    Duet 3 Output Not Working
    722
    • JoergS5undefined
      JoergS5 @beachtec
      @beachtec you confuse me with @Veti , the M584 was from him, the M906 comment was from me.
      Did you change the M commands to have 2 entries for E?
      Can you please repost the config how it is now? Maybe it's not moving because the endstops have a problem and are triggered from the beginning.
      And I did not understand completely your first description: is it in slot 5 or 0 which is not working? Is an endstop assigned to the slot which is not working?
      beachtecundefined 1 Reply Last reply Reply Quote 0
      • beachtecundefined
        beachtec @JoergS5
        @JoergS5 I am sorry for any confusion. Stepper 5 is NoOp. Steppers 3,4,5 are configured together to be the Z-axis. Motors 3,4 run and behave correctly. Swapping connectors with stepper 5, the new motor attached to stepper 5 connector does not function while the MOTOR that WAS connected to stepper 5 works fine in another position on the z-axis. I have commented out the stops (making no difference). Just trying to simplify and reduce the problem surface. I will post it in a few minutes. @JoergS5 , thank you for looking at this!!!
        JoergS5undefined beachtecundefined 2 Replies Last reply Reply Quote 0
          Are you getting any error messages in the console when you try to move the motors?
          https://forum.duet3d.com/topic/18011/duet-3-6hc-short-to-ground-issue
          Please check if your Duet 3 may be affected by this known issue.
          • JoergS5undefined
            JoergS5 @beachtec
            @beachtec a different thing is that the M92 for Z is wrong.
            M92 Z1600 ; Steps/mm for Z - TR8*4 / 0.9 deg stepper
            400 steps per rotation with M350 Z8 => 3200 steps for 4 mm => Z800 would be correct.
            • beachtecundefined
              beachtec @beachtec
              @beachtec Lucky me. I have seen that error msg. My board# is WD41-412
              • beachtecundefined
                beachtec @JoergS5
                @JoergS5 all 1.8 degree steppers (except the Hermera of course) ... 🙂
                • JoergS5undefined
                  JoergS5 @beachtec
                  @beachtec so I was fooled by the comment...
                  Back to your problem, I think the first step to analyze would be to isolate the problem and test stepper 5 connector as single drive configuration (for drive X eg). If this works, the 3-drive-Z can be tested. Because now it could be a defective driver, a configuration issue, a wiring issue or something else.
                  • beachtecundefined
                    beachtec @JoergS5
                    @JoergS5 Fair enough... I should have probably done that before I posted! I will test a file and publish the results.
                    • JoergS5undefined
                      JoergS5 @beachtec
                      @beachtec you don't need a file, you can move the steppers by direct g-code commands in the "Send G-Code" field of the DWC duet web control. That's one of the advantages of Duet, the direct execution of all commands (with the exception of some config settings).
                      (> sorry if this bothers you, I don't know whether you are familiar with Duet).
                      • beachtecundefined
                        beachtec
                        I wrote one anyway to try on a few different axis. Stepper 5, nothing. Other steppers work with the same settings. 😞
                        • beachtecundefined
                          beachtec @JoergS5
                          @JoergS5 I am very grateful for the help and am always learning... do not worry about bothering me at all! I am good!
                          • beachtecundefined
                            beachtec
                            and I love that command line window!
                            • JoergS5undefined
                              JoergS5 @beachtec
                              @beachtec if driver 5 is defective, the common procedure is to look at the Duet 3 whether a defect is visible for warranty, so detailed images of front and back of the stepper 5 driver would be the next step. Inspections would be made by the moderators/administrators.
                              It's confusing that M122 shows no errors for driver 5, so I expect that the driver is not defect. Maybe a connection problem of the connector?
                              • beachtecundefined
                                beachtec
                                I do not understand it either. I believe that if the wiring was at fault, the stepper driver would have worked when a motor known to be working well was swapped out and the power was cycled. But when I did that. The drive I motor I swapped into Drive 5 did not work and the motor formerly in drive 5... worked fine in the new location. I would MUCH rather fix it then replace it... it's a lot of time and delays... but I understand. By the way, I wanted to redo all of my connectors doing this but there was just enough to do the job in my box but I tested them and they all show good connections, and the same Impedance and coil phasing. I have only had it a few days... been waiting to work on it this weekend. Duet Driver 5 Rear.jpg Duet Driver 5.jpg
                                • JoergS5undefined
                                  JoergS5 @beachtec
                                  @beachtec you'll have to wait for the experts. Good luck!!
                                    Did you check out that link I posted? Send an email to see if you're affected by the diode problem. If so, replacement is really the only way to go.
                                    • beachtecundefined
                                      beachtec
                                      @Phaedrux, @JoergS5, @T3P3Tony Epilogue.
                                      Thank you for your help with this issue.
                                      This forum is loaded with great people, support and solutions that drive a deeper understanding of your products and the creative ways they can be used.. it is straight up good reading, I always learn something and sometimes even gain a bit of humility!
                                      I had my replacement Duet 3 sent overnight and installed it straight away... within minutes everything was working properly, even a few little issues I had with noise on drive 0 and 1, which seemed like it might just be tuning, were cleared up and the machine performed perfectly. I love drivers on this board, it is so quiet!
                                      Anyway, thank you again for your help and support. Cheers!
                                      • JoergS5undefined
                                        JoergS5 @beachtec
                                        @beachtec nice to hear that it has a good end. Happy printing!
