    Lost connection to Duet3 SBC
    455
    • dhusoloundefined
      dhusolo
      I upgraded from Duet 2 Wifi and DueX2 to a Duet 3 with Raspberry Pi.
      Since I upgraded I will randomly get this error:
      Randomly I get this error and my machine will stop responding to the web interface:
      Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
      Board: Duet 3 MB6HC (MB6HC)
      DSF Version: 3.1.1
      Firmware: RepRapFirmware for Duet 3 MB6HC 3.1.1 (2020-05-19b2)
      Before this happened I was loading the hotend using the interface to extrude the filament. Other times this has happened was when I was running bed leveling.
      Seems like when it does happen it's when I'm selecting a gcode file to print. It doesn't automatically reconnect unless I manually restart the board by hitting stop on the Panel Due or reset on the motherboard.
      8/13/2020, 2:34:16 PM	Connection established
      8/13/2020, 2:33:42 PM	Connection interrupted, attempting to reconnect...
      8/13/2020, 2:33:42 PM	Connection to Duet established
      8/13/2020, 2:33:41 PM	Warning: Firmware reset imminent
      8/13/2020, 2:33:41 PM	Emergency stop, attemping to reconnect...
      8/13/2020, 2:33:41 PM	Connection to Duet established
      8/13/2020, 2:33:29 PM	Warning: Firmware halted
      8/13/2020, 2:33:24 PM	Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
      8/13/2020, 2:33:21 PM	M32 "0:/gcodes/2020 Dial Indicator X Carriage Mount.gcode"
      File 0:/gcodes/2020 Dial Indicator X Carriage Mount.gcode selected for printing
      8/13/2020, 2:33:07 PM	TELNET is disabled
      8/13/2020, 2:33:07 PM	FTP is disabled
      8/13/2020, 2:33:07 PM	HTTP is enabled on port 80
      8/13/2020, 2:33:07 PM	Warning: Controller has been reset
      8/13/2020, 2:33:07 PM	Connection to Duet established
      8/13/2020, 2:33:07 PM	Warning: Lost connection to Duet (Board is not available (no header))
      8/13/2020, 2:33:06 PM	M32 "0:/gcodes/2020 Dial Indicator X Carriage Mount.gcode"
      	M122
      RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
      Board ID: 08DJM-956L2-G43S8-6J9D0-3S46T-9U2LF
      Used output buffers: 1 of 40 (11 max)
      Static ram: 154604
      Dynamic ram: 163392 of which 64 recycled
      Exception stack ram used: 536
      Never used ram: 74620
      Tasks: ETHERNET(blocked,824) NETWORK(ready,1968) HEAT(blocked,1188) CanReceiv(suspended,3820) CanSender(suspended,1420) CanClock(blocked,1436) TMC(blocked,60) MAIN(running,2868) IDLE(ready,76)
      Owned mutexes:
      Last reset 00:10:35 ago, cause: power up
      Last software reset time unknown, reason: User, spinning module LinuxInterface, available RAM 77216 bytes (slot 2)
      Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
      Error status: 0
      MCU temperature: min 33.5, current 37.5, max 37.7
      Supply voltage: min 24.2, current 24.6, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0
      Driver 0: ok, reads 8566, writes 17 timeouts 0, SG min/max 0/191
      Driver 1: ok, reads 8563, writes 21 timeouts 0, SG min/max 0/1000
      Driver 2: ok, reads 8563, writes 21 timeouts 0, SG min/max 0/188
      Driver 3: ok, reads 8564, writes 21 timeouts 0, SG min/max 0/1023
      Driver 4: ok, reads 8564, writes 21 timeouts 0, SG min/max 0/1023
      Driver 5: ok, reads 8565, writes 21 timeouts 0, SG min/max 0/922
      Date/time: 2020-08-13 14:44:20
      Slowest loop: 9.24ms; fastest: 0.13ms
      === Storage ===
      Free file entries: 10
      Hiccups: 0(0), FreeDm: 362, MinFreeDm: 356, MaxWait: 288392ms
      === MainDDARing ===
      Scheduled moves: 393, completed moves: 379, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: 3
      === AuxDDARing ===
      Heater 0 is on, I-accum = 0.0
      Heater 1 is on, I-accum = 0.3
      Segments left: 1
      Movement lock held by null
      HTTP* is ready with "M122" in state(s) 0
      Telnet is idle in state(s) 0
      File* is doing "G1 E-0.100000 F5100" in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon* is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 1.02ms; fastest: 0.01ms
      HTTP sessions: 0 of 8
      - Ethernet -
      State: establishingLink
      Error counts: 0 0 0 0 0
      === Filament sensors ===
      Extruder 0 sensor: ok
      === CAN ===
      Messages sent 2475, longest wait 0ms for type 0
      === Linux interface ===
      State: 0, failed transfers: 0
      Last transfer: 21ms ago
