    Duet 3 6hc + SBC just stops printing
    1.1k
    • Stephen6309undefined
      Stephen6309
      Starts print. Does the heating, then homes. Starts the skirt, prints fine along X, half way through Y, it stops.
      M122
      RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
      Board ID: 08DJM-956L2-G43S8-6J9FD-3SJ6K-TB0LG
      Used output buffers: 1 of 40 (10 max)
      Static ram: 154604
      Dynamic ram: 162844 of which 44 recycled
      Exception stack ram used: 520
      Never used ram: 75204
      Tasks: NETWORK(ready,1980) HEAT(blocked,1188) CanReceiv(suspended,3820) CanSender(suspended,1420) CanClock(blocked,1436) TMC(blocked,68) MAIN(running,4952) IDLE(ready,76)
      Owned mutexes:
      Last reset 00:02:12 ago, cause: power up
      Last software reset at 2020-08-09 15:17, reason: User, spinning module LinuxInterface, available RAM 75204 bytes (slot 2)
      Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
      Error status: 0
      MCU temperature: min 29.3, current 35.8, max 36.0
      Supply voltage: min 23.9, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
      Driver 0: standstill, reads 56845, writes 17 timeouts 0, SG min/max 0/245
      Driver 1: standstill, reads 56845, writes 17 timeouts 0, SG min/max 0/182
      Driver 2: standstill, reads 56846, writes 17 timeouts 0, SG min/max 0/948
      Driver 3: standstill, reads 56846, writes 17 timeouts 0, SG min/max 0/158
      Driver 4: standstill, reads 56852, writes 11 timeouts 0, SG min/max 0/0
      Driver 5: standstill, reads 56853, writes 11 timeouts 0, SG min/max 0/0
      Date/time: 2020-08-13 12:57:40
      Slowest loop: 4.60ms; fastest: 0.14ms
      === Storage ===
      Free file entries: 10
      Hiccups: 0(0), FreeDm: 267, MinFreeDm: 267, MaxWait: 68886ms
      === MainDDARing ===
      Scheduled moves: 83, completed moves: 38, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: 3
      === AuxDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
      Heater 0 is on, I-accum = 0.2
      Heater 1 is on, I-accum = 0.4
      Segments left: 1
      Movement lock held by null
      HTTP* is ready with "M122" in state(s) 0
      Telnet is idle in state(s) 0
      File* is doing "G1 X242.296997 Y74.782997 E0.070540" in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon* is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 1.01ms; fastest: 0.01ms
      HTTP sessions: 0 of 8
      • Ethernet -
        State: disabled
        Error counts: 0 0 0 0 0
        === CAN ===
        Messages sent 446, longest wait 0ms for type 0
        === Linux interface ===
        State: 0, failed transfers: 0
        Last transfer: 18ms ago
        RX/TX seq numbers: 3524/3525
        SPI underruns 0, overruns 0
        Number of disconnects: 0
        Buffer RX/TX: 3304/744-4072
        === Duet Control Server ===
        Duet Control Server v3.1.1
        File:
        Buffered code: G1 X242.297 Y74.783 E0.07054
        Buffered code: G1 X243.501 Y75.393 E0.06977
        Buffered code: G1 X244.596 Y76.241 E0.07163
        Buffered code: G1 X245.490 Y77.254 E0.06985
        Buffered code: G1 X246.188 Y78.438 E0.07106
        Buffered code: G1 X246.644 Y79.707 E0.06974
        Buffered code: G1 X246.859 Y81.088 E0.07225
        Buffered code: G1 X248.565 Y217.445 E7.05099
        Buffered code: G1 X248.513 Y218.349 E0.04681
        Buffered code: G1 X248.349 Y219.242 E0.04698
        Buffered code: G1 X248.071 Y220.115 E0.04736
        Buffered code: G1 X247.676 Y220.960 E0.04823
        Buffered code: G1 X247.191 Y221.728 E0.04699
        Buffered code: G1 X246.599 Y222.443 E0.04796
        Buffered code: G1 X245.926 Y223.072 E0.04763
