    Automatic Bed Leveling with Conditional Gcode Iterations
    Gcode meta commands
    6.5k
      Now you're cooking with gas!
      Kolbiundefined 1 Reply Last reply Reply Quote 0
      • mwolterundefined
        mwolter
        @Kolbi
        Since you're delving into conditional gcode you could look at something like this which only continues probing if necessary. Apologize for the length of this post but I included all sub macros for completeness. homexy.g also uses a virtual tool to indicate homing is in progress to avoid unnecessary Z axis movement. In case you're wondering, the sub macros are used to reduce duplicate code and unnecessarily updating several macros.
        if !move.axes[0].homed || !move.axes[1].homed	; If the printer hasn't been homed, home it
         M98 P"0:/sys/homeyx.g"	; home y and x
        M98 P"0:/sys/homez.g"			; always home z
        M561					; clear any bed transform
        M558 P9 H5 F120 T24000			; increase dive height incase bed is severely out of alignment
        M98 P"bed_threeScrews.g"		; perform bed tramming
        echo "Bed Tramming Cycle: 1 - Difference was " ^ move.calibration.initial.deviation ^ "mm"
        M98 P"0:/macros/Utilities/Config/bltouch_config"	; Apply default BLTouch config
        while move.calibration.initial.deviation >= 0.01	; perform additional tramming if previous deviation was over 0.01mm
         if iterations = 5
          abort "Too many auto tramming attempts"
         echo "Bed Tramming Cycle: " ^ iterations + 2 ^ " - Difference was " ^ move.calibration.initial.deviation ^ "mm"
         continue
        G28 Z							; home z
        bltouch_config
        M558 P9 C"^io7.in" H2 F120 T24000 	; set Z probe type to bltouch and the dive height + speeds
        M98 P"0:/macros/Utilities/Config/bltouch_offset_config"
        ; G31 - +Z Nozzle closer to bed, -Z Nozzle further from bed
        G31 X0 Y-20.23 Z2.1 P500		; 200710 mosquito liquid
        bed_threeScrews.g
        G30 P0 X10 Y18 Z-99999			; probe near a front left leadscrew
        G30 P1 X10 Y300 Z-99999			; probe near a back left leadscrew
        G30 P2 X320 Y166 Z-99999 S3		; probe near a right leadscrew and level
        homexy.g
        ; homeyx.g
        ; called to home x and y axes
        ; Warning: do not home individual axes by calling G28 X or G28 Y. It will cause errors. Instead run the macro file directly. IE M98 P"0:/sys/homex.g"
        M563 P9 S"HomeAll"		; create tool 9 to indicate homeall is in progress
        G91              		; relative positioning
        G1 Z5 F6000 H2   		; lift Z relative to current position
        M98 P"0:/sys/homey.g"		; home y
        M98 P"0:/sys/homex.g"		; home x
        G90             		; absolute positioning
        M563 P9 D-1 H-1			; delete tool 9 to indicate homeall is done
        homex.g
        if #tools != 10	; not homeall?
        G1 H1 X357 F6000 ; move quickly to X axis endstop and stop there (first pass)
        G1 X-5 F3600     ; go back a few mm
        G1 H1 X357 F360  ; move slowly to X axis endstop once more (second pass)
          G1 Z-5 F6000 H2  ; lower Z again
        homez.g
        ; Home Z - inline with autolevel axis
        G1 X165 Y193 F24000	; go to middle of the bed probe point and home Z. BLTouch on right
        M558 F1200		; Set probing at faster feed rate
        G30			; quickly home Z by probing the bed
        M400			; clear buffer
        M98 P"0:/macros/Utilities/Config/bltouch_config"	; Return bltouch to defaults
        G30			; slowly home Z by probing the bed
        M400			; clear buffer
        Phaedruxundefined Kolbiundefined 2 Replies Last reply Reply Quote 4
          Phaedrux Moderator @mwolter
          @mwolter Beautiful.
          • Kolbiundefined
            Kolbi @mwolter
            @mwolter Nice, thanks for that.
            Being away from my printer at the moment, but I would guess the following would be a correct implementation for my dual Z setup:
            !!! Please see my final code, this is not correct !!!
            ; bed.g
            G28                                                     ; home
             if iterations = 5                                      ; perform 5 checks
              abort "!!!Failed to achieve < 0.01 deviation within 5 movements. Current deviation is " ^ move.calibration.initial.deviation ^ "mm."
                G30 P0 X25 Y100 Z-99999                             ; probe near a leadscrew, half way along Y axis
                G30 P1 X235 Y100 Z-99999 S2                         ; probe near a leadscrew and calibrate 2 motors
                G90                                                 ; back to absolute mode
             continue
            mwolterundefined 1 Reply Last reply Reply Quote 0
            • fcwiltundefined
              fcwilt
              @mwolter said in Automatic Bed Leveling with Conditional Gcode Iterations:
              G1 Z{move.axes[2].userPosition+20} F1200
              Why that command as opposed to G91 G1 Z20?
              And why did you implement homing such that you could not safely use G28 X or G28 Y?
