    All axis stop moving before hitting switches
    939
    • JoergS5undefined
      JoergS5 @Gabell20
      @Gabell20 when I imagine that your G1 H2 runs ok, but G1 H1 stops after a few mm, and you use NC endstop, is it possible that the movement triggers the endstop, by the movement eg? If the G1 H1 stops, does the DWC show the endstop triggered?
      Gabell20undefined 1 Reply Last reply Reply Quote 0
      • Gabell20undefined
        Gabell20 @Phaedrux
        @Phaedrux That is helpful, but i followed along and the problem persists.
        • Gabell20undefined
          Gabell20 @JoergS5
          @JoergS5 that could be it, I noticed that sometimes under acceleration thy show up triggered, I wonder if I can makes the axes accelerate slower but only during homing.
          Phaedruxundefined JoergS5undefined 2 Replies Last reply Reply Quote 0
            Phaedrux Moderator @Gabell20
            @Gabell20 said in All axis stop moving before hitting switches:
            You certainly can. Just add a new acceleration command at the start of the homing file and then change it back to the previous value at the end.
            • JoergS5undefined
              JoergS5 @Gabell20
              @Gabell20 as a first test you can set the F values low while homing.
              Phaedrux you were faster and had the better answer 😉
              • Gabell20undefined
                Gabell20 @Phaedrux
                @Phaedrux @JoergS5 thank you i will try that now. EDIT: that did not work, now I have the same problem but slower lol, I should just purchase new switches
                  What exactly are the switches?
                  • Gabell20undefined
                    Gabell20 @Phaedrux
                    @Phaedrux I don't know, they are just no name switches that came on the machine. i am going to try putting ferrules around them.
                    • Gabell20undefined
                      Gabell20
                      So as it turns out, the wires from the switches were picking up some noise and causing the input to go high. I solved this by using shielded wire for my limit switches and now the machine homes just fine. Thank you @Phaedrux @JoergS5 @fcwilt for your responses.
                        Glad you got it figured out.