        Buffered code: G1 X245.162 Y223.619 E0.04861
        Buffered code: G1 X244.363 Y224.050 E0.04690
        Buffered code: G1 X243.485 Y224.387 E0.04863
        Buffered code: G1 X242.594 Y224.602 E0.04739
        Buffered code: G1 X241.630 Y224.706 E0.05018
        Buffered code: G1 X160.371 Y225.721 E4.20187
        Buffered code: G1 X159.493 Y225.669 E0.04546
        Buffered code: G1 X158.589 Y225.502 E0.04754
        Buffered code: G1 X157.720 Y225.225 E0.04715
        Buffered code: G1 X156.882 Y224.833 E0.04784
        Buffered code: G1 X156.099 Y224.336 E0.04795
        Buffered code: G1 X155.370 Y223.728 E0.04907
        Buffered code: G1 X154.739 Y223.044 E0.04816
        Buffered code: G1 X154.180 Y222.250 E0.05019
        Buffered code: G1 X153.740 Y221.406 E0.04923
        Buffered code: G1 X153.426 Y220.547 E0.04727
        Buffered code: G1 X153.220 Y219.637 E0.04824
        ==> 1500 bytes
        Code buffer space: 2560
        Full transfers per second: 18.55
        File /opt/dsf/sd/gcodes/PETG_BedMountX2.gcode is selected, processing
      Gcode:
      ; generated by PrusaSlicer 2.2.0+win64 on 2020-08-13 at 15:33:15 UTC
      ; external perimeters extrusion width = 0.45mm
      ; perimeters extrusion width = 0.45mm
      ; infill extrusion width = 0.45mm
      ; solid infill extrusion width = 0.45mm
      ; top infill extrusion width = 0.40mm
      ; first layer extrusion width = 0.53mm
      M107
      T0 ; make sure the hotend is selected
      M98 P"/macros/PETGOffset" ; set z probe offset
      M104 S255 ; start heating the hotend
      M190 S80 ; heat the bed and wait
      G28 ; home all axes
      G32 ; bed calibration - RRF
      M109 S255 ; finish heating the hotend
      G1 E5 ; extrude a bit
      ;M117 BedMountX2
      G21 ; set units to millimeters
      G90 ; use absolute coordinates
      M83 ; use relative distances for extrusion
      ; Filament gcode
      G10 ; retract
      G1 Z0.300 F7800.000
      G1 X151.915 Y78.827
      G11 ; unretract
      G1 F1680.000
      G1 X152.423 Y78.021 E0.04923
      G1 X153.034 Y77.277 E0.04980
      G1 X153.737 Y76.611 E0.05009
      G1 X154.535 Y76.028 E0.05108
      G1 X155.365 Y75.570 E0.04902
      G1 X156.286 Y75.204 E0.05128
      G1 X157.222 Y74.964 E0.04995
      G1 X158.206 Y74.842 E0.05127
      G1 X239.645 Y73.820 E4.21121
      G1 X241.069 Y73.953 E0.07396
      G1 X242.466 Y74.354 E0.07513
      G1 X243.743 Y75.002 E0.07403
      G1 X244.909 Y75.903 E0.07621
      G1 X245.860 Y76.980 E0.07429
      G1 X246.601 Y78.234 E0.07531
      G1 X247.087 Y79.583 E0.07413
      G1 X247.318 Y81.048 E0.07669
      G1 X249.025 Y217.441 E7.05286
      G1 X248.971 Y218.401 E0.04976
      G1 X248.796 Y219.352 E0.05000
      G1 X248.501 Y220.280 E0.05034
      G1 X248.083 Y221.176 E0.05112
      G1 X247.567 Y221.993 E0.04998
      G1 X246.943 Y222.749 E0.05066
      G1 X246.236 Y223.412 E0.05013
      G1 X245.432 Y223.994 E0.05133
      G1 X244.584 Y224.455 E0.04989
      G1 X243.665 Y224.813 E0.05100
      G1 X242.719 Y225.048 E0.05040
      G1 X241.711 Y225.163 E0.05248
      G1 X160.368 Y226.181 E4.20623
      G1 X159.434 Y226.126 E0.04838
      G1 X158.479 Y225.949 E0.05022
      G1 X157.555 Y225.655 E0.05013
      G1 X156.664 Y225.239 E0.05087
      G1 X155.831 Y224.711 E0.05098
      G1 X155.054 Y224.063 E0.05232
      G1 X154.382 Y223.335 E0.05120
      G1 X153.789 Y222.493 E0.05329
      G1 X153.319 Y221.593 E0.05246
      G1 X152.985 Y220.680 E0.05030
      G1 X152.765 Y219.713 E0.05128
      G1 X152.672 Y218.735 E0.05075
      G1 X150.975 Y82.561 E7.04160
      G1 X151.027 Y81.616 E0.04891
