    Fan Problem - Blown Board?
    Duet Web Control
    1.2k
      Phaedrux Moderator @Gary
      @Gary said in Fan Problem - Blown Board?:
      M563 P0 D0 H1 ; Define tool 0
      Your tool doesn't have a fan assigned to it. Add F0
      Are you saying that M106 P0 S1 doesn't turn on the fan connected to fan0 port?
      If your hotend fan seems slower that makes me wonder if you have the fan voltage select jumper pin set to 5v instead of Vin or something.
      Garyundefined 1 Reply Last reply Reply Quote 0
      • Garyundefined
        Gary @Phaedrux
        @Phaedrux M563 P0 D0 H1 Same as my other machine which works and dozuki says you can omit for tool0. Added F0 and rebooted - no change. M106 P0 S1 does not turn the fan on. Vin jumper selected as in working machine. I cannot figure it out. Thanks for trying to help. Strange that heatsink fan starts when over 45C, but WebGUI hs no effect on it either below or above 45C.
          Does the MOSFET look blown?
          • Garyundefined
            Gary @Phaedrux
            @Phaedrux MOSFETs look okay. Do you know if the WebGUI fan speed slider issues the M106 command?
              Yes the slider is the same as sensing m106.
              Garyundefined 2 Replies Last reply Reply Quote 0
              • Garyundefined
                Gary @Phaedrux
                @Phaedrux I've taken molex off fan header connections and attached direct to 24v. All fans/wiring okay. My mistake about speed - it's just a quiet - ish fan.
                That's maybe something if m106 and the sliders have no effect?
                send M106 P1 H-1 and heatsink fan comes on. No change to WebGUI controls
                M106 P1 S0 fan stops (WebGUI speed sliders - no effect)
                M106 P1 S1 fan on (WebGUI speed sliders - no effect)
                M106 P0 S1 no change to part cooling fan - still off
                • Garyundefined
                  Gary @Phaedrux
                  @Phaedrux Tried the following:
                  fan0 Molex into fan2 header
                  config.g changes
                  ;Fans
                  ; M106 P0 S0 I0 F500 H-1 ; Disable FAN0: Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                  M106 P2 S0 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
                  ;Tools for p0
                  ; M563 P0 D0 H1 F0
                  M563 P0 D0 H1 F2
                  It seems to work!
                    It sounds like the Fan0 mosfet got damaged when the fuse was blown.
                    • Garyundefined
                      Gary @Phaedrux
                      @Phaedrux Yeah. Nothing physically obvious. What also confused me was the 2 Fans on the WebGUI. I didn't notice that one was Tool Fan and the other Fan 0, which are the same. I thought one was the heatsink fan, which thinking about it now wouldn't make sense as it's not speed controllable. Thanks for your help.
                        You can post a close up high res well lit clear photo of the fan port area so we can see if there is any damage.
                        • Garyundefined
                          Gary @Phaedrux
                          @Phaedrux Hope it's clear enough.
                          ![0_1597559615949_20200816_072939.jpg](Uploading 100%)
                          Getting:
                          Error
                          Input file contains unsupported image format
                            Can you try putting the photo on dropbox or google drive or something like that?
                            • Garyundefined
                              Gary @Phaedrux
                                Nothing really visible, but it may still have failed.
                                  A Former User
                                  if you have a multimeter putting "multimeter mosfet" into google will show you how to test the mosfet properly its a little involved so doesn't make sense to repeat what google can tell you
                                  • Garyundefined
                                    Gary @A Former User
                                    @bearer Thanks I will check as I have now visually blown P3. Also P1 stopped working. So all 3 now not working! Is there anywhere in the UK that I can send the board to get it fixed?
                                    (I bought pre-wired connectors, but I didn't see that although the connectors were compatible at the hot end the polarity was reversed to the fan. I wouldn't have thought that switching the fan polarity would have blown anything - the fans would just spin the wrong way).
                                      dc42 administrators @Gary
                                      Send me a PM, I can replace the mosfets.
                                      (I bought pre-wired connectors, but I didn't see that although compatible at the hot end the polarity was reversed to the fan. I wouldn't have thought that switching the fan polarity would have blown anything - the fans would just spin the wrong way).
                                      Unfortunately, brushless DC fans don't work like that. A few types just don't work when connected the wrong way round, but most of them present a short-circuit.
                                      Garyundefined 1 Reply Last reply Reply Quote 1
                                      • Garyundefined
                                        Gary @dc42
                                        @dc42 Thanks for the info about the polarity. That now makes sense! I bought some PMV20XNER MOSFETs, but the size of them is way beyond my capability.
                                        I tried to PM you, but I get then message "This user has restricted their chat messages. They must follow you before you can chat with them"
                                          Try now.
