    Automatic Bed Leveling with Conditional Gcode Iterations
    Gcode meta commands
    7.9k
      I'd probably do it 3 times for good measure and then at the end probe the center of the bed with G30 to re-establish Z0. But that's just me.
      Kolbiundefined 1 Reply Last reply Reply Quote 0
      • Kolbiundefined
        Kolbi @Phaedrux
        @Phaedrux hehe, this is my bed.g:
        ; bed.g
        ; 4 Passes performed. Reccomend 2 passes as minimum.
        M561                                             ; clear any bed transform
        G28 W                                            ; home
        G30 P0 X25 Y100 Z-99999                          ; probe near a leadscrew, half way along Y axis
        G30 P1 X235 Y100 Z-99999 S2                      ; probe near a leadscrew and calibrate 2 motors
        G90                                              ; back to absolute mode
        G1 H2 Z8 F2600                                   ; raise head 4mm to ensure it is above the Z probe trigger height
        G1 X104 Y100 F6000                               ; put head over the centre of the bed, or wherever you want to probe
        G30                                              ; lower head, stop when probe triggered and set Z to trigger height
        • Kolbiundefined
          Kolbi
          @Phaedrux A cleaner way to do it:
          ; bed.g
          G28                                              ; home
          while iterations <= 3                            ; perform 4 passes
          G1 H2 Z8 F2600                                   ; raise head 8mm to ensure it is above the Z probe trigger height
          G30
            Now you're cooking with gas!
            • mwolterundefined
              mwolter
              @Kolbi
              Since you're delving into conditional gcode you could look at something like this which only continues probing if necessary. Apologize for the length of this post but I included all sub macros for completeness. homexy.g also uses a virtual tool to indicate homing is in progress to avoid unnecessary Z axis movement. In case you're wondering, the sub macros are used to reduce duplicate code and unnecessarily updating several macros.
              if !move.axes[0].homed || !move.axes[1].homed	; If the printer hasn't been homed, home it
               M98 P"0:/sys/homeyx.g"	; home y and x
              M98 P"0:/sys/homez.g"			; always home z
              M558 P9 H5 F120 T24000			; increase dive height incase bed is severely out of alignment
              M98 P"bed_threeScrews.g"		; perform bed tramming
              echo "Bed Tramming Cycle: 1 - Difference was " ^ move.calibration.initial.deviation ^ "mm"
              M98 P"0:/macros/Utilities/Config/bltouch_config"	; Apply default BLTouch config
              while move.calibration.initial.deviation >= 0.01	; perform additional tramming if previous deviation was over 0.01mm
               if iterations = 5
                abort "Too many auto tramming attempts"
               echo "Bed Tramming Cycle: " ^ iterations + 2 ^ " - Difference was " ^ move.calibration.initial.deviation ^ "mm"
               continue
              G28 Z							; home z
              bltouch_config
              M558 P9 C"^io7.in" H2 F120 T24000 	; set Z probe type to bltouch and the dive height + speeds
              M98 P"0:/macros/Utilities/Config/bltouch_offset_config"
              ; G31 - +Z Nozzle closer to bed, -Z Nozzle further from bed
              G31 X0 Y-20.23 Z2.1 P500		; 200710 mosquito liquid
              bed_threeScrews.g
              G30 P0 X10 Y18 Z-99999			; probe near a front left leadscrew
              G30 P1 X10 Y300 Z-99999			; probe near a back left leadscrew
              G30 P2 X320 Y166 Z-99999 S3		; probe near a right leadscrew and level
              homexy.g
              ; homeyx.g
              ; called to home x and y axes
              ; Warning: do not home individual axes by calling G28 X or G28 Y. It will cause errors. Instead run the macro file directly. IE M98 P"0:/sys/homex.g"
              M563 P9 S"HomeAll"		; create tool 9 to indicate homeall is in progress
              G91              		; relative positioning
              G1 Z5 F6000 H2   		; lift Z relative to current position
              M98 P"0:/sys/homey.g"		; home y
              M98 P"0:/sys/homex.g"		; home x
              G90             		; absolute positioning
              M563 P9 D-1 H-1			; delete tool 9 to indicate homeall is done
              homex.g
              if #tools != 10	; not homeall?
              G1 H1 X357 F6000 ; move quickly to X axis endstop and stop there (first pass)
              G1 X-5 F3600     ; go back a few mm
              G1 H1 X357 F360  ; move slowly to X axis endstop once more (second pass)
                G1 Z-5 F6000 H2  ; lower Z again
              homez.g
              ; Home Z - inline with autolevel axis
              G1 X165 Y193 F24000	; go to middle of the bed probe point and home Z. BLTouch on right
              M558 F1200		; Set probing at faster feed rate
              G30			; quickly home Z by probing the bed
              M400			; clear buffer
              M98 P"0:/macros/Utilities/Config/bltouch_config"	; Return bltouch to defaults
              G30			; slowly home Z by probing the bed
              M400			; clear buffer
              Phaedruxundefined Kolbiundefined 2 Replies Last reply Reply Quote 4
                Phaedrux Moderator @mwolter
                @mwolter Beautiful.
                • Kolbiundefined
                  Kolbi @mwolter
                  @mwolter Nice, thanks for that.
                  Being away from my printer at the moment, but I would guess the following would be a correct implementation for my dual Z setup:
                  !!! Please see my final code, this is not correct !!!
