    Unable to home z axis
    IR Height Sensor
    4.8k
    • Kayjayundefined
      Kayjay @droftarts
      @droftarts
      My apologies for one massive error, the files I had installed on my SD were the ones as I explained earlier but I'm afraid those are the only ones I can find. I do have lots of copies -1, -2 etc etc but they appear to be the same so I've made a new set using the config tool and your figures which you noted down for me in your previous post, thank you so much, it was an enormous help. I'll now post the config.g I have on my SD and I would be very grateful if you would cast an eye over it and confirm it's ok. If it is I will then proceed with the next set of test that yourself and Phaedrux has listed for me. Again, I must thank you both for the time you have spent working with my problem, it's only because of that effort that hbas stopped me giving up and buying an Anet 8 Plus which seems good value for money and given that Thomas S has given it the thumbs up I was tempted but I prefer to work with my Bigbox and solve the problem. One main reason is the excellent Duet, there is nothing to touch it on the market ( it's just so darned complicated for novices like me 🙂 ) Thanks again Ian, I do appreciate everything you've done for me, you really are a star !
      G90                                     ; send absolute coordinates...
      M83                                     ; ...but relative extruder moves
      M550 P"Bigbox1"                         ; set printer name
      M552 P0.0.0.0 S1                        ; enable network and acquire dynamic address via DHCP
      M586 P0 S1                              ; enable HTTP
      M586 P1 S0                              ; disable FTP
      M586 P2 S0                              ; disable Telnet
      M569 P0 S1                              ; physical drive 0 goes forwards
      M569 P1 S1                              ; physical drive 1 goes forwards
      M569 P2 S0                              ; physical drive 2 goes backwards
      M569 P3 S1                              ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                        ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                 ; configure microstepping with interpolation
      M92 X160.00 Y360.00 Z400.00 E304.00     ; set steps per mm
      M566 X480.00 Y480.00 Z24.00 E300.00     ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z360.00 E1500.00 ; set maximum speeds (mm/min)
      M201 X750.00 Y750.00 Z100.00 E5000.00     ; set accelerations (mm/s^2)
      M906 X1300 Y1300 Z1300 E800 I30            ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                 ; Set idle timeout
      M208 X0 Y0 Z0 S1                        ; set axis minima
      M208 X300 Y200 Z200 S0                  ; set axis maxima
      M574 X1 Y1 S1                           ; set active high endstops
      M574 Z1 S2                              ; set endstops controlled by probe
      M558 P1 H5 F120 T6000                   ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X0 Y25 Z2.5                    ; set Z probe trigger value, offset and trigger height
      M557 X15:215 Y15:195 S20                ; define mesh grid
      M305 P0 T100000 B4138 R4700             ; set thermistor + ADC parameters for heater 0
      M143 H0 S120                            ; set temperature limit for heater 0 to 120C
      M305 P1 T100000 B4138 R4700             ; set thermistor + ADC parameters for heater 1
      M143 H1 S320                            ; set temperature limit for heater 1 to 320C
      M106 P0 S0 I0 F500 H-1                  ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1 T45               ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 F0                        ; define tool 0
      G10 P0 X0 Y0 Z0                         ; set tool 0 axis offsets
      G10 P0 R0 S0                            ; set initial tool 0 active and standby temperatures to 0C
      Just a point, I know that there are a few commands that have to be either before or after others. Am I ok regarding this respect, is everything in the right order?
      Thanks again
      Keith
        droftarts administrators
        @Kayjay looks mostly okay, and in the correct order. You have chosen the default thermistor settings, and a couple of other minor differences. Compare it to the config in your post earlier, here: https://forum.duet3d.com/post/171309
        Kayjayundefined 1 Reply Last reply Reply Quote 0
        • Kayjayundefined
          Kayjay @droftarts
          @droftarts
          Ah yes, I forgot to set the PT100 didn't I. My Usual dummy self !
