    Extruder motor gets crazy.
    Firmware installation
    295
    • duttiundefined
      dutti @droftarts
      @droftarts
      Different code, same problem 😕
      Any other options to solve the problem?
      thanks to all
      Richard
      ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 23 2020 22:36:44 GMT+0200 (Mitteleuropäische Sommerzeit)
      M550 P"Duet 3" ; set printer name
      M569 P0.4 S1 ; physical drive 0.4 goes forwards
      M569 P0.5 S1 ; physical drive 0.5 goes forwards
      M569 P1.0 S0 ; physical drive 1.0 goes forwards
      M569 P1.1 S1 ; physical drive 1.1 goes forwards
      M569 P1.2 S1 ; physical drive 1.2 goes forwards
      M584 X0.0 Y0.1 Z0.2:0.3:0.4:0.5 E1.0:1.1:1.2 ; set drive mapping
      M350 X16 Y16 Z16 E16:16:16 I1 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z1600.00 E92.70:92.70:92.70 ; set steps per mm ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00:120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00:1200.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z40.00 E250.00:250.00:250.00 ; set accelerations (mm/s^2)
      M906 X1200 Y1200 Z3000 E1200:1200:1200 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X700 Y700 Z800 S0 ; set axis maxima
      M574 X2 S1 P"!io3.in" ; configure active-high endstop for high end on X via pin !io3.in
      M574 Y2 S1 P"!io0.in" ; configure active-high endstop for high end on Y via pin !io0.in
      M558 P9 C"io4.in" H10 F200 T1800 ; set Z probe type to bltouch and the dive height + speeds
      M950 S0 C"io4.out" ; create servo pin 0 for BLTouch
      G31 P25 X-20 Y-20 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X10:600 Y10:600 S200 ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      M307 H1 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
      M143 H0 S90 ; set temperature limit for heater 0 to 90C
      M308 S1 P"temp1" Y"thermistor" T100000 B4138                                     ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1                                                               ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 B0 S1.00        ; disable bang-bang mode for heater  and set PWM limit
      M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
      M106 P0 S0.8 H-1  ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"out7" Q500 ; create fan 1 on pin out7 and set its frequency
      M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
      M950 F2 C"out8" Q500 ; create fan 2 on pin out8 and set its frequency
      M106 P2 S1 H T45 ; set fan 2 value. Thermostatic control is turned on
      M671 X-19.5:99.5:99.5:-19.5 Y110:110:540:540 S2.5
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power
        Have you calibrated the extruder yet?
        duttiundefined 1 Reply Last reply Reply Quote 0
        • duttiundefined
          dutti @Phaedrux
          @Phaedrux
          No, but the seller told me that I need 92.7 steps per mm. This amount I had on a different machine and it was working perfectly.
          I have the same motor on the x + y axis and there are not hot when working.
          I think the motor still gets 3a instead of 1.2a.
          thanks a lot
          Richard
            If you send M906 by itself, what does it report?
            You should try this extruder calibration to see if your steps per mm is correct.
            https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s165
            If it's extruding the right amount of filament, but the amount of filament during a print is still wrong, then there is something wrong with the slicer config.
            • duttiundefined
              dutti @Phaedrux
              @Phaedrux
              @Phaedrux said in Extruder motor gets crazy.:
              M906
              M906
              Motor current (mA) - X:1200, Y:1200, Z:3000, E:1200:1200:1200, idle factor 30%
              I think it´s correct.
              I just extruded manually on the dwc to test the new config.g.
              I´ll try to print.... but the motor was much faster than excepted. It´s like freaking out!
              • duttiundefined
                dutti @dutti
                This post is deleted!
                • duttiundefined
                  dutti @dutti
                  @barbarossa-cologne
                  and in this situation it´s not possible to calibrate anyways. because it´s just not possible to extrude something.
                  The extruder just makes one step and jumps that step back. Problem with extruding to fast is solved!!
                  Extruder isn´t hot anymore! 🙂 --> solved
                  Maybe the motor is broken, now.
                  I´ll check that!
                  KR
                  Richard
                  Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
                    Phaedrux Moderator @dutti
                    @barbarossa-cologne said in Extruder motor gets crazy.:
                    I guess that could be possible if it was getting 3A for a long time when it's rated for 1.2A.
                      dc42 administrators @dutti
                      I´ll check that!
                      Measure the resistance of each phase. Compare them with each other and with the datasheet.
                      • duttiundefined
                        dutti @Phaedrux
                        @Phaedrux
                        Motor wasn´t working correct after having 3a instead of 1.2a.
                        Thanks
                        Problem solved!
