    Duet 3 Output Not Working
    722
    • beachtecundefined
      beachtec
      Using a Duet 3 in a new installation... My set-up works ok, sort of. I have 5 identical motors in the X/Y/ 3Z format. I can not get one on the motors to move. If I swap the motor leads out into an alternate stepper position, The motor works fine. The motor I plug into the nonworking slot (stepper 5) stops working. I ran a M115 and a M122... it looks ok. Any motor I move to the 0 position stops working but works in other positions. This thing is brand new!
      My Duet
      M115 b22
      Status
      Idle
      Mode: FFF
      Tool Position
      X
      1.0
      Y
      1.0
      Z
      0.00
      U
      0.0
      Extruder Drives
      Drive 0
      0.0
      Drive 1
      0.0
      Speeds
      Requested Speed
      0 mm/s
      Top Speed
      0 mm/s
      Sensors
      Vin
      24.0 V
      V12
      12.0 V
      MCU Temperature
      38.8 C
      Fan RPM
      0
      Z-Probe
      1000
       Tools
       Extra
       Control All
      Tool	Heater	Current	Active	Standby
      Tool 1
      T1 - Load Filament	n/a	n/a
      210
      160
      Bed	Bed
      off	81.8 C
      0
      0
      Temperature Chart
      M122
      8/21/2020, 11:34:36 PM	M122
      RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (standalone mode)
      Board ID: 08DJM-956L2-G43S8-6J1D8-3SJ6M-9B0GG
      Used output buffers: 2 of 40 (13 max)
      Static ram: 154604
      Dynamic ram: 162836 of which 100 recycled
      Exception stack ram used: 320
      Never used ram: 75356
      Tasks: NETWORK(ready,356) ETHERNET(blocked,436) HEAT(blocked,1112) CanReceiv(suspended,3404) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,204) MAIN(running,4528) IDLE(ready,76)
      Owned mutexes:
      Last reset 00:12:36 ago, cause: power up
      Last software reset at 2020-08-21 22:41, reason: User, spinning module GCodes, available RAM 75404 bytes (slot 3)
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
      Error status: 0
      MCU temperature: min 20.0, current 38.5, max 38.7
      Supply voltage: min 23.8, current 23.9, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
      Driver 0: ok, reads 53874, writes 19 timeouts 0, SG min/max 0/0
      Driver 1: ok, reads 53875, writes 19 timeouts 0, SG min/max 0/0
      Driver 2: ok, reads 53880, writes 14 timeouts 0, SG min/max 0/0
      Driver 3: ok, reads 53881, writes 14 timeouts 0, SG min/max 0/0
      Driver 4: ok, reads 53881, writes 14 timeouts 0, SG min/max 0/0
      Driver 5: ok, reads 53882, writes 14 timeouts 0, SG min/max 0/0
      Date/time: 2020-08-21 23:34:35
      Slowest loop: 10.78ms; fastest: 0.21ms
      === Storage ===
      Free file entries: 9
      SD card longest read time 4.5ms, write time 27.5ms, max retries 0
      Hiccups: 0(0), FreeDm: 375, MinFreeDm: 373, MaxWait: 54848ms
      === MainDDARing ===
      Scheduled moves: 2, completed moves: 2, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 43.73ms; fastest: 0.03ms
      HTTP sessions: 1 of 8
      - Ethernet -
      State: active
      Error counts: 0 0 0 0 0
      === CAN ===
      Messages sent 3035, longest wait 2ms for type 6011
      === Linux interface ===
      State: 0, failed transfers: 0
      Last transfer: 756063ms ago
      RX/TX seq numbers: 0/1
      SPI underruns 0, overruns 0
      Number of disconnects: 0
      Buffer RX/TX: 0/0-0
      8/21/2020, 11:27:25 PM	M115 b22
      Board TOOL1LC firmware 3.1.0 (2020-05-15b1)
      8/21/2020, 11:27:13 PM	M115
      FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2020-05-19b2
      Config.g
      ; Jubilee CoreXY ToolChanging Printer - Config File
      ; This file intended for Duet 3 hardware, main board plus two expansion boards (or, later, four tool boards)
      ; As of 10/14/2019 INCOMPLETE AND ONLY PARTIALLY TESTED.  See the discord for more info.
      ; Name and Identification
      ; Printer name is now set on the R Pi.
      ; Networking
      M552 S1 Enable Network					; Access point is configured manaually
      M586 P0 S1 								; Enable Http
      M586 P1 S0 								; Disable FTP
      M86 P2 S0 								; Disable Telnet
      ; Debugging
      M111 S0                                 ; Debug off
      M929 P"eventlog.txt" S1                 ; Start logging to file eventlog.txt
      ; General Preferences
      M555 P2                                 ; Set Marlin-style output
      G21                                     ; Set dimensions to millimetres
      G90                                     ; Send absolute coordinates...
      M83                                     ; ...but relative extruder moves
      ; Kinematics
      M669 K1                     			; CoreXY mode
      ; Axis to driver mapping
      M584 X0 Y1 U2 Z3:4:5         			; X and Y for CoreXY. U for toolchanger lock. Z has three drivers for kinematic bed suspension.