          Here are the M122 results :
          10:47:25 AMM122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet Ethernet 1.02 or later
          Board ID: 08DDM-9FAMU-JW4S4-6JKD4-3SJ6M-92Y7V
          Used output buffers: 3 of 24 (15 max)
          Static ram: 25712
          Dynamic ram: 92764 of which 0 recycled
          Exception stack ram used: 272
          Never used ram: 12324
          Tasks: NETWORK(ready,628) HEAT(blocked,1232) MAIN(running,3736) IDLE(ready,160)
          Owned mutexes:
          Last reset 00:43:40 ago, cause: software
          Last software reset at 2020-08-15 10:03, reason: User, spinning module GCodes, available RAM 12324 bytes (slot 1)
          Error status: 0
          Free file entries: 10
          MCU temperature: min 44.2, current 44.5, max 44.6
          Supply voltage: min 24.5, current 24.6, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
          Date/time: 2020-08-15 10:47:18
          Slowest loop: 1.11ms; fastest: 0.07ms
          Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
          === DDARing ===
          Segments left: 0
          Movement lock held by null
          http is idle in state(s) 0
          telnet is idle in state(s) 0
          file is idle in state(s) 0
          serial is idle in state(s) 0
          aux is idle in state(s) 0
          daemon is idle in state(s) 0
          queue is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 4.49ms; fastest: 0.06ms
          HTTP sessions: 1 of 8
          Interface state 5, link 100Mbps full duplex
          10:47:17 AMM122
          Static ram: 25712
          Owned mutexes: ToolList(NETWORK)
          Last reset 00:43:32 ago, cause: software
          Error status: 0
          MCU temperature: min 44.2, current 44.4, max 44.6
          Date/time: 2020-08-15 10:47:11
          === DDARing ===
          Segments left: 0
          === Network ===
          Slowest loop: 4.48ms; fastest: 0.06ms
          10:46:18 AMM122
          Static ram: 25712
          Last reset 00:42:33 ago, cause: software
          Error status: 0
          MCU temperature: min 44.3, current 44.5, max 44.6
          Date/time: 2020-08-15 10:46:12
          === DDARing ===
          Segments left: 0
          === Network ===
          Slowest loop: 4.47ms; fastest: 0.06ms
          10:46:13 AMM122
          10:46:00 AMM122
          Used output buffers: 1 of 24 (10 max)
          Static ram: 25712
          Owned mutexes:
          Last reset 00:42:15 ago, cause: software
          Error status: 0
          MCU temperature: min 42.8, current 44.4, max 44.7
          Date/time: 2020-08-15 10:45:53
          Slowest loop: 3.61ms; fastest: 0.06ms
          === DDARing ===
          Segments left: 0
          === Network ===
          Slowest loop: 9.40ms; fastest: 0.02ms
          10:04:02 AMConnection established!
          10:03:55 AMDisconnected.
          9:58:19 AMConnection established!
          9:58:19 AMPage Load complete!
          • Kayjayundefined
            Kayjay
            These are the results for the M98
            11:12:17 AMM98 P"config.g"
            HTTP is enabled on port 80
            FTP is disabled
            TELNET is disabled
              droftarts administrators @Kayjay
              @Kayjay I’d say have a go with the Z movement tests, once you have your config.g sorted.
              You can tell from the M122 response if the Z axis has stalled. Try moving Z, and if it doesn’t, send M122 and look at this line in the response:
              The bit after SG min/max will have numbers. If the max is 1023, the axis has tried to move, but stalled. It could be that the Z axis is binding, particularly as you have two motors on Z.
              • Kayjayundefined
                Kayjay
                I sorted the config.g, the PT100 wasn't configured to use the daughterboard, just a slip of the mind .
                This is the result of all the drivers from M122. I tried to move z then did the M122
                Driver 0: standstill, SG min/max 0/234
                Driver 1: standstill, SG min/max 0/295
                I assume this indicates that Z isn't trying to move. I can't get it to move using any Go or G1 command but it will move in homeall and homez.
                I have made a video of Homeall.z which shows x and y homing, then x moving to 150 and y to 100 which is the centre of the bed. After that nothing happens, as though G30 is being ignored completely.
                I'm busy trying to upload the video to youtube but at the moment I'm not able to, I do have an account but I have never uploaded anything to my account so it's a matter of another learning curve.
                I am getting very close to giving in as nothing seems to works. I'd even send it to Josh at E3D but they no longer handle the Bigbox so I don't think they'll do a repair.To be honest I'd be happy to pay anyone who can make this darned thing work otherwise its the Anet A8 Plus. I am getting very frustrated even with the great help you've all given me. I feel there is an electronic problem rather than software. I'm just at a loss, you guys have been so amazing and helpful, your hints and tips have been amazing too but I just don't know what to do any more. For one I'm a novice so to speak, I don't understand half of the speak, I'd just be happy with a working printer that I can throw a sliced prog in and let it print me a nice result.
                  It sounds like the Z axis isn't stalling, so that's a good sign.\
                  The reason it won't move the Z axis with G0 or G1 is probably because it hasn't been homed yet, So unless you've sent a G92 Z10 to force the Z axis into a homed position, it won't move.
