    2 MOTORES INDEPENDENTES NO EIXO Z
    453
    • brunowmktundefined
      brunowmkt
      meu software esta na versão 3.1.1, quando eu sigo os passos de configuração colocados no guia, ele não estão funcionando como deveriam. Qual a forma correta para esses 2 motores em z independentes e com 2 endstop.
      Impressora Core XY, motores Z em Z e E0.
      • oliofundefined
        oliof
        Please let us know which board you are using and share your current config.g
          In 3.1.1 you bind the drivers to the same Z axis, and then in the M574 you define both endstop pins.
          But if you have a z probe, this is a better method.
          https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
            droftarts administrators @brunowmkt
            @brunowmkt You need to define the endstops correctly. See https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors#Section_In_RepRapFirmware_Num_3
              brunowmkt
              Minha placa é uma Duet 2 Wifi ( clone)
              config.g
              M550 P"MY3D V2" ; set printer name
              M669 K1 ; select CoreXY mode
              M552 S1
              M552 P192.168.1.1 ; IP address (0 = use DHCP)
              M554 P192.168.1.1 ; Gateway
              M553 P255.255.255.0 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              M569 P1 S0 ; physical drive 1 goes forwards
              M584 X0 Y1 Z2 E4 ; set drive mapping
              M92 X80.00 Y80.00 Z1600.00 E90.00 ; set steps per mm
              M566 X900.00 Y900.00 Z12.00 E420.00 ; set maximum instantaneous speed changes (mm/min)
              M201 X600.00 Y600.00 Z1600.00 E300.00 ; set accelerations (mm/s^2)
              M906 X850 Y850 Z850 E850 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X300 Y300 Z286 S0 ; set axis maxima
              M574 X1 S1 P"!xstop" ; configure active-high endstop for high end on X via pin xstop
              M574 Y1 S1 P"!ystop" ; configure active-high endstop for high end on Y via pin ystop
              M574 Z2 S1 P"!zstop" ; configure active-high endstop for high end on Z via pin zstop
              M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
              M557 X50:270 Y50:250 S30 ; define mesh grid
              M307 H1 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
              M501
              ;M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency
              ;M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off
              M563 P0 S"Extrusor" D0 H1 F0 ; define tool 0
              T0 ; select first tool
                Phaedrux Moderator @brunowmkt
                @brunowmkt said in 2 MOTORES INDEPENDENTES NO EIXO Z:
                You only have a single driver assigned to the Z axis. The second Z motor needs to be on it's own driver.
                M584 X0 Y1 Z2:3 E4
                Then you must update your endstop definition for Z to include both endstop pin names.
                M574 Z2 S1 P"!zstop+!e0stop"
                  brunowmkt
                  Quanto a ligação dos cabos, seria dessa forma?WhatsApp Image 2020-08-12 at 19.02.38.jpeg
                  Coloquei em os dois em paralelo
                    The Z connector ports are wired in series to a single driver. So you would need to move one of those motors to your free driver and then install the jumpers on the second Z connector.
                    Then the config changes above should work.
                      brunowmkt
                      Então o correto é pegar o segundo que está em série, colocar no drive E0. E fazer os Jumpers no local onde ele foi removido. É isso?
                        yes, that is correct.
                          brunowmkt
                          @Phaedrux said in 2 MOTORES INDEPENDENTES NO EIXO Z:
                          M574 Z2 S1 P "! Zstop +! E0stop"
                          Fiz o procedimento, e subi a configuração pela web, mas parece que quando subo essa alteração, desconfigura e desconecta a rede, e não consigo nem colocar o comando pelo lcd M552 S1 para ativar novamente.
                            Do you have an endstop connected to e0stop?
                            brunowmktundefined 1 Reply Last reply Reply Quote 0
                              brunowmkt @Phaedrux
                              @Phaedrux Yes!
                              1 no E0 e outro no Z.
                              Assim como os cabos dos motores, 1 E0 outro Z.
                                brunowmkt
                                Consegui reverter. Tive que retirar o cartão SD, colocar o config anterior a configuração nova. Inserir novamente o SD, voltou a rede. Depois fui no config.g segui suas orientações, e agora subiu sem erro...
                                  So it is working now?
                                    brunowmkt
                                    Voltou a conectar a impressora na rede wifi....os dois motores ainda não fiz o teste!
                                      brunowmkt
                                      quando subo essa configuração, por algum motivo a placa não conecta mais a rede wifi, alguma explicação para isso?
                                      Tenho que voltar ela para "fabrica" ai sim ela entra na rede.
                                      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Aug 06 2020 17:16:26 GMT-0300 (Horário Padrão de Brasília)
                                      M552 S1
                                      M552 P192.168.1.116 ; IP address (0 = use DHCP)
                                      M584 X0 Y1 Z2: 3 E4 ; set drive mapping
                                      M208 X300 Y300 Z290 S0 ; set axis maxima
                                      M574 Z1 S2 P"!zstop + !e0stop" ; configure active-high endstop for high end on Z via pin zstop
                                      M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
                                      M558 P9 C"^zprobe.in" H5 F420 T6000 ; disable Z probe but set dive height, probe speed and travel speed
                                      G31 P500 X0 Y0 Z1.40 ; set Z probe trigger value, offset and trigger height
                                      M557 X30:250 Y30:250 S30 ; define mesh grid
                                      M501
                                        Remove this section so that it uses DHCP to get an address instead.
                                        You may need to check your router to see what IP address has been given to the Duet, or if you have a PanelDue or USB terminal you can send M552 to check the assigned IP. You can use the router to assign that IP to the Duet via DHCP reservation.
                                          brunowmkt
                                          voltou a funcionar....
                                          Mas tenho outro problema, esta dando esses erros, sempre que faço o Home em z
                                            brunowmkt
                                            além dos dois motores independentes em Z, tenho o Bltouch que também não esta dando certo!
