    Setting up heater chamber - need help
    1.4k
    • JoergS5undefined
      JoergS5 @felt342
      @felt342 please try setting D low (see my text change).
      I expect the values to be changed after a reboot only or setting it differently explicitly.
      felt342undefined 1 Reply Last reply Reply Quote 0
      • felt342undefined
        felt342 @JoergS5
        @JoergS5
        Okay, there is some light -
        I did set D value to 1, and for some reason, if I report M307 H5 its does show me values from the config.g finally!
        And start to autotune however it seems didn't change anything.
        Industrial 3D printing service in the Netherlands - gagatstudio.com
        • JoergS5undefined
          JoergS5 @felt342
          @felt342 is the error message Error: Heating fault on heater 5, temperature rising much more slowly than the expected 1.7°C/sec gone now? Would be interesting how the 1.7 is calculated. Then we can understand how to set it higher.
          • felt342undefined
            felt342 @JoergS5
            @JoergS5 I just did a test and got now this error with 0.3C/s
            Error: Heating fault on heater 5, temperature rising much more slowly than the expected 0.3°C/sec
            Could be what my value for E3D thermistor are wrong? But those values is something that I found on duet forum for e3d thermistor.
            • JoergS5undefined
              JoergS5 @felt342
              @felt342 can you see how 1.7 and 0.3 is calculated? M307 original and now)?
              I found the error message in the source code, it depends on expected rate, dead time, the current temperature and the PWM.
              Measuring the temperature wrong could be a reason.
              I've also seen 4725 as value for the E3D thermistor. You could try verifying that it works by heating up somehow without the chamber heater. (hair dryer)
              • felt342undefined
                felt342 @JoergS5
                @JoergS5
                Well, setting C value to 2000 doesn`t give me an error anymore about Fault in heater 5, and its keeps the rising temperature. But I still can not do the autotune.
                Yeah the thermistor seams works.
                • JoergS5undefined
                  JoergS5 @felt342
                  @felt342 you get the same autotune error like in the first post? And does the reported temperature value of the thermistor go up?
                  • felt342undefined
                    felt342 @JoergS5
                    @JoergS5
                    Yes, this is an error:
                    Autotune canceled because the temperature is not increasing.
                    Temperature goes up, but slowly about 1 degree a minute. This would be fine for me because I am planning to add two heaters there overall of 600, but first I got one and would like to deal it up first, to at least heating without errors. Which we did now (thanks to you!) setting C to 2000, but to perform autotune for real values would be better.
                    • JoergS5undefined
                      JoergS5 @felt342
                      @felt342 Seems to be a timeout. I cannot find the error message in the source at the moment.
                      felt342undefined 1 Reply Last reply Reply Quote 1
                      • felt342undefined
                        felt342 @JoergS5
                        @JoergS5
                        Yeah, I really appreciate your help and digging in! What I am thinking is maybe better to move thermistor to the middle of the chamber, it will probably be the faster response until I have only one heater.
                        JoergS5undefined 2 Replies Last reply Reply Quote 0
                        • JoergS5undefined
                          JoergS5 @felt342
                          @felt342 Now I know why I cannot find it. I search in the 3.1.1 code....
                          => didn't find it in 2.05 code also. Will search and will tell you if I find something.
                          • felt342undefined
                            felt342 @JoergS5
                            @JoergS5
                            Happens 🙂
                            Thank you!
                            • JoergS5undefined
                              JoergS5 @felt342
                              @felt342 I found it in pid.cpp of 2.05 source:
                              // Heating up
                              const bool isBedOrChamberHeater = reprap.GetHeat().IsBedOrChamberHeater(heater);
                              const uint32_t heatingTime = millis() - tuningPhaseStartTime;
                              const float extraTimeAllowed = (isBedOrChamberHeater) ? 60.0 : 30.0;
                              if (heatingTime > (uint32_t)((model.GetDeadTime() + extraTimeAllowed) * SecondsToMillis)
                              && (temperature - tuningStartTemp) < 3.0)
                              platform.Message(GenericMessage, "Auto tune cancelled because temperature is not increasing\n");
                              break;
                              So the error message is called and a break occurs, if the heating time is bigger than dead time + extraTimeAllowed.
                              A low dead time helps in any case.
                              extraTimeAllowed is defined by:
                              so for Chamber it is 60.
                              You could try setting D negative, say -59. Don't know whether it works.
                              You're welcome and I wish you success with the heated chamber!
                              felt342undefined 1 Reply Last reply Reply Quote 2
                              • felt342undefined
                                felt342 @JoergS5
                                @JoergS5
                                That seems working without error!
                                I didn't try negative D, but I set D to 1 and kept C at 2000, waiting for autotune and values 🙂
                                Thanks a lot again!
                                • JoergS5undefined
                                  JoergS5 @felt342
                                  @felt342 Nice to hear, thank you!
                                  See you.
                                  • felt342undefined
                                    felt342 @JoergS5
                                    @JoergS5
                                    I must say it`s a nice way of solving the issue, digging the source code, will take it as a tip 🙂
