Unable to get any stepper motors to work
@Phaedrux said in Unable to get any stepper motors to work:
How are you "turning them on and off"?
By them I meant the 3d printer Turning it off and on by the power I have not plugged/unplugged any motor whilst the board is powered. So just as an example I came this morning and turned the printer on and everything worked as expected. Turned it of and back on, still working. I thought oh its fixed itself off and on again... no longer working.
What are you doing to generate that error?
Homing X / Y or moving the motors individually
Good that you have checked the phase pairs, but how are they actually wired to the Duet?
They are wired using the normal X/Y/Z header on the board I have checked the continuity of the wires (crimps) and all looks as expected.
Please post your full config.g
; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"My Printer" ; set printer name ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z2560.00 E100.00 ; set steps per mm M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X600.00 Y600.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X1000 Y1000 Z1000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X190 Y200 Z210 S0 ; set axis maxima M206 X0 Y0 ; Endstops M574 X1 S1 P"xstop" ; configure active-low endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure active-low endstop for low end on Y via pin ystop ; Z-Probe M307 H3 A-1 C-1 D-1 M574 Z1 S2 M558 P9 C"^zprobe.in" H5 F100 T2000 ; set Z probe type to bltouch and the dive height + speeds M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch ; ; Bed Height Adjustments here ; G31 X-3 Y-23 Z1.76; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment M557 X15:190 Y-15:195 S20 ; define mesh grid ; Heaters M308 S0 P"bed_temp" Y"thermistor" T100000 B4138 ;Sets sensor 0 as a thermistor connected to bed_temp pins M308 S1 P"e0_temp" Y"thermistor" T100000 B4725 C7.06e-8 ;Sets sensor 1 as a thermistor connected to e0_temp pins M950 H0 C"bed_heat" T0 ;Sets heater 0 connected to bed_heater pins with sensor S0 (see above) M950 H1 C"e0_heat" T1 ;Sets heater 1 connected to bed_heater pins with sensor S1 (see above) ;Create Fans M950 F1 C"fan1" ; Setup Fan 1 to be connected to fan 1 header This is the extruder heatsink fan ; Fans M106 P1 T40:50 H1 ; set fan 2 value, turn on at 50% if the CPU temperature reaches 45C, and increase to full speed gradually as the temperature rises to 55C ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R10 S10 ; set initial tool 0 active and standby temperatures to 0C
For the Z axis, are you sure the steps per mm is 4000?
4000 is what I was using before but you are correct it should be closer to 2560. I have a lead screw system and generated 2560 using this tool (https://blog.prusaprinters.org/calculator_3416/) I updated my config.g to reflect this but still no go with the motors.
Also as an aside I spent some time last night using the duet board schematic and checked the continuity of the stepper driver chips themselves and all the pins seem to have continuity so I can rule out a burnt trace but an not familiar with how the stepper drivers work so not sure if there is any way to check if the stepper chip itself if burnt out.
Not that I am an expert in any way, but this sounds to me that the wiring isn't down correctly.
Are you sure you have crimped the male pins correctly and then inserted them the way you should? I once had this problem because I had mistakenly inserted the pins back to front...
@Odin Regarding stepper motor wiring, see here for finding the phase pairs of wires: https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
Then here for how to wire the plug that connects to the Duet: https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Using_the_internal_drivers
Specifically, see this picture:
Though, as it works occasionally, I'd guess it's a continuity problem. Check that the crimps on the end of the motor wires are in the housing the right way round, and that the curly bit on the end (which actually connects to the pin on the board) is not squashed or misshapen, as this will create poor contact onto the pin.
@droftarts Yeah I've checked continuity on all the wires I've even checked continuity by pulling the header up slightly and checking one end of the wire to the bottom of the pin. See image for example, red arrow where multi meter touches. And all wires have continuity so I can see how there can be any continuity issues. And I have checked the phases of all pairs and they read 2.0 ohms on all pairs.
@Odin Those stepper motor crimps look odd; are you sure they're not in the housing the wrong way around? Won't measuring continuity at that point just show the continuity through the stepper driver chip? Check by measuring resistance of pins without stepper motor connected.
Also, looks like you've got a clone Duet board there, with the heatsinks on the stepper driver chips. The heatsinks are quite ineffective, as the stepper driver sinks the heat through the bottom of the chip into the board. You're better off fitting a fan, pointing at the bottom side of the board, to cool it. Where did you buy the board?
@droftarts I actually have two boards, Bought a clone a year ago but didnt have much success with it so went with an original a few months ago plonked the heat sinks on because thats what I had before, bought it from e3d or oozenet I remeber looking at it on both cant remember who i bought from, I can pull up the purchase emails if its important.
And sorry I have been measuring the resistance apologies for the confusion. I do agree the crimps look odd but they are definitely in the correct way -
@Odin has the board ever worked correctly? If so, how was it set up before, and what have you changed?
@droftarts
Yeah it used to work fine, I had an issue with the wifi (unable to connect a few days ago) that turned out to be my wifi router causing the issue. But in the process of doing that I updated from version 3.0 of the firmware to the latest version. I also updated the wifi firmware. I have tried going back to 3.0 with no luck so I came back to the lates version, do you think its work going back to 3.0 again? -
@droftarts
I believe I have fixed the issue. I spoke to my boss who is an electrical engineer by degree and he suggested it might be a lack of voltage/current going to the board. Anyway long story short I have re stripped my V in and hey presto everything is working fine.
Thanks for the help -
@Odin Great, glad it's working. PSU was on my list as one of the next things to investigate! Though your M122 report showed 12V working fine.
Supply voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0, over voltage events: 0, power good: yes
Might be worth changing to 24V if the motors are bigger. Also, it's best to use ferrules on the ends of your VIN wires, for better contact and hold in the screw gates, rather than just bare wires.