                  ; bed.g
                  G28                                                     ; home
                   if iterations = 5                                      ; perform 5 checks
                    abort "!!!Failed to achieve < 0.01 deviation within 5 movements. Current deviation is " ^ move.calibration.initial.deviation ^ "mm."
                   continue
                  mwolterundefined 1 Reply Last reply Reply Quote 0
                  • fcwiltundefined
                    fcwilt
                    @mwolter said in Automatic Bed Leveling with Conditional Gcode Iterations:
                    G1 Z{move.axes[2].userPosition+20} F1200
                    Why that command as opposed to G91 G1 Z20?
                    And why did you implement homing such that you could not safely use G28 X or G28 Y?
                    It would not be hard to structure it so you could.
                    mwolterundefined 1 Reply Last reply Reply Quote 1
                    • mwolterundefined
                      mwolter @fcwilt
                      @fcwilt Using that command I can be sure it raised 20mm from the previous height. Probably overkill 🙂 It was a quick add before posting this and thought it would help with changing the magnetic bed but it makes for an odd extra movement of the bed between performing the homez and bed leveling. I'll rework the macros to utilize the virtual homeall tool to skip the unnecessary bed movement and update the macros above.
                      • mwolterundefined
                        mwolter @Kolbi
                        @Kolbi There are too many spaces before the G30 commands and it would cause issues. Would recommend doing one leveling pass before the while command. I haven't tested the following code but it should be close.
                        G28                                          ; home
                         if iterations = 5
                         continue
                        G28 Z					; home z
                        • Kolbiundefined
                          Kolbi @mwolter
                          @mwolter Thanks for covering my 6, I just caught that and was typing this:
                          ; bed.g
                          ; Called to perform automatic bed compensation via G32
                          G28                                                     ; home
                           echo "Gantry deviation of " ^ move.calibration.initial.deviation ^ "mm obtained within " ^ iterations + 2 ^ " tramming cycles."
                           continue
                          • Kolbiundefined
                            Kolbi
                            @mwolter I guess the trailing code is not a hard requirement? By trailing code I'm referring to this:
                             continue
                            • mwolterundefined
                              mwolter @Kolbi
                              @Kolbi nope
                              • mwolterundefined
                                mwolter
                                Removed the following and added it to homeall.g since I typically do a home all before changing the bed.
                                G1 Z{move.axes[2].userPosition+20} F1200		; move z up 20mm for magnetic bed replacement
                                homeall.g
                                ; homeall.g
                                ; called to home all axes (G28)
                                M98 P"0:/sys/homez.g"	; home z
                                G1 Z{move.axes[2].userPosition+50} F1200		; move z up 50mm for magnetic bed replacement
                                • Kolbiundefined
                                  Kolbi
                                  Thanks @mwolter!
                                  For brevity, here is my final working version:
                                  ; bed.g
                                  M561                                                      ; Clear any bed transform
                                  G28                                                       ; Home
                                  while iterations <=1                                      ; Do minimum of 2 passes
                                     G30 P0 X25 Y100 Z-99999                                ; Probe near a leadscrew, half way along Y axis
                                     G30 P1 X235 Y100 Z-99999 S2                            ; Probe near a leadscrew and calibrate 2 motors
                                     G90
                                  while move.calibration.initial.deviation >= 0.002         ; perform additional tramming if previous deviation was over 0.002mm
                                     if iterations = 5                                      ; Perform 5 checks
                                        M300 S3000 P500                                     ; Sound alert, required deviation could not be achieved
                                        abort "!!! ABORTED !!! Failed to achieve < 0.002 deviation within 5 movements. Current deviation is " ^ move.calibration.initial.deviation ^ "mm."
                                     G90                                                    ; Back to absolute mode
                                  echo "Gantry deviation of " ^ move.calibration.initial.deviation ^ "mm obtained."
                                  G1 H2 Z8 F2600                                            ; Raise head 8mm to ensure it is above the Z probe trigger height
                                  G1 X104 Y100 F6000                                        ; Put head over the centre of the bed, or wherever you want to probe
                                  G30
                                  • fcwiltundefined
                                    fcwilt @mwolter
                                    Thanks for the reply.
                                    Why do you think G91 G1 Z20 doesn't do that same thing?
                                    • mwolterundefined
                                      mwolter @fcwilt
                                      @fcwilt
                                      It’s just a different way of doing it and like I mentioned, this way I can be sure it’s raised 20mm from its current position. The G30 command actually sets Z to about 3m. So G1 Z20 will only raise Z by 17mm.
                                      • Kolbiundefined
                                        Kolbi @Phaedrux
                                        @Phaedrux said in Automatic Bed Leveling with Conditional Gcode Iterations:
                                        Definitely cooking with gas now!
                                        • fcwiltundefined
                                          fcwilt @mwolter
                                          I think you will find that a G91 G1 Z20 will raise Z by 20 unless it doesn't have that much room left on the axis.
                                          If a G30 sets Z to 3 then a G91 G1 Z20 will take Z to 23.
                                          At least that is my experience.
                                          Good luck.
                                          mwolterundefined Phaedruxundefined 2 Replies Last reply Reply Quote 1
                                          • mwolterundefined
                                            mwolter @fcwilt
                                            This post is deleted!