      M584 E22.0:23.0 						; Set Hermera extruder drives up on Hermera Toolboards
      M569 P0 S0               				; Drive 0 direction | X stepper
      M569 P1 S1              	 			; Drive 1 direction | Y Stepper
      M569 P2 S0                  			; Drive 2 direction | U Tool Changer Lock
      M569 P3 S0                  			; Drive 3 direction | Front Left Z
      M569 P4 S0                  			; Drive 4 direction | Front Right Z
      M569 P5 S0                  			; Drive 5 direction | Back Z
      M569 P22.0 S0 							; set tool 2 extruder direction on Hermera Toolboards
      M569 P23.0 S0 							; set tool 3 extruder direction on Hermera Toolboards
      ; Leadscrew locations (really, kinematic coupling locations) extracted from CAD model assuming back right build plate corner is (0, 0)
      M671 X300:5:152.5 Y316:316:-14 S10 ; Front Left: (300, 316) | Front Right: (5, 316) | Back: (-14, 152.5)
      ; Axis and motor configuration
      M350 X8 								; Set 8x microstepping for axes use interpolation.
      M350 Y8 I1                   			; Set 8x microstepping for axes use interpolation.
      M350 U4 I1                        		; Set 4x for toolchanger for lock use interpolation.
      M350 Z8 I1                     			; Set 8x microstepping for axes use interpolation.
      M350 E16 I1
      ; Motor Configurations
      M906 X1600 Y1600 Z1600:1600:1600 E1250 I30		; motor currents (mA) and Idle percentage
      M906 U900 I60                           		; Motor currents (mA) and Idle percentage
      M201 X800 Y800 Z800 E1300 U800         			; Accelerations (mm/s^2)
      M203 X6000 Y6000 Z1000 E1200 U9000    			; Maximum speeds (mm/min)
      M566 X1000 Y1000 Z500 E3000 U50	 				; Maximum jerk speeds mm/minute
      M92 X80 Y80                          			; Steps/mm for X,Y with 20 tooth pulleys.
      M92 Z1600                   					; Steps/mm for Z - TR8*4 / 0.9 deg stepper
      M92 U11.515                            			; Steps/mm for tool lock geared motor.
      M92 E837		                           		; Extruder - 0.9 deg/step
      Help please! 🙂
      • JoergS5undefined
        JoergS5 @beachtec
        @beachtec M906 are axis values, so set only one value for Z.
        And E needs two values for M906. (for some of the other M settings also)
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M906_Set_motor_currents
        "Example: If you have two motors on your Z axis, physically connected to Z and E0 stepper drivers, configured with M584 Z2:3, set M906 Z200, not M906 Z200:200"
        beachtecundefined 1 Reply Last reply Reply Quote 0
        • Vetiundefined
          Veti
          @beachtec said in Duet 3 Output Not Working:
          M584
          also see
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M584_Set_drive_mapping
          VERY IMPORTANT! Assigning a drive using M584 does not remove its old assignment. Therefore, if you assign a drive that defaults to being an extruder drive, you should also assign the extruder drives explicitly as in the above example. Failure to do so may result in unexpected behaviour.
          so do one M584 statement
          • beachtecundefined
            beachtec @JoergS5
            @JoergS5 That is interesting because my general guidance here has been from following @dc42's awesome wordpress blog https://github.com/Duet3D/RRF-machine-config-files/blob/master/E3D_Tool_Changer/dc42-duet3-centreZero-2Titan-2Hemera/sys/config.g... here it is as a cut and paste:
            M550 P"ToolChanger" 			; Set machine name
            M552 P192.168.1.153 S1			; Enable Networking
            M586 P0 S1 						; Enable HTTP
            M586 P2 S0 						; Disable Telnet
            M667 S1 						; Select CoreXY mode
            ; Drive direction
            M569 P0 S1 						; Drive 0 Z
            M569 P1 S0 						; Drive 1 Y
            M569 P2 S0 						; Drive 2 X
            M569 P3 S0 						; Drive 3 E0
            M569 P4 S0 						; Drive 4 E1
            M569 P5 S0 						; Drive 5 COUPLER
            M569 P22.0 S0 D2				; Drive 22.0 (E2) spreadCycle mode
            M569 P23.0 S0 D2 				; Drive 23.0 (E3) spreadCycle mode
            M584 X2 Y1 Z0 C5				; Axis to driver mapping
            M584 E3:4:22.0:23.0				; set extruder drivers
            M208 X-185:178.5 Y-149:49 Z0:300 C0:500					; Set axis maxima & minima
            M92 X100 Y100 Z1600 C200 E834:834:409:409				; Set steps per mm assuming x16 microstepping
            M350 E16:16:16:16 I1 									; Configure microstepping with interpolation
            M350 C16 I1
            M350 X16 Y16 Z16 I1										; Configure microstepping with interpolation
            M566 X400 Y400 Z8 C2 E200:200:200:200					; Set maximum instantaneous speed changes (mm/min)
            M203 X35000 Y35000 Z1200 C10000 E5000:5000:5000:5000	; Set maximum speeds (mm/min)
            M201 X6000 Y6000 Z400 C500 E2500:2500:2500:2500			; Set accelerations (mm/s^2)
            M906 X2000 Y2000 Z1330 C500 E1400:1400:1000:1000 I30	; Set motor currents (mA) and motor idle factor in percent
            M84 S120 												; Set idle timeout
            @DC42 is a kind of Ninja to me and his M584 section here has 2 entries; I thought maybe the Hermera(s) (running on ILC toolboard's over the CAN bus) might need a separate one... I mean @dc42 put it in HIS config.g file. That said, I have shrunk it to one... and the problem remains...
