    RepPanel - A DIY alternative to the PanelDue with WiFi support
    Third-party software
    39
    243
    30.5k
    • seeul8erundefined
      seeul8er
      @littlehobbyshop Check the color depth in the config file. It should be 16bit. The swap can be set here. Maybe some of the settings in menuconfig broke during the port to your display.
      Also check if it actually is compiled with that option.
      @zapta Yes I did. But they tend to be lower in quality - breaking a lot more often. The API on how to program them (request/display data) is not a good match to the RepRap API. You would need an additional microcontroller to translate the commands as far as I understood. So no real benefit on software nor hardware side.
      zaptaundefined A Former User? littlehobbyshopundefined 3 Replies Last reply Reply Quote 0
      • zaptaundefined
        zapta @seeul8er
        @seeul8er said in RepPanel - A DIY alternative to the PanelDue with WiFi support:
        Since you have an ESP32, it can send the command to the Nextion via a serial port. The commands are simple text such as field.val="123", and the field itself is designed with a GUI editor they provide.
        What you are doing very good. However if you find yourself spending too much time on implementing the GUI that you want, switching to Nextion will speed up the process and will lower the hassle factor of adding new features. That was at least the case with one of my recent projects.
        Anyway, I like your project very much.
        • seeul8erundefined
          seeul8er
          @zapta I totally agree. That option was my favourite for a while. It can get the job done very quickly. However, I also do these projects to up my skills on a specific subject and I do not like to be constrained a lot when it comes to choosing my tools. The UIs produced by the more affordable nextion displays look kind of shitty in my opinion. Maybe due to a reduced feature/cpu power set.
          The project is already in a released state and I am using it for my prints so the hard work is done 🙂
          zaptaundefined 1 Reply Last reply Reply Quote 1
          • zaptaundefined
            zapta @seeul8er
            The project is already in a released state...
            That's what count 😉
            I see that you use the lvgl library, I will check it out for my projects.
              A Former User @seeul8er
              empirical data? genuinely curious if really inferior or if lending temselves to protptyping and rapid development just means they see more and harder use? waiting for my first one to try out with zapta's stepper analyzer and will perhaps borrow it for other one-off type projects.
              • zaptaundefined
                zapta @A Former User
                @bearer said in RepPanel - A DIY alternative to the PanelDue with WiFi support:
                empirical data?
                I have a 3.5" and I don't see why it should be less reliable than similar TFT screens.
                BTW, one cool feature of the Nextion is the ability to run the MCU code against a simulator on your computer, via serial over USB. A little bit tricky but doable. This is how I took the screenshots for the documentation.
                However, the lvgl library is intriguing. I plan to play with it and see how easy it is to design and use GUIs. One thing I would like to try one day is a battery operated Duet monitor with ePaper display for a long battery life, maybe even with a small indoor solar panel. 😉
                • littlehobbyshopundefined
                  littlehobbyshop @seeul8er
                  @seeul8er Thanks for your help. Display is now working, the invert was on and now it's off.
                  Now struggling with the touch, it's an XPT2046 capcitive touch, I'm getting feedback on the monitor so at least the interrupt is wired correctly but no co-ordinates.
                  Looking through some LVGL posts others have had issues with the SPI speed and it looks like there have been updates to the XPT2046 driver in recent months but there's lots that is new here for me and I could be heading down the wrong rabbit hole.
                  Any pointers?
                  BLV MGN Cube w/Hemera, K8200, Sunlu S8
                  • oliofundefined
                    oliof
                    I ordered a display and ESP32, but all I get is a white screen. Looking at a serial console, I get the following output:
                    rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
                    configsip: 0, SPIWP:0xee
                    clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
                    mode:DIO, clock div:2
                    load:0x3fff0018,len:4
                    load:0x3fff001c,len:6960
                    ho 0 tail 12 room 4
                    load:0x40078000,len:14076
                    load:0x40080400,len:4352
                    entry 0x400806ec
                    I (74) boot: Chip Revision: 1
                    I (74) boot_comm: chip revision: 1, min. bootloader chip revision: 0
                    I (41) boot: ESP-IDF v4.0.1 2nd stage bootloader
                    I (41) boot: compile time 13:22:55
                    I (41) boot: Enabling RNG early entropy source...
                    I (45) boot: SPI Speed      : 40MHz
                    I (49) boot: SPI Mode       : DIO
                    I (53) boot: SPI Flash Size : 4MB
                    I (57) boot: Partition Table:
                    I (61) boot: ## Label            Usage          Type ST Offset   Length
                    I (68) boot:  0 nvs              WiFi data        01 02 00009000 00006000
                    I (76) boot:  1 phy_init         RF data          01 01 0000f000 00001000
                    I (83) boot:  2 factory          factory app      00 00 00010000 00200000
                    I (91) boot: End of partition table
                    I (95) boot_comm: chip revision: 1, min. application chip revision: 0
                    I (102) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x80728 (526120) map
                    I (299) esp_image: segment 1: paddr=0x00090750 vaddr=0x3ffb0000 size=0x041cc ( 16844) load
                    I (306) esp_image: segment 2: paddr=0x00094924 vaddr=0x40080000 size=0x00400 (  1024) load
                    I (307) esp_image: segment 3: paddr=0x00094d2c vaddr=0x40080400 size=0x0b2e4 ( 45796) load
                    I (334) esp_image: segment 4: paddr=0x000a0018 vaddr=0x400d0018 size=0xc0010 (786448) map
                    I (616) esp_image: segment 5: paddr=0x00160030 vaddr=0x4008b6e4 size=0x0c68c ( 50828) load
                    I (652) boot: Loaded app from partition at offset 0x10000
                    I (652) boot: Disabling RNG early entropy source...
