    RepPanel - A DIY alternative to the PanelDue with WiFi support
    Third-party software
    39
    243
    32.4k
    • oliofundefined
      oliof
      I ordered a display and ESP32, but all I get is a white screen. Looking at a serial console, I get the following output:
      rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
      configsip: 0, SPIWP:0xee
      clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
      mode:DIO, clock div:2
      load:0x3fff0018,len:4
      load:0x3fff001c,len:6960
      ho 0 tail 12 room 4
      load:0x40078000,len:14076
      load:0x40080400,len:4352
      entry 0x400806ec
      I (74) boot: Chip Revision: 1
      I (74) boot_comm: chip revision: 1, min. bootloader chip revision: 0
      I (41) boot: ESP-IDF v4.0.1 2nd stage bootloader
      I (41) boot: compile time 13:22:55
      I (41) boot: Enabling RNG early entropy source...
      I (45) boot: SPI Speed      : 40MHz
      I (49) boot: SPI Mode       : DIO
      I (53) boot: SPI Flash Size : 4MB
      I (57) boot: Partition Table:
      I (61) boot: ## Label            Usage          Type ST Offset   Length
      I (68) boot:  0 nvs              WiFi data        01 02 00009000 00006000
      I (76) boot:  1 phy_init         RF data          01 01 0000f000 00001000
      I (83) boot:  2 factory          factory app      00 00 00010000 00200000
      I (91) boot: End of partition table
      I (95) boot_comm: chip revision: 1, min. application chip revision: 0
      I (102) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x80728 (526120) map
      I (299) esp_image: segment 1: paddr=0x00090750 vaddr=0x3ffb0000 size=0x041cc ( 16844) load
      I (306) esp_image: segment 2: paddr=0x00094924 vaddr=0x40080000 size=0x00400 (  1024) load
      I (307) esp_image: segment 3: paddr=0x00094d2c vaddr=0x40080400 size=0x0b2e4 ( 45796) load
      I (334) esp_image: segment 4: paddr=0x000a0018 vaddr=0x400d0018 size=0xc0010 (786448) map
      I (616) esp_image: segment 5: paddr=0x00160030 vaddr=0x4008b6e4 size=0x0c68c ( 50828) load
      I (652) boot: Loaded app from partition at offset 0x10000
      I (652) boot: Disabling RNG early entropy source...
      I (653) cpu_start: Pro cpu up.
      I (656) cpu_start: Application information:
      I (661) cpu_start: Project name:     reppanel_esp32
      I (666) cpu_start: App version:      v1.0.2-dirty
      I (672) cpu_start: Compile time:     Jun 22 2020 18:25:51
      I (678) cpu_start: ELF file SHA256:  8b85d585a6bdd293...
      I (684) cpu_start: ESP-IDF:          v4.0.1
      I (689) cpu_start: Starting app cpu, entry point is 0x40081468
      I (0) cpu_start: App cpu up.
      I (699) heap_init: Initializing. RAM available for dynamic allocation:
      I (706) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
      I (712) heap_init: At 3FFDA238 len 00005DC8 (23 KiB): DRAM
      I (718) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
      I (725) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
      I (731) heap_init: At 40097D70 len 00008290 (32 KiB): IRAM
      I (737) cpu_start: Pro cpu start user code
      I (755) spi_flash: detected chip: generic
      I (756) spi_flash: flash io: dio
      I (756) cpu_start: Starting scheduler on PRO CPU.
      I (0) cpu_start: Starting scheduler on APP CPU.
      I (210) ILI9488: ILI9488 initialization.
      I (510) ILI9488: Enabling backlight.
      I (510) FT6X36: Found touch panel controller
      E (510) FT6X36: Error reading from device: ERROR
      I (510) FT6X36: 	Device ID: 0x00
      I (520) FT6X36: 	Chip ID: 0x00
      I (520) FT6X36: 	Device mode: 0x00
      I (530) FT6X36: 	Firmware ID: 0x00
      I (530) FT6X36: 	Release code: 0x00
      I double checked the wiring twice, but cannot rule out the possibility of miswiring of course, but I also cannot find an error myself.
      • oliofundefined
        oliof
        Reading more of the thread closely again, the display turns on when switching to 5V, but it looks like the touch controller is not being detected correctly.
        • seeul8erundefined
          seeul8er
          @oliof What display? The recommended one? Can you post your wiring please, especially the touch panel stuff.
          • oliofundefined
            oliof
            I got the recommended panel (ER-TFTM035-6). Wiring is as per README.md,
            ESP32 GPIO TFT Pin Color
            13 27 white
            14 24 yellow
            15 23 grey
            22 30 orange
            21 31 brown
            4 21 violet
            2 25 green
            27 29 blue
            Some photos at https://photos.app.goo.gl/gmXPoCFF2FA5Ge2M8
            NB: I can only get the display working with the precompiled binaries, building from source was quite hairy to set up, and all I get is a white screen. I didn't find documentation about how to configure the screen correctly, so I am fumbling around a bit there.