              It would not be hard to structure it so you could.
              mwolterundefined 1 Reply Last reply Reply Quote 1
              • mwolterundefined
                mwolter @fcwilt
                @fcwilt Using that command I can be sure it raised 20mm from the previous height. Probably overkill ๐Ÿ™‚ It was a quick add before posting this and thought it would help with changing the magnetic bed but it makes for an odd extra movement of the bed between performing the homez and bed leveling. I'll rework the macros to utilize the virtual homeall tool to skip the unnecessary bed movement and update the macros above.
                • mwolterundefined
                  mwolter @Kolbi
                  @Kolbi There are too many spaces before the G30 commands and it would cause issues. Would recommend doing one leveling pass before the while command. I haven't tested the following code but it should be close.
                  G28                                          ; home
                   if iterations = 5
                   continue
                  G28 Z					; home z
                  • Kolbiundefined
                    Kolbi @mwolter
                    @mwolter Thanks for covering my 6, I just caught that and was typing this:
                    ; bed.g
                    ; Called to perform automatic bed compensation via G32
                    G28                                                     ; home
                     echo "Gantry deviation of " ^ move.calibration.initial.deviation ^ "mm obtained within " ^ iterations + 2 ^ " tramming cycles."
                     continue
                    • Kolbiundefined
                      Kolbi
                      @mwolter I guess the trailing code is not a hard requirement? By trailing code I'm referring to this:
                       continue
                      • mwolterundefined
                        mwolter @Kolbi
                        @Kolbi nope
                        • mwolterundefined
                          mwolter
                          Removed the following and added it to homeall.g since I typically do a home all before changing the bed.
                          G1 Z{move.axes[2].userPosition+20} F1200		; move z up 20mm for magnetic bed replacement
                          homeall.g
                          ; homeall.g
                          ; called to home all axes (G28)
                          M98 P"0:/sys/homez.g"	; home z
                          G1 Z{move.axes[2].userPosition+50} F1200		; move z up 50mm for magnetic bed replacement
                          • Kolbiundefined
                            Kolbi
                            Thanks @mwolter!
                            For brevity, here is my final working version:
                            ; bed.g
                            M561                                                      ; Clear any bed transform
                            G28                                                       ; Home
                            while iterations <=1                                      ; Do minimum of 2 passes
                               G30 P0 X25 Y100 Z-99999                                ; Probe near a leadscrew, half way along Y axis
                               G30 P1 X235 Y100 Z-99999 S2                            ; Probe near a leadscrew and calibrate 2 motors
                               G90
                            while move.calibration.initial.deviation >= 0.002         ; perform additional tramming if previous deviation was over 0.002mm
                               if iterations = 5                                      ; Perform 5 checks
                                  M300 S3000 P500                                     ; Sound alert, required deviation could not be achieved
                                  abort "!!! ABORTED !!! Failed to achieve < 0.002 deviation within 5 movements. Current deviation is " ^ move.calibration.initial.deviation ^ "mm."
                               G90                                                    ; Back to absolute mode
                            echo "Gantry deviation of " ^ move.calibration.initial.deviation ^ "mm obtained."
                            G1 H2 Z8 F2600                                            ; Raise head 8mm to ensure it is above the Z probe trigger height
                            G1 X104 Y100 F6000                                        ; Put head over the centre of the bed, or wherever you want to probe
                            G30
                            • fcwiltundefined
                              fcwilt @mwolter
                              Thanks for the reply.
                              Why do you think G91 G1 Z20 doesn't do that same thing?
                              • mwolterundefined
                                mwolter @fcwilt
                                @fcwilt
                                Itโ€™s just a different way of doing it and like I mentioned, this way I can be sure itโ€™s raised 20mm from its current position. The G30 command actually sets Z to about 3m. So G1 Z20 will only raise Z by 17mm.
                                • Kolbiundefined
                                  Kolbi @Phaedrux
                                  @Phaedrux said in Automatic Bed Leveling with Conditional Gcode Iterations:
                                  Definitely cooking with gas now!
                                  • fcwiltundefined
                                    fcwilt @mwolter
                                    I think you will find that a G91 G1 Z20 will raise Z by 20 unless it doesn't have that much room left on the axis.
                                    If a G30 sets Z to 3 then a G91 G1 Z20 will take Z to 23.
                                    At least that is my experience.
                                    Good luck.
                                    mwolterundefined Phaedruxundefined 2 Replies Last reply Reply Quote 1
                                    • mwolterundefined
                                      mwolter @fcwilt
                                      This post is deleted!
                                        Phaedrux Moderator @fcwilt
                                        @fcwilt said in Automatic Bed Leveling with Conditional Gcode Iterations:
                                        I think you will find that a G91 G1 Z20 will raise Z by 20 unless it doesn't have that much room left of the axis.
                                        Correct. G90 moves to an absolute point, G91 is relative to the current position.
                                        https://duet3d.dozuki.com/Wiki/Gcode#Section_G90_Set_to_Absolute_Positioning
                                        • mwolterundefined
                                          mwolter @Phaedrux
                                          @Phaedrux If the command G90 G1 Z20 is used in one line, does G91 have to be used to return to absolute mode?
                                          Phaedruxundefined A Former User? fcwiltundefined 3 Replies Last reply Reply Quote 1
                                            @mwolter That's a good question, and I'm not sure off the top of my head. Would have to test to see if it sticks in that format or not.
