    Duet 3 v1.0 Fault on SD slot
    618
    • Carloundefined
      Carlo @T3P3Tony
      @T3P3Tony
      Response from YAT
      M552 P192.168.0.25 S1
      ok
      Ethernet running, IP address = 192.168.0.25
      M665
      Error: M665: M665 parameters do not apply to Cartesian kinematics
      ok
      Still can't connect:
      Your Duet rejected the HTTP request: page not found
      Check that the SD card is mounted and has the correct files in its /www folder
      First thing I tried of the usual thing was swap the card with a backup of all the folders
      Before I re-flashed the firmware
        It definitely seems like it's not reading the SD card. Not executing the config.g and can't read the /www folder.
        Can you try sending M22 followed by M21? This should unmount and remount the SD card.
        Also M122 P104, which should try to measure the write speed of the SD card.
        Carloundefined 1 Reply Last reply Reply Quote 0
        • Carloundefined
          Carlo @Phaedrux
          @Phaedrux said in Duet 3 v1.0 Fault on SD slot:
          M22
          Yat output of M21/M22
          M22
          SD card 0 may now be removed
          ok
          M21
          Error: M21: Cannot initialise SD card 0: Card is unusable
          ok
          I've tried a third card which this is output against, weirdly the SD slot is now latching 1st time?.
          M122 P104
          Error: Failed to create folder 0:/gcodes in path 0:/gcodes/test.tst
          Error: M122: Failed to create file
          ok
          Cheers
          C
            When and where was the board purchased? There seems to be a fault in the SD card slot.
            Can you post close up photos of the slot insides and the solder tabs?
            • Carloundefined
              Carlo @Phaedrux
              @Phaedrux
              Yeah Pic to follow
              08/04/20 E3D
              Cheers
              C
                Sorry, is that August 4th or April 8th? Not that it matters, either are within 6 months.
                You can contact E3D and initiate a warranty exchange. Use this thread as authorization. I'm not sure what the current Duet3 stock status is due to the current manufacturing issue with driver diodes, so there may be a delay on replacement. At least in the meantime you can use SBC mode.
                • Carloundefined
                  Carlo @Phaedrux
                  @Phaedrux
                  LoL no I can't use SBC mode it has never worked "under investigation"
                  Best I can get on my phone
                  I can't see anything obvious with the slot or pads?
                  Cheers
                  C
                    Right: https://forum.duet3d.com/topic/16191/duet3-pi-dwc-freezing/31?_=1597246408031
                    All the more reason to swap it out. Something is amiss.
                    • Carloundefined
                      Carlo @Phaedrux
                      @Phaedrux
                      April
                      Thanks as always appreciate your help.
                      C
                        It sounds like FW 3.2 beta1 is arriving shortly (maybe this week), if you still have the board when it lands, perhaps you can test it to see if it has an effect on your other SBC issue.
                        • Carloundefined
                          Carlo @Phaedrux
                          @Phaedrux
                          E3D is out of stock so I'll keep hold until I've tested 3.2.1beta may be helpful.
                          Cheers
                          C
                            Do you happen to have a different pi to test SBC mode with?
                            • Carloundefined
                              Carlo @Phaedrux
                              @Phaedrux
                              Yeah tested it with 3 Pi's 2x 4b and 1 3b+ all exactly the same result with nothing else attached and even tried a new 26 pin cable still the same.
                              • Carloundefined
                                Carlo @Carlo
                                @Carlo
                                The freezing I sorted by not using duetPi and just adding DSF to another distro but thats a far as I could get I could do everything but print ..just went nuts on the purge line or first move
                                actually damaged my print bite sheet rammed the head in to the bed bent the heat break
                                but same files Iv'e printed many time in stand alone
                                  A Former User
                                  i didn't read the whole thread i'll admitt, but if you want to verify the individual parts that make up the connection between the pi and the duet this old-ish thread has a ton of information on where to go digging https://forum.duet3d.com/topic/15551/duet3-pi-dcs-is-unavailable-after-wiring-24v/119?_=1597267914698
                                  (and if not, disregard:)
                                  Carloundefined 1 Reply Last reply Reply Quote 1
                                  • Carloundefined
                                    Carlo @A Former User
                                    @bearer
                                    Thanks bearer I was following the thread at the time I did check continuity and chris did manage to recreate an issue I was having so expect there would be a fix at some point
                                    though at the time it was still freezing my issues which are many but with the duet even weirder and may not have been software or communication between the 2 as it ran as expected until a file was loaded everything else perfect probe, mesh G1's all extruding, heaters maybe a buffer/memory conflict/issue ?
                                      droftarts administrators @Carlo
                                      @Carlo These two pins of your SD card socket do not look well soldered:
                                      Can you take a picture of the socket from an angle across the board, as shown here https://duet3d.dozuki.com/Wiki/SD_Card#Section_SD_Card_Socket
                                      • Carloundefined
                                        Carlo @droftarts
                                        @droftarts
                                        Hi Ian,
                                        Sorry the board went in the mail run today wanted to keep it a while to test 3.2 beta 1
                                        plus it is out of stock...but you get 7 days for return once they issue a returns # and I may have no access to office or workshop due to another possible 2 week lock down in my area
                                        all the pins looked to be well attached and no oxidation all the contacts look ok..bit hard to see inside the slot
                                        Image I took yesterday from a different angle.
                                        Dunno if it is of help.
                                        Cheers
                                        C