                    I (653) cpu_start: Pro cpu up.
                    I (656) cpu_start: Application information:
                    I (661) cpu_start: Project name:     reppanel_esp32
                    I (666) cpu_start: App version:      v1.0.2-dirty
                    I (672) cpu_start: Compile time:     Jun 22 2020 18:25:51
                    I (678) cpu_start: ELF file SHA256:  8b85d585a6bdd293...
                    I (684) cpu_start: ESP-IDF:          v4.0.1
                    I (689) cpu_start: Starting app cpu, entry point is 0x40081468
                    I (0) cpu_start: App cpu up.
                    I (699) heap_init: Initializing. RAM available for dynamic allocation:
                    I (706) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
                    I (712) heap_init: At 3FFDA238 len 00005DC8 (23 KiB): DRAM
                    I (718) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
                    I (725) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
                    I (731) heap_init: At 40097D70 len 00008290 (32 KiB): IRAM
                    I (737) cpu_start: Pro cpu start user code
                    I (755) spi_flash: detected chip: generic
                    I (756) spi_flash: flash io: dio
                    I (756) cpu_start: Starting scheduler on PRO CPU.
                    I (0) cpu_start: Starting scheduler on APP CPU.
                    I (210) ILI9488: ILI9488 initialization.
                    I (510) ILI9488: Enabling backlight.
                    I (510) FT6X36: Found touch panel controller
                    E (510) FT6X36: Error reading from device: ERROR
                    I (510) FT6X36: 	Device ID: 0x00
                    I (520) FT6X36: 	Chip ID: 0x00
                    I (520) FT6X36: 	Device mode: 0x00
                    I (530) FT6X36: 	Firmware ID: 0x00
                    I (530) FT6X36: 	Release code: 0x00
                    I double checked the wiring twice, but cannot rule out the possibility of miswiring of course, but I also cannot find an error myself.
                    • oliofundefined
                      oliof
                      Reading more of the thread closely again, the display turns on when switching to 5V, but it looks like the touch controller is not being detected correctly.
                      • seeul8erundefined
                        seeul8er
                        @oliof What display? The recommended one? Can you post your wiring please, especially the touch panel stuff.
                        • oliofundefined
                          oliof
                          I got the recommended panel (ER-TFTM035-6). Wiring is as per README.md,
                          ESP32 GPIO TFT Pin Color
                          13 27 white
                          14 24 yellow
                          15 23 grey
                          22 30 orange
                          21 31 brown
                          4 21 violet
                          2 25 green
                          27 29 blue
                          Some photos at https://photos.app.goo.gl/gmXPoCFF2FA5Ge2M8
                          NB: I can only get the display working with the precompiled binaries, building from source was quite hairy to set up, and all I get is a white screen. I didn't find documentation about how to configure the screen correctly, so I am fumbling around a bit there.
                          • oliofundefined
                            oliof
                            @oliof said in RepPanel - A DIY alternative to the PanelDue with WiFi support:
                            It looks like I ordered the screen with the resistive touch panel, so this can't work (FT6x36 is capacitative if I got it right). I will see if I can get my own build up.
                            • seeul8erundefined
                              seeul8er
                              @oliof Was about to suggest that. Your touch panel looks a little different than mine. You can check if J8 on the TFT is closed. Closed means resistive touch.
                              You can configure the build by dunning
                              idf.py menuconfig
                              Check the config options.
                              Set the display controller manually to ILI9488. The resistive touch panel is a XPT2046. Configure that one as well. You can choose the pins now. I recommend to go with the ones from the readme
                              • oliofundefined
                                oliof
                                The RepPanel Readme or the LVGL Readme?
                                seeul8erundefined 1 Reply Last reply Reply Quote 0
                                • seeul8erundefined
                                  seeul8er @oliof
                                  @oliof The RepPanel Readme. At least what the TFT is concerned. The touch controller should be SPI as far as I rememember. So you will need to hook it up to the VSPI of the ESP32. The default pins of LVGL should work fine I guess. I updated the repo a few days ago so make sure you use the latest lv_conf.h (copy content from lv_conf_back.h). It fixes random UI freezes.
                                  • oliofundefined
                                    oliof @seeul8er
                                    @seeul8er I checked out master and will try to sort this out over the weekend. Thanks for your help so far!
                                    • oliofundefined
                                      oliof
                                      Unfortunately the weekend didn't have enough time for me to figure things out. Between menuconfig selections not sticking, PIN definitions that aren't part of any readme, and possibly bad cables I can't say I've had any success moving forward. The most timely solution seems to be to order another screen with 3.3v and capacitative touch and trying again with that ...
                                        littlehobbyshop
                                        I still can't get my SPI touchscreen working. Feeling I'm in over my head. I just don't know how to troubleshoot this stuff.
                                        pandaymundefined 1 Reply Last reply Reply Quote 0
                                        • seeul8erundefined
                                          seeul8er
                                          @oliof @littlehobbyshop I don't think that the 5V version is any problem. It can be tricky to get the config right. I'd go and config all pins manually with menuconfig. Maybe use these pins as a hint for a start. Then you just need to wire it accordingly. If the TFT does not have proper docs ... thats a different story.
                                          According to the git the XPT2046 driver has not been updated since. So By using the recommended/supported commit ID of LVGL for ESP32 you have the up to date driver
                                          • pandaymundefined
                                            pandaym @littlehobbyshop
                                            @littlehobbyshop said in RepPanel - A DIY alternative to the PanelDue with WiFi support:
                                            Sorry man, I completely forgot to answer you. Where are you with this now? I absolutely do not know what I am doing with stuff like this, so I just lucked out getting it working. I can try and figure out some details if you still need it?
