Macros on PanelDue's Control Screen
PanelDue
913
    oozeBot
    We are using a Duet 3 / RPi combo connected to a PanelDue. Macros were not working with this combo until recently and I've just reported a seperate issue, so this is potentially related - or I just don't know what I'm doing..
    I've create a macro named 01_test.g. From what I've read, the top 4 macros should be visible in the circled area in the pic, but I can't get anything to show up there. Am I doing something wrong, or is this another issue with Macros stored on the RPi's SD card? Thanks
    undefined undefined 2 Replies Last reply 21 Aug 2020, 21:49 Reply Quote 0
      droftarts administrators @oozeBot
      @oozeBot Are you running the latest 1.24 firmware on the PanelDue? The current installed version is shown on the 'setup' screen. v1.24 has "improved compatibility with Duet 3 boards running with an attached Single Board Computer" which may resolve the issue.
      https://github.com/Duet3D/PanelDueFirmware/releases/tag/1.24
      See here for updating firmware: https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
      undefined 1 Reply Last reply 21 Aug 2020, 21:59 Reply Quote 0
        Kolbi
        @oozeBot, what I have found is that if you just created a macro in DWC it won't show up on the panel until it is refreshed, which can be done by going into 'Macro' and then back to 'Control' screen.
        undefined 1 Reply Last reply 21 Aug 2020, 22:02 Reply Quote 0
          oozeBot @droftarts
          @droftarts yes, I am running v1.24. Sorry I failed to mention that..
            oozeBot @Kolbi
            @Kolbi I’ve rebooted several times.. are you running a Duet 3 connected to an Raspberry Pi with macros on the RPi’s SD card?
            undefined 1 Reply Last reply 21 Aug 2020, 22:06 Reply Quote 0
              Kolbi @oozeBot
              @oozeBot No, I am not - I'm running Duet2WiFi, but the panel is its own serial attached appendage and I believe it would function the same.
              Do the macros show up on the macro's screen?
              undefined 1 Reply Last reply 21 Aug 2020, 22:12 Reply Quote 0
                oozeBot @Kolbi
                @Kolbi thanks for clarifying. It should act the same, but there were issues with it that 1.24 addressed when accessing the RPi’s SD card, but I think this wasn’t caught.. yes, the macros do show up on the macro tab.
                undefined 1 Reply Last reply 21 Aug 2020, 22:19 Reply Quote 0
                  Kolbi @oozeBot
                  @oozeBot Ok, understand all. From a curiosity standpoint, have you performed a power-down then power-on and seen if that yields a change?
                  undefined 1 Reply Last reply 21 Aug 2020, 22:22 Reply Quote 0
                    oozeBot @Kolbi
                    @Kolbi yes - nothing shows after a reboot. The Macros tab lists them all, but nothing on the Control tab. @droftarts - would you please ask @dc42 and/or @chrishamm to review this? Thanks
                    undefined 1 Reply Last reply 21 Aug 2020, 22:27 Reply Quote 0
                      Kolbi @oozeBot
                      @oozeBot rgr all. Just was curious if scenario changed with software reboot vice shutdown via power and the full power on - it happens to a lot of systems that we deal with. Best of luck 👍
                        Phaedrux Moderator @oozeBot
                        @oozeBot said in Macros on PanelDue's Control Screen:
                        Where did you read that? I wasn't aware macros would show up there now, just in the top right corner. Maybe I missed that.
                        undefined 1 Reply Last reply 22 Aug 2020, 16:59 Reply Quote 0
                          oozeBot @Phaedrux
                          @Phaedrux well, maybe that is my misunderstanding of where they'd show up as I just assumed it was in that empty row.. where are they supposed to show up? Is it the empty area in the top right corner? If so, my mistake.. but they still aren't showing up at all. If this is just my misunderstanding, is there any guidance you can give me?
                            They would show here on the control tab.
                            undefined 1 Reply Last reply 22 Aug 2020, 20:36 Reply Quote 0
                              oozeBot @Phaedrux
                              @Phaedrux thanks for the photo. What I am experiencing on a Duet 3/RPi is that no macros are showing up on the Control tab of the PanelDue. My suspicion is this is a defect that has gone unreported until now. It was just recently that the defect was corrected that allowed Macros on the RPi's SD card to even show up on the PanelDue (I'm the one that reported it). This feels like a similar scenario. Would you please ask @dc42 and/or @chrishamm to review this?
                              undefined 1 Reply Last reply 22 Aug 2020, 20:48 Reply Quote 0
                                OwenD @oozeBot
                                @oozeBot
                                I don't run a pi, so can't be sure if it's the same, but on the D2, macros will only show on that screen if they are placed in the root of the macros folder.
                                Anything in a sub folder can only be accessed from the macros page.
                                undefined 1 Reply Last reply 22 Aug 2020, 20:50 Reply Quote 1
                                  oozeBot @OwenD
                                  @OwenD said in Macros on PanelDue's Control Screen:
                                  @oozeBot
                                  Good call out - the test scripts are in the root Macros folder. Thanks
                                    How are they named?
                                    Can you test in standalone mode to isolate the problem to the rpi side?
                                    undefined 2 Replies Last reply 22 Aug 2020, 22:28 Reply Quote 0
                                      oozeBot @Phaedrux
                                      @Phaedrux there is currently just a single macro in the root macros folder named 01_test.g. It shows up as test.g on the Macros tab, but does not show up at all on the Control tab.
                                      While I understand what you are asking, I do not have any experience running the Duet 3 in stand-alone mode. I suspect it would work as I’ve found several other things that seemed to only break when running from the RPi’s SD card- specifically, no macros displayed on the macros tab before 3.1.1..
                                        oozeBot @Phaedrux
                                        @Phaedrux - is there a better way to report defects than forum posts? Github? Thanks
                                          I've brought it to attention, but it is the weekend after all.
                                          undefined 1 Reply Last reply 23 Aug 2020, 17:16 Reply Quote 0
                                          9 out of 24
