All axis stop moving before hitting switches
@Phaedrux The x switch is on the left and the y switch is mounted to the x carriage and triggers at the back.
Can you go through these steps to test endstop and motors before homing?
https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39#s145
@Gabell20 when I imagine that your G1 H2 runs ok, but G1 H1 stops after a few mm, and you use NC endstop, is it possible that the movement triggers the endstop, by the movement eg? If the G1 H1 stops, does the DWC show the endstop triggered?
@Phaedrux That is helpful, but i followed along and the problem persists.
@JoergS5 that could be it, I noticed that sometimes under acceleration thy show up triggered, I wonder if I can makes the axes accelerate slower but only during homing.
@Gabell20 said in All axis stop moving before hitting switches:
You certainly can. Just add a new acceleration command at the start of the homing file and then change it back to the previous value at the end.
@Gabell20
as a first test you can set the F values low while homing.
Phaedrux you were faster and had the better answer -
What exactly are the switches?
@Phaedrux I don't know, they are just no name switches that came on the machine. i am going to try putting ferrules around them.
Glad you got it figured out.
