 X or G28 Y. It will cause errors. Instead run the macro file directly. IE M98 P"0:/sys/homex.g"
          M563 P9 S"HomeAll"		; create tool 9 to indicate homeall is in progress
          G91              		; relative positioning
          G1 Z5 F6000 H2   		; lift Z relative to current position
          M98 P"0:/sys/homey.g"		; home y
          M98 P"0:/sys/homex.g"		; home x
          G90             		; absolute positioning
          M563 P9 D-1 H-1			; delete tool 9 to indicate homeall is done
          homex.g
          if #tools != 10	; not homeall?
          G1 H1 X357 F6000 ; move quickly to X axis endstop and stop there (first pass)
          G1 X-5 F3600     ; go back a few mm
          G1 H1 X357 F360  ; move slowly to X axis endstop once more (second pass)
            G1 Z-5 F6000 H2  ; lower Z again
          homez.g
          ; Home Z - inline with autolevel axis
          G1 X165 Y193 F24000	; go to middle of the bed probe point and home Z. BLTouch on right
          M558 F1200		; Set probing at faster feed rate
          G30			; quickly home Z by probing the bed
          M400			; clear buffer
          M98 P"0:/macros/Utilities/Config/bltouch_config"	; Return bltouch to defaults
          G30			; slowly home Z by probing the bed
          M400			; clear buffer
          Phaedruxundefined Kolbiundefined 2 Replies Last reply Reply Quote 4
            Phaedrux Moderator @mwolter
            @mwolter Beautiful.
            • Kolbiundefined
              Kolbi @mwolter
              @mwolter Nice, thanks for that.
              Being away from my printer at the moment, but I would guess the following would be a correct implementation for my dual Z setup:
              !!! Please see my final code, this is not correct !!!
              ; bed.g
              G28                                                     ; home
               if iterations = 5                                      ; perform 5 checks
                abort "!!!Failed to achieve < 0.01 deviation within 5 movements. Current deviation is " ^ move.calibration.initial.deviation ^ "mm."
               continue
              mwolterundefined 1 Reply Last reply Reply Quote 0
              • fcwiltundefined
                fcwilt
                @mwolter said in Automatic Bed Leveling with Conditional Gcode Iterations:
                G1 Z{move.axes[2].userPosition+20} F1200
                Why that command as opposed to G91 G1 Z20?
                And why did you implement homing such that you could not safely use G28 X or G28 Y?
                It would not be hard to structure it so you could.
                mwolterundefined 1 Reply Last reply Reply Quote 1
                • mwolterundefined
                  mwolter @fcwilt
                  @fcwilt Using that command I can be sure it raised 20mm from the previous height. Probably overkill ๐Ÿ™‚ It was a quick add before posting this and thought it would help with changing the magnetic bed but it makes for an odd extra movement of the bed between performing the homez and bed leveling. I'll rework the macros to utilize the virtual homeall tool to skip the unnecessary bed movement and update the macros above.
                  • mwolterundefined
                    mwolter @Kolbi
                    @Kolbi There are too many spaces before the G30 commands and it would cause issues. Would recommend doing one leveling pass before the while command. I haven't tested the following code but it should be close.
                    G28                                          ; home
                     if iterations = 5
                     continue
                    G28 Z					; home z
                    • Kolbiundefined
                      Kolbi @mwolter
                      @mwolter Thanks for covering my 6, I just caught that and was typing this:
                      ; bed.g
                      ; Called to perform automatic bed compensation via G32
                      G28                                                     ; home
                       echo "Gantry deviation of " ^ move.calibration.initial.deviation ^ "mm obtained within " ^ iterations + 2 ^ " tramming cycles."
                       continue
                      • Kolbiundefined
                        Kolbi
                        @mwolter I guess the trailing code is not a hard requirement? By trailing code I'm referring to this:
                         continue
                        • mwolterundefined
                          mwolter @Kolbi
                          @Kolbi nope
                          • mwolterundefined
                            mwolter
                            Removed the following and added it to homeall.g since I typically do a home all before changing the bed.
                            G1 Z{move.axes[2].userPosition+20} F1200		; move z up 20mm for magnetic bed replacement
                            homeall.g
                            ; homeall.g
                            ; called to home all axes (G28)
                            M98 P"0:/sys/homez.g"	; home z
                            G1 Z{move.axes[2].userPosition+50} F1200		; move z up 50mm for magnetic bed replacement
                            • Kolbiundefined
                              Kolbi
                              Thanks @mwolter!
                              For brevity, here is my final working version:
                              ; bed.g
                              M561                                                      ; Clear any bed transform
                              G28                                                       ; Home
                              while iterations <=1                                      ; Do minimum of 2 passes
                                 G30 P0 X25 Y100 Z-99999                                ; Probe near a leadscrew, half way along Y axis
                                 G30 P1 X235 Y100 Z-99999 S2                            ; Probe near a leadscrew and calibrate 2 motors
                                 G90
                              while move.calibration.initial.deviation >= 0.002         ; perform additional tramming if previous deviation was over 0.002mm
                                 if iterations = 5                                      ; Perform 5 checks
                                    M300 S3000 P500                                     ; Sound alert, required deviation could not be achieved
                                    abort "!!! ABORTED !!! Failed to achieve < 0.002 deviation within 5 movements. Current deviation is " ^ move.calibration.initial.deviation ^ "mm."
                                 G90                                                    ; Back to absolute mode
                              echo "Gantry deviation of " ^ move.calibration.initial.deviation ^ "mm obtained."
                              G1 H2 Z8 F2600                                            ; Raise head 8mm to ensure it is above the Z probe trigger height
                              G1 X104 Y100 F6000                                        ; Put head over the centre of the bed, or wherever you want to probe
                              G30
                              • fcwiltundefined
                                fcwilt @mwolter
                                Thanks for the reply.
                                Why do you think G91 G1 Z20 doesn't do that same thing?
                                • mwolterundefined
                                  mwolter @fcwilt
                                  @fcwilt
                                  Itโ€™s just a different way of doing it and like I mentioned, this way I can be sure itโ€™s raised 20mm from its current position. The G30 command actually sets Z to about 3m. So G1 Z20 will only raise Z by 17mm.
                                  • Kolbiundefined
                                    Kolbi @Phaedrux
                                    @Phaedrux said in Automatic Bed Leveling with Conditional Gcode Iterations:
                                    Definitely cooking with gas now!
                                    • fcwiltundefined
                                      fcwilt @mwolter
                                      I think you will find that a G91 G1 Z20 will raise Z by 20 unless it doesn't have that much room left on the axis.
                                      If a G30 sets Z to 3 then a G91 G1 Z20 will take Z to 23.
                                      At least that is my experience.
                                      Good luck.
                                      mwolterundefined Phaedruxundefined 2 Replies Last reply Reply Quote 1
                                      • mwolterundefined
                                        mwolter @fcwilt
                                        This post is deleted!
                                          Phaedrux Moderator @fcwilt
                                          @fcwilt said in Automatic Bed Leveling with Conditional Gcode Iterations:
                                          I think you will find that a G91 G1 Z20 will raise Z by 20 unless it doesn't have that much room left of the axis.
                                          Correct. G90 moves to an absolute point, G91 is relative to the current position.
                                          https://duet3d.dozuki.com/Wiki/Gcode#Section_G90_Set_to_Absolute_Positioning
                                          • mwolterundefined
                                            mwolter @Phaedrux
                                            @Phaedrux If the command G90 G1 Z20 is used in one line, does G91 have to be used to return to absolute mode?
                                            Phaedruxundefined A Former User? fcwiltundefined 3 Replies Last reply Reply Quote 1