      RX/TX seq numbers: 19446/19447
      SPI underruns 0, overruns 0
      Number of disconnects: 0
      Buffer RX/TX: 3704/1080-4080
      === Duet Control Server ===
      Duet Control Server v3.1.1
      File:
      Buffered code: G1 E-0.1000 F5100
      Buffered code: G92 E0.0000
      Buffered code: G1 X142.453 Y151.100 E0.5814 F866
      Buffered code: G1 X148.447 Y151.100 E0.8227
      Buffered code: G1 X148.532 Y149.363 E0.8927
      Buffered code: G1 X148.626 Y148.732 E0.9183
      Buffered code: G1 X148.781 Y148.114 E0.9440
      Buffered code: G1 X148.996 Y147.513 E0.9697
      Buffered code: G1 X149.268 Y146.936 E0.9953
      Buffered code: G1 X149.596 Y146.389 E1.0210
      Buffered code: G1 X149.976 Y145.877 E1.0467
      Buffered code: G1 X150.404 Y145.404 E1.0723
      Buffered code: G1 X150.877 Y144.976 E1.0980
      Buffered code: G1 X151.389 Y144.596 E1.1237
      Buffered code: G1 X151.936 Y144.268 E1.1493
      Buffered code: G1 X152.513 Y143.996 E1.1750
      Buffered code: G1 X153.114 Y143.781 E1.2007
      Buffered code: G1 X153.732 Y143.626 E1.2263
      Buffered code: G1 X154.363 Y143.532 E1.2520
      Buffered code: G1 X155.000 Y143.501 E1.2777
      Buffered code: G1 X155.637 Y143.532 E1.3033
      Buffered code: G1 X156.268 Y143.626 E1.3290
      Buffered code: G1 X156.886 Y143.781 E1.3547
      Buffered code: G1 X157.487 Y143.996 E1.3803
      Buffered code: G1 X158.064 Y144.268 E1.4060
      Buffered code: G1 X158.611 Y144.596 E1.4317
      Buffered code: G1 X159.123 Y144.976 E1.4573
      Buffered code: G1 X159.596 Y145.404 E1.4830
      Buffered code: G1 X160.024 Y145.877 E1.5087
      Buffered code: G1 X160.404 Y146.389 E1.5343
      Buffered code: G1 X160.732 Y146.936 E1.5600
      Buffered code: G1 X161.004 Y147.513 E1.5857
      ==> 1508 bytes
      Code buffer space: 2576
      Full transfers per second: 18.47
      File /opt/dsf/sd/gcodes/2020 Dial Indicator X Carriage Mount.gcode is selected, processing
        Can you try putting it in debug mode to gather some additional info?
        https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Monitoring_optional
        dhusoloundefined 1 Reply Last reply Reply Quote 0
          Will have to see what @chrishamm has to say about the error.
          baird1faundefined 1 Reply Last reply Reply Quote 0
          • dhusoloundefined
            dhusolo @Phaedrux
            @Phaedrux Thanks. I will try that and see if I can get any more information. it's not consistent. I can go days without it happening.
            • baird1faundefined
              baird1fa @Phaedrux
              @Phaedrux I’m still getting that error too. It usually happens after a print or two when I try to submit a new print. Any update on a fix for this?
              • dhusoloundefined
                dhusolo
                I changed my hostname on the Pi not realizing i had invalid characters. I changed it to The_Demon where capital and "_" are not allowed. when i changed it to the-demon it seems my problems went away. at least it hasn't happened since
                  Phaedrux Moderator @baird1fa
                  @baird1fa Have you started a thread for your issue and provide some debug info as linked above?
                    A Former User @dhusolo
                    @dhusolo said in Lost connection to Duet3 SBC:
                    capitals isn't (shouldn't be?) a problem, it just isn't case sensitve. _ isn't a valid hostname character indeed, more details in link
                    https://en.wikipedia.org/wiki/Hostname#Syntax
                    • dhusoloundefined
                      dhusolo @A Former User
                      @bearer I know with Linux if you don't have the correct case it sometimes it'll say the command is invalid. So to eliminate any issues i made it all lowercase LOL
                        for commands and filenames yes, dns and hostnames doesn't matter. in general you'll have less issues avoiding mixed case and special characters (incl spaces) on linux indeed
                        bearer@rama:~$ dig +noall +answer gatebear.lan
                        gatebear.lan.           0       IN      A       10.10.0.1
                        bearer@rama:~$ dig +noall +answer GATEBEAR.LAN
                        GATEBEAR.LAN.           0       IN      A       10.10.0.1
                        bearer@rama:~$ DIG +noall +answer gatebear.lan
                        DIG: command not found