                  @Phaedrux said in Unable to home z axis:
                  https://wiki.e3d-online.com/BigBox_Version_Overview
                  I think this may be an issue of Z axis steps per mm being incorrect.
                  The marlin config for the Bigbox pro hydrid is 1600 steps per mm on Z. You've got it configured as 400.
                  #define DEFAULT_AXIS_STEPS_PER_UNIT {160,180,1600,417.5} // default steps per unit for Titan BigBox
                  So try changing your M92 Z400 to M92 Z1600 and try to homeall again.
                    @Kayjay Have you been able to post the video? Also, I’ve sent you a private message. Click the speech balloon icon at the top of the page to see messages.
                    • Kayjayundefined
                      Kayjay @Phaedrux
                      @Phaedrux
                      Well, there is a small improvement, the bed now rises in the steps I have set in homeall, I have to keep homing but by hte time it reaches the top it crashes or rather would if I don't do an emergency stop. I've also tried holding my finger under the probe whilst it is homing , the LED lights but it doesn't stop, neither does it stop as it lights just before I hit emergency stop.
                      ; homeall.g
                      ; called to home all axes
                      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Aug 15 2020 09:44:17 GMT+0100 (British Summer Time)
                      G1 H2 Z-25 F6000          ; lift Z relative to current position
                      G1 H1 X-305 Y-205 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                      G1 H2 X5 Y5 F6000       ; go back a few mm
                      G1 H1 X-305 Y-205 F360  ; move slowly to X and Y axis endstops once more (second pass)
                      G90                     ; absolute positioning
                      G1 X150 Y100 F6000       ; go to first bed probe point and home Z
                      G30                     ; home Z by probing the bed
                      ;G91                    ; relative positioning
                      ;G1 Z5 F100             ; lift Z relative to current position
                      ;G90                          ; absolute positioning
                      The Z-25 setting is temporary to enable a quicker bed rise so I don't have to hit homeall a hundred and umpteen times. Obviously I stop it crashing before it reaches it's limit
                      droftartsundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                        @Kayjay does the probe still give sensible numbers in DWC, ie 0 when not triggered, 500+ when triggered?
                        Can you post some pictures of the Duet and wiring?
                        Kayjayundefined 2 Replies Last reply Reply Quote 0
                        • Kayjayundefined
                          Kayjay @droftarts
                          @droftarts Yes, the probe numbers are still correct, 0 and 537. I've also managed to upload the video I made yesterday, I suppose it's out of date now as it shows that the bed doesn't rise after homeall but I thought I'd post it for completion. Here's the link, you may have to wait until 4pm for it to show, it's the earliest it would allow me to show it.
                          https://youtu.be/Xtr5PvMXFso
                          I'll also take some stills of the Duet wiring. Is it possible to post pics on here or should I put them somewhere else?
                          • Kayjayundefined
                            Kayjay
                            • Kayjayundefined
                              Kayjay
                              @Kayjay said in Unable to home z axis:
                              • Kayjayundefined
                                Kayjay
                                • Kayjayundefined
                                  Kayjay
                                  • Kayjayundefined
                                    Kayjay @droftarts
                                    @droftarts
                                    Are the pictures above ok or would you like some more specific areas, particular clear shots of wires and plugs, not a prob if you require them.
                                    Keith
                                      Phaedrux Moderator @Kayjay
                                      Do you mean that G30 seems to be working now, or is it the G1 H2 Z-25 that is moving it up? That command will move it until it crashes, the probe won't stop it.
                                      Can you get a better photo of the probe wiring and the ir probe itself?
                                      • Kayjayundefined
                                        Kayjay @Phaedrux
                                        @Phaedrux It's a bit of a mixture, if I comment out G30 the bed will rise whenever Homeall is activated, the head centres to the middle of the bed and the bed will rise the amount I have set in Homeall but if G30 is active ie not commented out then things return to as they were, all stops at the point G30 should home. I have also included two stills of the probe plug on the Duet and the plug on the probe itself.
                                          What happens if you move the print head to the center and then issue G30 in the console?
                                          Also, can you send G31 and report the result?
                                          • Kayjayundefined
                                            Kayjay
                                            Just an intersting item I found in my bits and bobs box. I bought it years ago, it was poorly printed as you can see but the circuit design and construction was good. It's a filament diameter sensor to detect variances in filament thickness and as such the flow through the hotend could be adjusted. I know Marlin was adjusted to enable this to be used and I used it on my old Prusa Mendel to good use but it meant me changing from Repetier (which was far superior at the time and may still be) to Marlin. If anyone wants to make one it can be found on Thingverse.
                                            http://www.thingiverse.com/thing:454584