            I would LOVE to sort this!!!... and thank you all for trying to help!!!
            • JoergS5undefined
              JoergS5 @beachtec
              @beachtec you confuse me with @Veti , the M584 was from him, the M906 comment was from me.
              Did you change the M commands to have 2 entries for E?
              Can you please repost the config how it is now? Maybe it's not moving because the endstops have a problem and are triggered from the beginning.
              And I did not understand completely your first description: is it in slot 5 or 0 which is not working? Is an endstop assigned to the slot which is not working?
              • beachtecundefined
                beachtec @JoergS5
                @JoergS5 I am sorry for any confusion. Stepper 5 is NoOp. Steppers 3,4,5 are configured together to be the Z-axis. Motors 3,4 run and behave correctly. Swapping connectors with stepper 5, the new motor attached to stepper 5 connector does not function while the MOTOR that WAS connected to stepper 5 works fine in another position on the z-axis. I have commented out the stops (making no difference). Just trying to simplify and reduce the problem surface. I will post it in a few minutes. @JoergS5 , thank you for looking at this!!!
                JoergS5undefined beachtecundefined 2 Replies Last reply Reply Quote 0
                  Are you getting any error messages in the console when you try to move the motors?
                  https://forum.duet3d.com/topic/18011/duet-3-6hc-short-to-ground-issue
                  Please check if your Duet 3 may be affected by this known issue.
                  • JoergS5undefined
                    JoergS5 @beachtec
                    @beachtec a different thing is that the M92 for Z is wrong.
                    400 steps per rotation with M350 Z8 => 3200 steps for 4 mm => Z800 would be correct.
                    • beachtecundefined
                      beachtec @beachtec
                      @beachtec Lucky me. I have seen that error msg. My board# is WD41-412
                      • beachtecundefined
                        beachtec @JoergS5
                        @JoergS5 all 1.8 degree steppers (except the Hermera of course) ... 🙂
                        • JoergS5undefined
                          JoergS5 @beachtec
                          @beachtec so I was fooled by the comment...
                          Back to your problem, I think the first step to analyze would be to isolate the problem and test stepper 5 connector as single drive configuration (for drive X eg). If this works, the 3-drive-Z can be tested. Because now it could be a defective driver, a configuration issue, a wiring issue or something else.
                          • beachtecundefined
                            beachtec @JoergS5
                            @JoergS5 Fair enough... I should have probably done that before I posted! I will test a file and publish the results.
                            • JoergS5undefined
                              JoergS5 @beachtec
                              @beachtec you don't need a file, you can move the steppers by direct g-code commands in the "Send G-Code" field of the DWC duet web control. That's one of the advantages of Duet, the direct execution of all commands (with the exception of some config settings).
                              (> sorry if this bothers you, I don't know whether you are familiar with Duet).
                              • beachtecundefined
                                beachtec
                                I wrote one anyway to try on a few different axis. Stepper 5, nothing. Other steppers work with the same settings. 😞
                                • beachtecundefined
                                  beachtec @JoergS5
                                  @JoergS5 I am very grateful for the help and am always learning... do not worry about bothering me at all! I am good!
                                  • beachtecundefined
                                    beachtec
                                    and I love that command line window!
                                    • JoergS5undefined
                                      JoergS5 @beachtec
                                      @beachtec if driver 5 is defective, the common procedure is to look at the Duet 3 whether a defect is visible for warranty, so detailed images of front and back of the stepper 5 driver would be the next step. Inspections would be made by the moderators/administrators.
                                      It's confusing that M122 shows no errors for driver 5, so I expect that the driver is not defect. Maybe a connection problem of the connector?
                                      • beachtecundefined
                                        beachtec
                                        I do not understand it either. I believe that if the wiring was at fault, the stepper driver would have worked when a motor known to be working well was swapped out and the power was cycled. But when I did that. The drive I motor I swapped into Drive 5 did not work and the motor formerly in drive 5... worked fine in the new location. I would MUCH rather fix it then replace it... it's a lot of time and delays... but I understand. By the way, I wanted to redo all of my connectors doing this but there was just enough to do the job in my box but I tested them and they all show good connections, and the same Impedance and coil phasing. I have only had it a few days... been waiting to work on it this weekend. Duet Driver 5 Rear.jpg Duet Driver 5.jpg
                                        • JoergS5undefined
                                          JoergS5 @beachtec
                                          @beachtec you'll have to wait for the experts. Good luck!!
                                            Did you check out that link I posted? Send an email to see if you're affected by the diode problem. If so, replacement is really the only way to go.
