Fan Problem - Blown Board?
I have a Duet 2 Wifi in an existing printer, Predator2. Just installed a Duet 2 Wfi in another printer, Predator1. Both printers are the same deltas apart from fan makes, but all 4020s.
Predator2 working. Dozuki instructions on fans very confusing, so copied everything from Predator2.duet 2 wifi
V2.05.01
2 wire fans (common + ve on all fans from heatsink fan header)
2x24v part cooling parallel
1x24v heatsink fanProblem: Predator1 does not respond to webGUI fan sliders.
boot up - heatsink fan spins briefly
try web GUI sliders when cold - nothing
over 45C heatsink fan spins (although seems well under full speed) - use sliders no speed variance - part cooling nothing
web GUI no change using sliders on any fan
After messing with above:
(- ve on part cooling wire maybe loose - did have them on at one point though)
did blow fuse with part cooling FAN0 on trying to check voltage - something else blown?
M106 into GUI - no effectconfig.g
M106 P0 S0 I0 F500 H-1
M106 P1 S1 I0 F500 H1 T45Any ideas or help welcome.
Regards
Gary -
@Gary said in Fan Problem - Blown Board?:
Problem: P1 does not respond to webGUI fan sliders.
Printer P1 or fan config P1?
Sorry my names for the printers Predator1 and 2. Predator1, Predator1, is the problem printer. (edited above to remove references to P1 and changed to Predator1)
Post your full config please.
Are you saying you blew the fan fuse? It's possible that the MOSFETs for the fans were also damaged. You'd need a good close up look at them, they are by the fan ports.
See the image here: https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers#Section_Fan_mosfet
Just remembered that the fan speed sliders never worked, which is why I thought something was wrong. Hotend fan still working. I think there was something wrong before I blew the fuse as above.
I'm still commissioning the machine, so most of the config is from my other machine. Main problem is that the WebGUI fan speed sliders have no effect (also M106 no effect). Hotend fan kicks in at 45C. Fan seems slow, but it's hard to tell. (firmware 2.05.1)
; generated by RepRapFirmware Configuration Tool v2 on Tue Feb 26 2019 21:31:01 GMT+0000 (Greenwich Mean Time)
;made by Gary 22/07/2020; General preferences
G21 ; Work in millimetres
M552 S1 ; connect to WiFi; Delta Settings
M665 L440.49 R227 H456.747 B185.0 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 A0.00 B0.00 ; Put your endstop adjustments here, or let auto calibration find them; Network
M550 P"P1" ; Set machine name
M551 P""
M552 P192.168.0.16 ; Set password
;M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P0 S0 ; Drive 0 goes forwards
M569 P1 S0 ; Drive 1 goes forwards
M569 P2 S0 ; Drive 2 goes forwards
M569 P3 S0 ; Drive 3 goes forwards (BMG extruder clone - MT-1703HSM168RE 0.9deg step 180917 1.68A)
M350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation (20teeth pulley) "E3D MT-1704HSM168RE 0.9deg step 190102, 400 steps/rev 1.68A"
M92 X160.00 Y160.00 Z160.00 E837 ; Set steps per mm
M566 X1000 Y1000 Z1000 E1000 ; Set maximum instantaneous speed changes (mm/min)
M203 X12000.00 Y12000.00 Z12000.00 E10000 ; Set maximum speeds (mm/min)
M201 X3000.00 Y3000.00 Z3000.00 E3000.00 ; Set accelerations (mm/s^2)
M906 X1000.00 Y1000.00 Z1000.00 E1100.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
;M906 X1344.00 Y1344.00 Z1344.00 E1344.00 I30 ; Set motor currents (mA) and motor idle factor in per cent (reduced to 80% of max Amps)
;M84 S30 ; Set idle timeout
M84 S600; Retraction
M207 S4.0 F5000 R-0.025 T2500 Z0.5 ; Firmware retraction; Axis Limits
M208 Z0 S1 ; Set minimum Z; Endstops
M574 X2 Y2 Z2 S1 ; Set active high endstops; Z-Probe (standard AC Predator microswitch probe, clips just under nozzle)
M558 P4 H25 F120 T6000 ; Set Z probe type to switch(P4) and the dive height + speeds
G31 P500 X0 Y0 z17.225 ;Z22.446 ;17.249 ;.656 ; Set Z probe trigger value, offset and trigger height
M557 R115 S20
;G29 S1 ; Load the heightmap; Heaters
M307 H0 A137.8 C533.3 D1.5 V24.3 B0 ; Disable bang-bang mode for the bed heater and set PWM limit
M305 P0 T100000 B4300 C0 R4700 ; Set thermistor + ADC parameters for heater 0
M305 P1 T100000 B4300 C0 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S240 ; Set temperature limit for heater 1 to 240C; Fans
M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools for p0
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic saving after power loss is not enabled
M572 D0 S0.1 ; Pressure Advance
;M591 D0 P2 C4 S1 ; Activate filament sensor
M404 N1.75 ; Set for print monitor
M592 D0 A0.07772 B-0.00029 ; Nonlinear extrusion. Set parameters for extruder drive 0; Miscellaneous
T0 ;select tool 0 gary added
M501 ; Load saved parameters from non-volatile memory -
Your tool doesn't have a fan assigned to it. Add F0
Are you saying that M106 P0 S1 doesn't turn on the fan connected to fan0 port?
If your hotend fan seems slower that makes me wonder if you have the fan voltage select jumper pin set to 5v instead of Vin or something.
@Phaedrux M563 P0 D0 H1 Same as my other machine which works and dozuki says you can omit for tool0. Added F0 and rebooted - no change. M106 P0 S1 does not turn the fan on. Vin jumper selected as in working machine. I cannot figure it out. Thanks for trying to help. Strange that heatsink fan starts when over 45C, but WebGUI hs no effect on it either below or above 45C.
Does the MOSFET look blown?
@Phaedrux MOSFETs look okay. Do you know if the WebGUI fan speed slider issues the M106 command?
Yes the slider is the same as sensing m106.
@Phaedrux I've taken molex off fan header connections and attached direct to 24v. All fans/wiring okay. My mistake about speed - it's just a quiet - ish fan.
That's maybe something if m106 and the sliders have no effect?
send M106 P1 H-1 and heatsink fan comes on. No change to WebGUI controls
M106 P1 S0 fan stops (WebGUI speed sliders - no effect)
M106 P1 S1 fan on (WebGUI speed sliders - no effect)
M106 P0 S1 no change to part cooling fan - still off -
@Phaedrux Tried the following:
fan0 Molex into fan2 header
config.g changes
;Fans
; M106 P0 S0 I0 F500 H-1 ; Disable FAN0: Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P2 S0 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off;Tools for p0
; M563 P0 D0 H1 F0
M563 P0 D0 H1 F2It seems to work!
It sounds like the Fan0 mosfet got damaged when the fuse was blown.
@Phaedrux Yeah. Nothing physically obvious. What also confused me was the 2 Fans on the WebGUI. I didn't notice that one was Tool Fan and the other Fan 0, which are the same. I thought one was the heatsink fan, which thinking about it now wouldn't make sense as it's not speed controllable. Thanks for your help.
You can post a close up high res well lit clear photo of the fan port area so we can see if there is any damage.
@Phaedrux Hope it's clear enough.
Getting:
ErrorInput file contains unsupported image format
Can you try putting the photo on dropbox or google drive or something like that?
Nothing really visible, but it may still have failed.
