    Duet 2 Wifi + BLtouch issues on Ender 5 pro
    3.9k
    • alxndrundefined
      alxndr @mitch
      @mitch just out of curiosity, how and where in comparison to your nozzle is your bltouch mounted?
      mitchundefined 1 Reply Last reply Reply Quote 0
      • mitchundefined
        mitch @alxndr
        @alxndr that is also defined in the config.g I posted. It is in the G31 setting for X and Y offsets.
        M950 S0 C"exp.heater4"                                 ; create servo pin 0 for BLTouch
        M558 P9 C"zprobe.in+zprobe.mod" H5 F120 T6000          ; set Z probe type to bltouch and the dive height + speeds
        G31 P500 X-43 Y3 Z2.0431                               ; set Z probe trigger value, offset and trigger height
        M557 X0:180 Y40:195 S40                                ; define mesh grid
        alxndrundefined 1 Reply Last reply Reply Quote 0
        • alxndrundefined
          alxndr @mitch
          @mitch I don't get how we have the same printer and yet we have different values for axis limits.
          • mitchundefined
            mitch
            I have a hemera direct drive extruder w/ BLtouch. You have a stock bowden extruder. You just need to go find the limits you have with your BLtouch setup and change the values.
              If you want to probe 4 points change your M557 from using S40 which is spacing between points to P4 which is probe 4 points and figure out the spacing automatically.
              alxndrundefined 2 Replies Last reply Reply Quote 0
              • alxndrundefined
                alxndr @Phaedrux
                @Phaedrux so I did that. But it only probes 3 while saying it can't reach some points.
                • alxndrundefined
                  alxndr @mitch
                  @mitch would you happen to have an example of start and end gcodes that i could look at? im trying to set mine right now. Thanks!
                  • alxndrundefined
                    alxndr @Phaedrux
                    @Phaedrux hey again! would you have any suggestions for start and end gcode? this is probably the very last thing i have to do until i can finally print. thanks!
                      stop.g start.g
                        Phaedrux Moderator @alxndr
                        @alxndr said in Duet 2 Wifi + BLtouch issues on Ender 5 pro:
                        Adjust your M557 grid based on your M208 size and your G31 probe offset.
                        If it's saying it can't reach a point, it's because it physically can't get the probe there. So move that point further in where the probe can reach.
