    how to recompile the firmware.bin
    30
    1.3k
    • tony73undefined
      tony73 @koaldesigns
      This post is deleted!
      • tony73undefined
        tony73 @koaldesigns
        @koaldesigns
        Hello everyone ! thanks to dc42 for the last help on the homing of the 4 hidden axis! I managed to recompile the firmware with the help that everyone gave me [rrf 3 lpc on skr v1.3] lately I had little time, the homing on 4 axis hidden by problems !!! maybe some bag on rrf3 lpc? in loading the new line I noticed that it was missing ----; ----- at the end of the line, it made no sense to me !!!!! 4 ASSE.JPG
        now i bought a duet 3 6ch and i don't know how to recompile the firmware to add the hidden 4 axis !! can you help me ? or tell me if I find documentation and where? if I can help you too but I think you know more about me on rrf for duet !!!
        JoergS5undefined dc42undefined 2 Replies Last reply Reply Quote 0
        • JoergS5undefined
          JoergS5 @tony73
            dc42 administrators @tony73
            @tony73 said in how to recompile the firmware.bin:
            See https://github.com/Duet3D/RepRapFirmware/blob/dev/BuildInstructions.md. Development of RRF is currently on the v3.02-dev branch.
            Please upgrade the firmware on your Duet 3 to version 3.1.1 and check all is OK before you try to install your own firmware.
            tony73undefined 1 Reply Last reply Reply Quote 0
            • tony73undefined
              tony73 @dc42
              duet 3 6ch arrived from 1 day I'm connecting it to the scara !! all different from rrf lpc on skr v1.3 ..... m122 tells me this diagnostica duet.JPG
              version 3.01-rc9 !!! I don't know how to update to 3.1.1 is there a guide? and T: -273.1 can I use this 100k thermistor on duet 3 6ch? it went on rrf3 lps + skr v1.3 20200804_223202.jpg
              I have no idea how to update the firmware !!! thank you all !!!
                Download https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip, then upload it to the Duet from the System page of Duet Web Control. More at https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware.
                Yes you can use a 100K thermistor.
                • tony73undefined
                  tony73 @dc42
                  sorry but an example of config.g how to set up a 100k thermistor could you give an example or is there a guide? do I need an expansion card for this thermistor? thank you!!!
                    Phaedrux Moderator @tony73
                    @tony73 https://configtool.reprapfirmware.org/Start
                    Have you seen the config tool yet? You can choose your sensor there and set the values and it will generate a full config set for you to further modify.
                    Thermistors do not require any other hardware.
                    • tony73undefined
                      tony73 @Phaedrux
                      @Phaedrux
                      hello the problem and I don't understand which code to put in the web configurator for that type of thermistor !!! I'm going randomly and nothing changes simplify 3d always marks (T: -273.1)temp sensor.JPG
                      • tony73undefined
                        tony73 @tony73
                        @tony73
                        problem solved now goes !! in the duet 3 6ch there was the firmware 3.01 rc9 I reloaded 3.1.1 maybe that was the problem !!!
                          So you've got it sorted out now?
                          • tony73undefined
                            tony73 @Phaedrux
                            @Phaedrux
                            hi yes I have solved it now with version 3.1.1 the temperature is seen by the thermistor 100k !!! question is it possible to load the rrf 2.05 version on duet 3 6ch? because scara on version rrf 2.05 with G0 x-200 y-200 reversed the arm like the scara helios and could go in the unreachable area !!! but with the rrf version 3.1.1 it doesn't go anymore !!!! thank you !!
                            example scara helios from minute 0: 50 to minute 2: 02 inversion in the unreachable area !!
                            [link text](link url) https://www.youtube.com/watch?v=l_FVnIYND4Y
                              @tony73 No it's not possible to run RRF2 on the Duet 3.
                              I'm not familiar with any changes to scara movements. I suggest you post a new thread with that question.
                              • tony73undefined
                                tony73 @Phaedrux
                                @Phaedrux
                                hi now everything works! also the inversion of the arm to print in the unreachable area as scara helios !! used rrf 3 lpc with skr v1.3 I had this card and I took the opportunity to try rrf3 with scara !! since it works well I bought duet 3 6ch. I would like to recompile the firmware to add this in scara kinematic cpp "" "motorpos [3] = irntf (-1 * (theta + psi) * stepspermm [3]);" "" "" "to have a fourth hidden axis that keeps the extruder always parallel to axis an axis. with rrf 3 lpc and this very detailed guide https://www.jayuk.org/compiling-and-running-reprapfirmware-on-an-skr-1-4-and-other-lp17xx -boards / and a bit of luck I had recompiled the firmware. I am little expert of this thing I would like to recompile with windows the firmware and try it with duet3 6ch. kindly @ dc42 gave me the link to do it
                                https://github.com/Duet3D/RepRapFirmware/blob/dev/BuildInstructions.md but I can't prepare everything, it is possible to have help video link or anything else would be fine !!!
                                  @tony73, if you tell us what you are having trouble with, we will help you.
                                  Can you explain in a little more detail your extension to the SCARA kinematics? If it is generally useful, I could add it as a new kinematic type.
                                  • tony73undefined
                                    tony73 @dc42
                                    thank you for the answer I have to fix the 4th axis on scara cleaner and I will make a video to show you what I would like to do, thanks again !!