      G1 X151.203 Y80.652 E0.05064
      G1 X151.499 Y79.721 E0.05051
      G1 X151.890 Y78.881 E0.04790
      G1 X152.307 Y79.076 F7800.000
      G1 F1680.000
      G1 X152.798 Y78.289 E0.04794
      G1 X153.374 Y77.588 E0.04691
      G1 X154.039 Y76.959 E0.04734
      G1 X154.790 Y76.412 E0.04805
      G1 X155.571 Y75.982 E0.04611
      G1 X156.441 Y75.638 E0.04834
      G1 X157.324 Y75.414 E0.04713
      G1 X158.251 Y75.301 E0.04828
      G1 X239.648 Y74.281 E4.20903
      G1 X240.986 Y74.406 E0.06949
        Can you also share your config.g and also try putting it in debug mode to try and capture more info if it happens again?
        https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Monitoring_optional
        Also, did you get any error messages in the console?
        Stephen6309undefined 2 Replies Last reply Reply Quote 0
          Another one for @chrishamm
            Stephen6309 @Phaedrux
            @Phaedrux No errors. Pause button just gets the busy symbol. Also, unable to move any of the axes.
            A few days ago, it worked fine.
            It has a Raspberry Pi 4 4GB.
            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Jul 21 2020 16:28:37 GMT-0400 (Eastern Daylight Time)
            M550 P"raspberrypi" ; set printer name
            M669 K1 ; select CoreXY mode
            M569 P0.0 S0 ; physical drive 0.0 goes backwards
            M569 P0.1 S0 ; physical drive 0.1 goes backwards
            M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
            M92 X80.00 Y80.00 Z800.00 E417.00 ; set steps per mm
            M566 X2500.00 Y2500.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X12000.00 Y12000.00 Z720.00 E7200.00 ; set maximum speeds (mm/min)
            M201 X1000.00 Y1000.00 Z250.00 E250.00 ; set accelerations (mm/s^2)
            M84 S30 ; Set idle timeout
            M208 X400 Y300 Z200 S0 ; set axis maxima
            M574 X1 S1 P"io1.in" ; configure active-high endstop for low end on X via pin io1.in
            M574 Y1 S1 P"io2.in" ; configure active-high endstop for low end on Y via pin io2.in
            M558 P5 C"^io3.in" H5 F120 T6000 B1 ; set Z probe type to switch and the dive height + speeds
            G31 P500 X0 Y-55 Z0 ; set Z probe trigger value, offset and trigger height
            M557 X10:400 Y10:300 S50 ; define mesh grid
            M308 S0 P"temp0" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0
            M308 S1 P"temp1" Y"thermistor" T100000 B4388 ; configure sensor 1 as thermistor on pin temp1
            M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
            M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
            M563 P0 D0 H1 F-1 ; define tool 0
            ;M572 D0 S0.02 ; Pressure advance
            M207 S1.5 F6000 R0 Z0.03 ; firmware retraction
            M376 H5 ; taper bed compensation
            M593 F23 ; cancel ringing at 23Hz
            T0 ; select first tool
              @Phaedrux Attempted to do debug: the first command never finishes.
              I have a Pi 0 W coming tomorrow, so I'll try that.
                I'll be surprised if the Pi 0 W can handle it well, but worth trying I suppose.
                Stephen6309undefined 1 Reply Last reply Reply Quote 0
                  @Phaedrux PI0W didn't work, would not bring up DWC. The Pi0W sure is slow.
                  I upgraded my Duet 2 to 3.11, no problems there.
                  It'll be several days before I can try again. I'll redo the raspberry OS on the Pi4. One thing, 5ghz wifi won't connect, but 2.4ghz does. If the new install doesn't work, I'll find a long enough ethernet cable and try the direct connection.
