    What CAD software you use?
    3D Printing General Chat
    18
    58
    4.3k
    • botundefined
      bot @arhi
      I don't have much time to respond atm, but great points!
      Merill, SuperSlicer dev, has already been implementing FreeCAD into his slic3r fork! So, he's probably well aware of those workbenches or whatever and that's likely where he'll source his methodology.
      *not actually a robot
      arhiundefined 1 Reply Last reply Reply Quote 1
      • arhiundefined
        arhi @bot
        @bot yeah well between freecad, arcwelder and slic3r I think something interesting open source can be born... the major issue is an investment of time... just look how much kicad progressed after cern added a single paid developer to work on it full time.. prusaslicer has prusa research behind them, cura has ultimaker, idemaker has raise3d.. dunno who's backing superslicer but if it's just someone free time thats always scary 😞
          https://www.luban3d.com/
          It's not quite CAD. More like... post processor? Pre processor?
          • Stu3Dentundefined
            Stu3Dent
            Solidworks, Artec Studio and Blender for some of my projects sometimes. Still learning Solidworks, even though I've been working with it for a couple of years. Blender is for animations mostly.
            • LidaDidaundefined
              LidaDida
              Inventor
              • theruttmeisterundefined
                theruttmeister @arhi
                @arhi said in What CAD software you use?:
                @bot said in What CAD software you use?:
                I just tried to look, I do not know if AMF/3MF support "solid" geometry. I'd love to find out.
                When you export a solid from FreeCAD to .AMF it triangulates it so I would assume AMF is triangles only (so basically STL's + meta data) as FreeCAD works normally with solids and if it could save solid into .amf it would. I'm not sure but it makes sense.
                As others have said, .3MF is just a container file, it in theory supports any anything inside. DXF (yes, for laser cutters), STL, STEP... (I was there at /b when microsoft launched .3MF, and after reading the spec I couldn't have told you what problem it actually solved.)
                STEP/IGES works for decades for the engineering industry as an interchangeable file format for solids but not many slicers know how to deal with them. Machining CAM tools normally handle them ok, and I believe they would be totally ok for 3d print format as well. The only problem is that you can't handle solid formats on "cpu challenged" devices, and slicing a solid requires complex rendering of the solid that's rather "expensive" compared to a mesh that can be rendered on your watch. I'm not sure if STEP/IGES are protected by some patents, it would not surprise me if they are :(.
                Anyhow if we see how few open source tools know how to properly deal with STEP/IGES that might be the explanation..
                IGES and STEP are quite different. (IGES is only still supported by anyone because the US DoD requires it iirc).
                The important differences being that IGES can describe non-manifold solids. STEP can't.
                And STEP is still being updated. IGES hasn't had an update in over 20 years.
                There is 1 patent I'm aware of that describes how to slice a STEP for printing... It's more complex, but if we want to do things like actually use arc g-code we need a slicer that can actually accept arcs.
                If you asked me 10 years ago what the biggest software issue in 3D printing was, I would have said STL.
                Sad that we haven't moved past that point.
                Oh, and I use Fusion.
                Does anyone use Fusions internal slicer? I don't know if its converting to STL internally...
                Isolate, substitute, verify.
                Phaedruxundefined botundefined 2 Replies Last reply Reply Quote 0
                  Phaedrux Moderator @theruttmeister
                  @theruttmeister https://forum.duet3d.com/topic/14872/fusion-360-fdm-fff-slicing?_=1598474627031
                  Check that out for the Fusion Slicer.
                  • botundefined
                    bot @theruttmeister
                    @theruttmeister said in [What CAD software you use?]
                    Judging by the Fusion 360 API, I doubt they go fully to STL. They likely just triangulate a mesh internally and use that. Unfortunately, there is no ability to set at what resolution the mesh is made so it's kind of not great. I have long-term plans to cram prusaslicer (libslic3r) into Fusion as an add-in. Step to slicing with no middle format. It will be even easier now that they have their own slicing -- I can use the additive/manufacturing environment to set up the print just as they would, but then take over the process before the slicing is done or settings are chosen.
                    theruttmeisterundefined 1 Reply Last reply Reply Quote 0
                      theruttmeister @bot
                      @Phaedrux
                      Thanks, interesting link.
                      I would assume its the same slicer code that dates all the way back to Topolabs...
                      Those two things are the same... its not like STL is anything more than a mesh.
                      Given that whatever math Fusion is using to describe its solids (eg, brep or nurbs) is nothing like an STL, you might need to do some work on getting an input that prusaslicer can actually accept.
                      • botundefined
                        bot @theruttmeister
                        An STL is a very specific format and not the format that Fusion uses internally. I guess I'l stop responding to you in any way because all you want to do is argue without any understanding of what you're talking about. The Fusion API is documented, you can read it yourself.
                        • NiklasPundefined
                          NiklasP
                          I mostly use Inventor and Nastran in-CAD.
