    Duet 2 Wifi + BLtouch issues on Ender 5 pro
    3.9k
    • alxndrundefined
      alxndr @peter247
      @peter247 how would i move to heater 7? is it just changing the values? or physically moving the pins connected to the board?
      also, i settled for this: M557 X35:185 Y35:185 S50
      that way i probe 4 points and not 5. I think that should work like it did on marlin.
      so if m401 and m402 work, do i still need to move to heater 7? and if so, id need some guidance or direction if possible please.
      peter247undefined 1 Reply Last reply Reply Quote 0
      • peter247undefined
        peter247 @alxndr
        @alxndr o.k first little point are you on version 2 or 3 , because the code is different .
        I can see your config file is for version 3 , but are you running version 3 of the firmware ?.
        If M401 and M402 works sit back and relax your bltouch is fully working .
        If you need to change to a different heater , YES , lots config changes and hardware changes.
        Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
        alxndrundefined 1 Reply Last reply Reply Quote 0
        • alxndrundefined
          alxndr @peter247
          @peter247 i upgraded the firmware to latest which is 3.1.1 i believe!
          and if i remember correctly, m401 and m402 were working fine but ill test again tonight. but i do remember manually entering those commands to deploy and retract.
          • peter247undefined
            peter247 @alxndr
            @alxndr O.K you have a ender 5 pro , So how or should I say where does to home , Right ( X max ) , Back ( Y max ) , Z Bltouch ?
            If so I can more or less give you my homing macros , but mine is for a 350x350 bed , so the hitting the centre of the bed will need to be changed.
            • alxndrundefined
              alxndr @peter247
              @peter247 thats correct...mine homes at the back (y max) right (x max) when im facing the front. as for the z, its the end stop right now...bltouch doesnt deploy yet cause i didnt get to change it yet as im at work.
              • peter247undefined
                peter247 @alxndr
                @alxndr
                change 355 to 225 , 5mm more than the max
                ; homex.g
                ; called to home the X axis
                ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sat Jun 20 2020 16:28:00 GMT+0100 (British Summer Time)
                G91               ; relative positioning
                G1 H2 Z5 F6000    ; lift Z relative to current position
                G1 H1 X 355 F3000 ; move quickly to X axis endstop and stop there (first pass)
                ;G1 H2 X-5 F6000    ; go back a few mm
                ;G1 H1 X 355 F240  ; move slowly to X axis endstop once more (second pass)
                G1 H2 Z-5 F6000   ; lower Z again
                G90               ; absolute positioning
                ; homey.g
                ; called to home the Y axis
                G1 H1 Y 355 F3000 ; move quickly to Y axis endstop and stop there (first pass)
                ;G1 H2 Y-5 F6000    ; go back a few mm
                ;G1 H1 Y355 F240  ; move slowly to Y axis endstop once more (second pass)
                ; homez.g
                ; called to home the Z axis
                ;G28 XY
                ;G1 H2 Z-5 F6000   ; lower Z again
                G1 X220 Y175 F4000 ; Move probe to middle of bed
                G30
                note is the same as homez.g
                ; homeall.g
                ; called to home all axes
                ;G28 XY
                G30
                X220 is the centre of my bed , 350 / 2 + 45 offset
                • alxndrundefined
                  alxndr @peter247
                  @peter247 wow thank you!
                  a few questions....my x and y both have a value of 220....why do the values need to be 5mm more? is it so that it backs up afterwards? like the amount of distance to press into the switch and back out?
                  also, for the z im a little confused...how do i find the value for that?
                  and lastly, the bed is x220 and y220 so would the center be 110? the nozzle seems to be perfectly in the center at x110 y110....and the z at that point id have to figure out i guess?
                  • peter247undefined
                    peter247
                    you don't need to set the value that high , so 220 or less will do , it is maximum travel before it stops and say I'm homed without hitting the switch.
                    no 110 is not the centre of the bed for the bltouch it is the centre of the bed for the nozzle , so the centre is 110 plus the offset of 45mm X ( 155mm for the bltouch ) and 110 + 4mm Y so just go at half .
                    Hope that makes sense to you now ?.
                    how do you find the off set ?
                    first set the value in G31 Z to zero , Home and see if it home but is off the bed , then slowly increase the value of Z until it hits the bed when Z say Z say 0.0mm
                    MAKE SURE IT WILL HOME FIRST , THAT IS THE IMPORTANT PART.
                    o.k my system all the motor are backward ? , make sure to motor direction is correct too.
                    • alxndrundefined
                      alxndr @peter247
                      @peter247 first part makes sense! thank you. What did you mean by "just go at half?'
                      X be 155 and Y would be 114 because of the offset of the bltouch?
                      as for the z offset, how would i set the value of G31 Z to 0? just input the line G31 Z0 ?
                      and then you say to check if it homes. But im pretty sure it pushes up onto my nozzle if i home z. I dont get the last part when you say "...then slowly increase the value of Z until it hits the bed when Z say Z say 0.0mm"
                      My motors seem correct....not sure if they are backwards...but they home at the back right which is what it was with the stock motherboard...
                      • peter247undefined
                        peter247 @alxndr
                        @alxndr My motors seem correct....
                        Two wrongs can make a right , eg if you are homing in the wrong
                        direction and your motor are in the wrong direction it will look right.