                    Stephen6309 @Stephen6309
                    Setup the pi4 with the new os, install the duet stuff. Left the pi4 hanging off the side and this morning it started to print. Currently doing the first layer. Ain't computers fun. 🙂
                    Will have wait a few days to see it stays working.
                      Stephen6309
                      Fired up the printer today, so far printed twice with no problem.
                      The OS on the pi4 must have been messed up when I was powering the pi touchscreen via the dotstar connector. The pi4 was showing the low voltage lightning on the screen. Now powering from a 5vdc Meanwell.
                        Stephen6309
                        Today, it's once again dying on the second leg of the skirt.
                        Wrapped the ribbon cable in aluminum foil and grounded it. No change. Disconnected the pi touchscreen.
                        It appears my pi4 stops talking to the duet 3. Emergency stop restores the ability to send gcode.
                        Going to see if the 2020-07-20-DuetPi.img lasts longer. It's current printing. Now, will it keep working over the next few days. Ribbon cable still shielded. Didn't do the updates yet.
                        Next time I'll try the direct connection.
                          A Former User @Stephen6309
                          @Stephen6309 said in Duet 3 6hc + SBC just stops printing:
                          I have been using a Pi-3B+ on my duet 3 Unit with NO issues, maybe its a Pi-4 thing, latest is not always best...
                            Can you provide M122 results after the stop?
                            Or enable the monitoring I linked above?
                              @Phaedrux I will try the debug mode again, if it does it again.
                              Running a similation of a print has worked fine.
                                @Phaedrux 2020-07-20-DuetPi.img smae thing happens the next day. Tempertures still update, can set them. Simulating print time was completed successfully.
                                Emergency stop restores movement.
                                Will try to set debug. Stop the servers, and the first command in PuTTy:
                                sudo /opt/dsf/bin/DuetControlServer -l debug
                                Stops after showing: Updated key volumes
                                VNC Connect will not connect, via IP or CXY-MSv1.local.
                                Used Advanced IP Scanner to verify IP.
                                Connected the touchscreen: desktop screen garbled.
                                The M122 is below.
                                Did the update and upgrade. That took a while. The update let me set the resolution for the touchscreen. Started print via touchscreen. Stopped again.
                                Where is the terminal in 2020-07-20-DuetPi.img?
                                Ther M122 doesn't change, except for the bytes transmitted/received.
                                m122
                                Static ram: 154604
                                Tasks: NETWORK(ready,1972) HEAT(blocked,1188) CanReceiv(suspended,3820) CanSender(suspended,1420) CanClock(blocked,1436) TMC(blocked,68) MAIN(running,4952) IDLE(ready,76)
                                Owned mutexes:
                                Last reset 00:44:07 ago, cause: power up
                                Last software reset at 2020-08-22 15:28, reason: User, spinning module LinuxInterface, available RAM 77008 bytes (slot 3)
                                Error status: 0
                                MCU temperature: min 24.4, current 36.1, max 37.5
                                Supply voltage: min 23.9, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                                12V rail voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0
                                Driver 0: standstill, reads 55236, writes 17 timeouts 0, SG min/max 0/253
                                Driver 1: standstill, reads 55236, writes 17 timeouts 0, SG min/max 0/956
                                Driver 2: standstill, reads 55237, writes 17 timeouts 0, SG min/max 0/1023
                                Driver 3: standstill, reads 55237, writes 17 timeouts 0, SG min/max 0/144
                                Driver 4: standstill, reads 55244, writes 11 timeouts 0, SG min/max 0/0
                                Driver 5: standstill, reads 55244, writes 11 timeouts 0, SG min/max 0/0
                                Date/time: 2020-08-23 14:11:55
                                Slowest loop: 4.95ms; fastest: 0.14ms
                                === Storage ===
                                Hiccups: 0(0), FreeDm: 281, MinFreeDm: 281, MaxWait: 454488ms
                                === MainDDARing ===
                                Scheduled moves: 81, completed moves: 45, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: 3
                                === AuxDDARing ===