            • oliofundefined
              oliof
              @oliof said in RepPanel - A DIY alternative to the PanelDue with WiFi support:
              It looks like I ordered the screen with the resistive touch panel, so this can't work (FT6x36 is capacitative if I got it right). I will see if I can get my own build up.
              • seeul8erundefined
                seeul8er
                @oliof Was about to suggest that. Your touch panel looks a little different than mine. You can check if J8 on the TFT is closed. Closed means resistive touch.
                You can configure the build by dunning
                idf.py menuconfig
                Check the config options.
                Set the display controller manually to ILI9488. The resistive touch panel is a XPT2046. Configure that one as well. You can choose the pins now. I recommend to go with the ones from the readme
                • oliofundefined
                  oliof
                  The RepPanel Readme or the LVGL Readme?
                  seeul8erundefined 1 Reply Last reply Reply Quote 0
                  • seeul8erundefined
                    seeul8er @oliof
                    @oliof The RepPanel Readme. At least what the TFT is concerned. The touch controller should be SPI as far as I rememember. So you will need to hook it up to the VSPI of the ESP32. The default pins of LVGL should work fine I guess. I updated the repo a few days ago so make sure you use the latest lv_conf.h (copy content from lv_conf_back.h). It fixes random UI freezes.
                    • oliofundefined
                      oliof @seeul8er
                      @seeul8er I checked out master and will try to sort this out over the weekend. Thanks for your help so far!
                      • oliofundefined
                        oliof
                        Unfortunately the weekend didn't have enough time for me to figure things out. Between menuconfig selections not sticking, PIN definitions that aren't part of any readme, and possibly bad cables I can't say I've had any success moving forward. The most timely solution seems to be to order another screen with 3.3v and capacitative touch and trying again with that ...
                        • littlehobbyshopundefined
                          littlehobbyshop
                          I still can't get my SPI touchscreen working. Feeling I'm in over my head. I just don't know how to troubleshoot this stuff.
                          BLV MGN Cube w/Hemera, K8200, Sunlu S8
                          pandaymundefined 1 Reply Last reply Reply Quote 0
                          • seeul8erundefined
                            seeul8er
                            @oliof @littlehobbyshop I don't think that the 5V version is any problem. It can be tricky to get the config right. I'd go and config all pins manually with menuconfig. Maybe use these pins as a hint for a start. Then you just need to wire it accordingly. If the TFT does not have proper docs ... thats a different story.
                            According to the git the XPT2046 driver has not been updated since. So By using the recommended/supported commit ID of LVGL for ESP32 you have the up to date driver
                            • pandaymundefined
                              pandaym @littlehobbyshop
                              @littlehobbyshop said in RepPanel - A DIY alternative to the PanelDue with WiFi support:
                              Sorry man, I completely forgot to answer you. Where are you with this now? I absolutely do not know what I am doing with stuff like this, so I just lucked out getting it working. I can try and figure out some details if you still need it?
                              • oliofundefined
                                oliof
                                @seeul8er thanks for the encouraging words ... I tried those pins as well. The 5V isn't a problem as I can feed it from the 5V pin and it lights up with your firmware (just without any touch support, of course) -- I just decided to stick with 3.3V on the re-order to avoid any surprises.
                                I will need to go back and try to get this going, but I can't even replicate your build by following the instructions. So I must be doing something wrong.
                                • oliofundefined
                                  oliof
                                  Sorry, I am too dense. The pin numbers in the lvgl readme -- are those the one on the TFT, or the one on the ESP32? I constantly seem to take one list for the other and have so far not been able to tell them apart reliably enough to avoid cabling errors it seems.
                                  • seeul8erundefined
                                    seeul8er
                                    @oliof The LVGL docs only specify ESP32 pins. You need to find their counterpart on your TFT
                                    • oliofundefined
                                      oliof
                                      I found the counter parts in the official buydisplay documentation. I know they're right for the TFT part because that lights up with your precompiled binary. Can you maybe share your sdkconfig from the RepPanel_ESP32 directory that you used when building the current latest binary?
                                      • seeul8erundefined
                                        seeul8er
                                        @oliof https://pastebin.ubuntu.com/p/MWBQH2tVSR/
                                        • seeul8erundefined
                                          seeul8er
                                          Release v1.1.0 is out now!
                                          Thanks to contributions from Github user vden some new features are added and old bugs were fixed:
                                          • Change console image button
                                          • Added power button
                                          • Added extruder fan control
                                          • Added light switch (compile-time selection) - default not enabled
                                          • Fix for freezes when using supported hardware (ILI9488)
                                          • pdundefined
                                            pd @seeul8er
                                            @seeul8er I finally had another go with this and have made some progress. I bought a new capacitive screen from buydisplay. Unfortunately I didn't realise it wasn't 3.3v version to start with but it was easy enough to short the JP bridge. I finally managed to get the reppanel to light up. The touch screen seems to work and I managed to find my router. However the one issue I have left is that I am unable to bring up the keyboard from the top right hand corner to change the password. Do you have any idea why this might happen. All the other Icons seem to open OK.
                                            @PCR Any news on the PCB front ?