                        Look at your config file :
                        M558 P9 C"^zprobe.in" H5 F100 T2000 ;
                        M950 S0 C"exp.heater3" ; define GPIO/Servo pin index
                        M557 X0:220 Y0:220 S25 ; define mesh grid
                        G31 X-45 Y-4 Z3.737 ; <------------- just change this to Z0 ---------
                        M307 H3 A-1 C-1 D-1 ;
                        What I'm saying is get it to home with crashing into the bed , then you can find the true offset .
                        Have you changed the homing files ? and does m401 and m402 work ?
                        • alxndrundefined
                          alxndr @peter247
                          @peter247 i havent had a chance to test m401 and m402 yet as im still at work. ill do those tests after work and get back to you! thanks so much for helping. im learning and progressing so much! ill reply back with my test results asap!
                          • peter247undefined
                            peter247
                            Going to bed soon I`m in the UK , so bits to check.
                            (1) See if m401 and m402 works
                            (2) You need to change all the homing files
                            (3) press home x then press the x micro-switch does it stop , PANIC if not
                            (4) press home y then press the y micro-switch does it stop, PANIC if not
                            (5) press home all and see which way the head goes now to home ( with your finger on the emergency stop), I think your motors direction is wrong x , y , z ) it is the M569 commands in the config.g
                            (6) get it to home all axis correct without the nozzle hitting to bed.
                            • alxndrundefined
                              alxndr @peter247
                              @peter247 so homing z works fine now. ive got it all set up with the homey homex and homez and homeall....now im having a stupid little annoying issue......220 isnt the bed size? the bed size is actually 235!! wtf...creality advertises it as 220 but when i measure it, its actually 235!! do i need to change everything now?
                              peter247undefined droftartsundefined 2 Replies Last reply Reply Quote 0
                                Phaedrux Moderator @alxndr
                                @alxndr said in Duet 2 Wifi + BLtouch issues on Ender 5 pro:
                                M208 X220 Y220 Z300 S0 ; set axis maxima
                                You can change your axis limits with the M208 commands.
                                This may mean you need to change your M557 grid spacing a bit.
                                You also need to make sure that the homing moves in your homing files are long enough to hit the endstops if they are at the opposite end already.
                                You might find this series of guides helpful
                                https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
                                • peter247undefined
                                  peter247 @alxndr
                                  @alxndr the bed size is actually 235!! wtf
                                  The 220 x 220 is the printable size !!
                                  A cr10s pro says 300x300 , but the bed is 320x310
                                  a ender 5 plus says 350x350 , but the bed is 370x377
                                  if you print at 0:0 you can't print on fresh air so the bed is always bigger than the printable area.
                                  When it X and Y homes is that under the bed , just check that all the printable area is under the bed .
                                    droftarts administrators @alxndr
                                    @alxndr I tend to use the P parameter rather than the S parameter with M557. This sets the number of points to probe, rather than the spacing between them. Then, if you change the probe area, it still probes the same number of points, evenly spaced, without having to calculate the probe spacing yourself. It's also quicker to change if you want to change the number of probe points in the mesh. So:
                                    M557 X35:185 Y35:185 S50 (which probes X and Y at 35, 85, 135 and 185, so 4 points in each axis for a total of 16 points)
                                    becomes:
                                    M557 X35:185 Y35:185 P4
                                    To increase or decrease the number of probe points, you just change the P parameter.
                                    See https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M557_Set_Z_probe_point_or_define_probing_grid
                                    alxndrundefined 1 Reply Last reply Reply Quote 1
                                    • alxndrundefined
                                      alxndr @peter247
                                      @peter247 i just dont get something...if the physical bed is 235x235, why are my axis limits 220x220? I mean...dont i base my bed center off of the actual bed size? nowhere in the gcode shows the ACTUAL bed size of 235x235. Am i doing something wrong? because if i go from left to right, it goes from 0 to 220...
                                      as for everything else, homing works and the bltouch works 🙂 deploys and retracts properly! m401 and m402 confirmed working!!
                                      what are the next steps? do i have to remove the lines for my z endstop?
                                      • alxndrundefined
                                        alxndr @droftarts
                                        @droftarts this is great to know! thank you!
                                          @alxndr When you home X, then move to X0, is the nozzle on the edge of the bed? If it's over the bed, there will be some of the bed you cannot use. Same at the other end of the X axis, and for Y minimum and maximum. You can always adjust M208 to increase the axis limits, so long as the nozzle can physically reach the position.
                                          If you home X, and X=0 is off the bed, you need to know how far it is to the edge of the bed. For example, if you jog the X axis 10mm for the nozzle to be over the bed, then you would set M208 X-10 S1. This tells the firmware where the bed is in relation to the X endstop. Then move the X to the far side of the bed (with X0 on the edge of the bed) to see the full X axis limit; this might be X240, but the nozzle is off the bed on the other side, but is on the edge at X235. So set M208 X235 S0. Repeat for the Y axis. This should give you the maximum printable area.
                                          Use of M208 is explained more fully here: https://duet3d.dozuki.com/Wiki/Centering_the_bed_or_setting_the_bed_origin
                                          Edit: when you are testing where the limits are, you may need to go beyond the current M208 limits. Send M564 S0 H0, which will allow moves outside the print volume and before axes are homed. Use carefully!
                                          • alxndrundefined
                                            alxndr @droftarts
                                            @droftarts this is something ill have to check once i get home from work. I'm in EST time zone (Canada). So i'll only get to check this later today. thanks for the explanation. I dont fully understand but i do kind of understand lol i just dont see how the printer knows that the bed is 235 but only 220 is used. But ill test as you recommended and try to understand. I think it would be easier if i get to see it for myself.
                                            peter247undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