                                Heater 0 is on, I-accum = 0.3
                                Heater 1 is on, I-accum = 0.3
                                Segments left: 1
                                File* is doing "G1 X217.895996 Y52.673000 E4.612160" in state(s) 0
                                === Network ===
                                Slowest loop: 0.82ms; fastest: 0.01ms
                                • Ethernet -
                                  State: disabled
                                  === CAN ===
                                  Messages sent 10514, longest wait 0ms for type 0
                                  Last transfer: 17ms ago
                                  RX/TX seq numbers: 18425/18426
                                  Buffer RX/TX: 3548/984-4076
                                  File:
                                  Buffered code: G1 X217.896 Y52.673 E4.61216
                                  Buffered code: G1 X218.739 Y51.836 E0.06141
                                  Buffered code: G1 X220.019 Y50.790 E0.08550
                                  Buffered code: G1 X221.406 Y49.902 E0.08514
                                  Buffered code: G1 X222.512 Y49.340 E0.06417
                                  Buffered code: G1 X224.040 Y48.744 E0.08481
                                  Buffered code: G1 X225.634 Y48.327 E0.08515
                                  Buffered code: G1 X226.859 Y48.133 E0.06416
                                  Buffered code: G1 X228.509 Y48.038 E0.08547
                                  Buffered code: G1 X230.116 Y48.130 E0.08319
                                  Buffered code: G1 X231.213 Y48.294 E0.05735
                                  Buffered code: G1 X232.297 Y48.546 E0.05755
                                  Buffered code: G1 X233.827 Y49.053 E0.08332
                                  Buffered code: G1 X234.844 Y49.503 E0.05755
                                  Buffered code: G1 X236.252 Y50.288 E0.08331
                                  Buffered code: G1 X237.164 Y50.919 E0.05735
                                  Buffered code: G1 X238.389 Y51.943 E0.08255
                                  Buffered code: G1 X239.180 Y52.747 E0.05833
                                  Buffered code: G1 X240.199 Y53.992 E0.08319
                                  Buffered code: G1 X240.819 Y54.920 E0.05768
                                  Buffered code: G1 X241.581 Y56.323 E0.08255
                                  Buffered code: G1 X242.018 Y57.355 E0.05800
                                  Buffered code: G1 X242.506 Y58.882 E0.08287
                                  Buffered code: G1 X242.741 Y59.966 E0.05735
                                  Buffered code: G1 X242.931 Y61.507 E0.08028
                                  Buffered code: G1 X242.966 Y237.499 E9.09980
                                  Buffered code: G1 X242.873 Y239.115 E0.08374
                                  Buffered code: G1 X242.703 Y240.243 E0.05898
                                  Buffered code: G1 X242.306 Y241.812 E0.08365
                                  Buffered code: G1 X241.890 Y242.968 E0.06355
                                  Buffered code: G1 X241.238 Y244.352 E0.07911
                                  Buffered code: G1 X240.607 Y245.411 E0.06371
                                  ==> 1512 bytes
                                  Code buffer space: 2572
                                  Full transfers per second: 1.32
                                  File /opt/dsf/sd/gcodes/PETG_Spacer3mm20mmX8.gcode is selected, processing
                                  Stephen6309
                                  Pulled the 5vdc to Pi jumper and tried powering the pi4 from a wall wart, no change.
                                    Stephen6309
                                    Tried a new setup on a different card. Can't connect to the Pi4, DWC or PuTTy doesn't connect. Put other card back, it connects, but won't keep printing. does show a low voltage on the screen just before to showes DWC. Tried the Pi0W again with the 2020-07-20-DuetPi.img, didn't connect.
                                    Next: direct connection, it works.
                                    Looks like my Pi4 is flakey, need to get another one. Will know for sure in a few days.
                                      @Stephen6309 So far, the direct mode is still working.
                                        Stephen6309
                                        Update: Got a new Pi4 from Adafruit with an acrylic case. Installed DuetPi OS with GUI and a fanshim. So far it works and seem to be a bit more responsive. Printed a magic fish just fine.
                                        In a few days, we'll see if it stays working
                                        Stephen6309undefined 1 Reply Last reply Reply Quote 1
                                          It's still printing.
                                            Stephen6309
                                            Spoke too soon. It's doing it again. Going to ask for a new ribbon cable.
