    Setting up heater chamber - need help
    1.4k
    • felt342undefined
      felt342 @JoergS5
      @JoergS5
      Okay, there is some light -
      I did set D value to 1, and for some reason, if I report M307 H5 its does show me values from the config.g finally!
      And start to autotune however it seems didn't change anything.
      Industrial 3D printing service in the Netherlands - gagatstudio.com
      • JoergS5undefined
        JoergS5 @felt342
        @felt342 is the error message Error: Heating fault on heater 5, temperature rising much more slowly than the expected 1.7°C/sec gone now? Would be interesting how the 1.7 is calculated. Then we can understand how to set it higher.
        felt342undefined 1 Reply Last reply Reply Quote 0
        • felt342undefined
          felt342 @JoergS5
          @JoergS5 I just did a test and got now this error with 0.3C/s
          Error: Heating fault on heater 5, temperature rising much more slowly than the expected 0.3°C/sec
          Could be what my value for E3D thermistor are wrong? But those values is something that I found on duet forum for e3d thermistor.
          • JoergS5undefined
            JoergS5 @felt342
            @felt342 can you see how 1.7 and 0.3 is calculated? M307 original and now)?
            I found the error message in the source code, it depends on expected rate, dead time, the current temperature and the PWM.
            Measuring the temperature wrong could be a reason.
            I've also seen 4725 as value for the E3D thermistor. You could try verifying that it works by heating up somehow without the chamber heater. (hair dryer)
            • felt342undefined
              felt342 @JoergS5
              @JoergS5
              Well, setting C value to 2000 doesn`t give me an error anymore about Fault in heater 5, and its keeps the rising temperature. But I still can not do the autotune.
              Yeah the thermistor seams works.
              • JoergS5undefined
                JoergS5 @felt342
                @felt342 you get the same autotune error like in the first post? And does the reported temperature value of the thermistor go up?
                • felt342undefined
                  felt342 @JoergS5
                  @JoergS5
                  Yes, this is an error:
                  Autotune canceled because the temperature is not increasing.
                  Temperature goes up, but slowly about 1 degree a minute. This would be fine for me because I am planning to add two heaters there overall of 600, but first I got one and would like to deal it up first, to at least heating without errors. Which we did now (thanks to you!) setting C to 2000, but to perform autotune for real values would be better.
                  • JoergS5undefined
                    JoergS5 @felt342
                    @felt342 Seems to be a timeout. I cannot find the error message in the source at the moment.
                    felt342undefined 1 Reply Last reply Reply Quote 1
                    • felt342undefined
                      felt342 @JoergS5
                      @JoergS5
                      Yeah, I really appreciate your help and digging in! What I am thinking is maybe better to move thermistor to the middle of the chamber, it will probably be the faster response until I have only one heater.
                      JoergS5undefined 2 Replies Last reply Reply Quote 0
                      • JoergS5undefined
                        JoergS5 @felt342
                        @felt342 Now I know why I cannot find it. I search in the 3.1.1 code....
                        => didn't find it in 2.05 code also. Will search and will tell you if I find something.
                        • felt342undefined
                          felt342 @JoergS5
                          @JoergS5
                          Happens 🙂
                          Thank you!
                          • JoergS5undefined
                            JoergS5 @felt342
                            @felt342 I found it in pid.cpp of 2.05 source:
                            // Heating up
                            const bool isBedOrChamberHeater = reprap.GetHeat().IsBedOrChamberHeater(heater);
                            const uint32_t heatingTime = millis() - tuningPhaseStartTime;
                            const float extraTimeAllowed = (isBedOrChamberHeater) ? 60.0 : 30.0;
                            if (heatingTime > (uint32_t)((model.GetDeadTime() + extraTimeAllowed) * SecondsToMillis)
                            && (temperature - tuningStartTemp) < 3.0)
                            platform.Message(GenericMessage, "Auto tune cancelled because temperature is not increasing\n");
                            break;
                            So the error message is called and a break occurs, if the heating time is bigger than dead time + extraTimeAllowed.
                            A low dead time helps in any case.
                            extraTimeAllowed is defined by:
                            so for Chamber it is 60.
                            You could try setting D negative, say -59. Don't know whether it works.
                            You're welcome and I wish you success with the heated chamber!
                            felt342undefined 1 Reply Last reply Reply Quote 2
                            • felt342undefined
                              felt342 @JoergS5
                              @JoergS5
                              That seems working without error!
                              I didn't try negative D, but I set D to 1 and kept C at 2000, waiting for autotune and values 🙂
                              Thanks a lot again!
                              • JoergS5undefined
                                JoergS5 @felt342
                                @felt342 Nice to hear, thank you!
                                See you.
                                • felt342undefined
                                  felt342 @JoergS5
                                  @JoergS5
                                  I must say it`s a nice way of solving the issue, digging the source code, will take it as a tip 🙂
