    Cnc breakout board for 4 axis milling machine.
    CNC
    cnc milling metalwork
    907
    • bigdaveundefined
      bigdave
      Hi, I have a 1.5kw mill running 4x NEMA 34 12nm motors and drives. I really like your platform and was wondering if you have a suitable board for my purpose.
      Regards
      Dave
      jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @bigdave
        @bigdave
        There is a duet 3 with connections to external drivers planned but has not been released yet.
        The duet 2 family have a breakout board to allow external drives to be connected.
        Or there's the LPC or STM32 ports of the firmware that would allow external drives to be connected. I'm using an SKR Pro with external drives on my printNC build.
        bigdaveundefined 1 Reply Last reply Reply Quote 1
        • bigdaveundefined
          bigdave
          Thanks Jay, any idea as to when the duet 3 will be released?
            jay_s_uk @bigdave
            @bigdave I'm not the best person to ask. Maybe @T3P3Tony can answer?
            I believe it's months though
            bigdaveundefined 1 Reply Last reply Reply Quote 0
              dc42 administrators @bigdave
              @bigdave said in Cnc breakout board for 4 axis milling machine.:
              What's the specification of the motors, and what drivers do you currently use? Duet 3 can drive some types of Nema 34 motors directly. OTOH the more expensive external drivers have features like mid-band resonance damping, which Duet 3 doesn't have yet.
              • bigdaveundefined
                bigdave
                Hi, this is the detail given by the supplier in the kit.
                1 x Closed Loop Stepper Driver 0-8.5A 20-80VAC/30-110VDC for Nema 34 Stepper Motor
                1 x E Series Nema 34 Closed Loop Stepper Motor 12.0 Nm(1699.68oz.in) Encoder 1000CPR
                1 x 1.7 m(67") Long Encoder Extension Cable for Closed Loop Stepper Driver
                1 x RV-4 AWG18 1.7 m(67") Long Motor Extension Cable with GX16 Aviation Plug
                Motor Specification
                Part Number: 34HE59-6004D-E1000
                Number of phase: 2
                Holding Torque: 12.0 Nm(1699.68oz.in)
                Rated Current/phase: 6.0 A
                Phase Resistance: 0.7 ohms± 10%
                Inductance: 7.9 mH ± 20%(1KHz)
                Frame Size: 86 x 86 mm
                Body Length: 150.5 mm
                Shaft Diameter: Φ14 mm
                Shaft Length: 37 mm
                Keyway Shaft Length: 25 mm
                Lead Length: 300 mm
                Encoder Specification
                Driving Voltage : 5V
                Output current : 55mA
                Resolution : 1000cpr
                Output Signal : 2 Channels
                Bore Diameter : Φ8mm
                Output Frequency : ≤1MHz
                Running Speed : ≤5000rpm
                Driver Specification
                Output Peak Current: 0~8.5A(0~6 RMS)
                Input Voltage: 20~80VAC/30~110VDC (Typical 48/60VDC)
                Logic Signal Current: 7~16mA (Typical 10mA)
                Pulse Input Frequency: 0~200kHz
                Pulse Width: 2.5μS
                Built-in positioning and alarm output for easy detection and control
                Intelligently regulate current, reduce vibration, noise and heat, and increase efficiency by 35%
                With single and double pulse selection function, the factory default is: pulse + direction control
                Excellent high-speed performance and rigidity, perfect combination of servo and stepping advantages
                Connection
                PIN
                1
                Color
                White
                Green
                Blue
                Black
                Motor
                A+
                A-
                B+
                B-
                PIN
                13
                11
                12
                Color
                Red
                White
                Black
                Blue
                Yellow
                Green
                Encoder
                VCC
                EGND
                EA+
                EA-
                EB+
                EB-
                • bigdaveundefined
                  bigdave
                  This is the eBay link
                  https://www.ebay.com.au/itm/174181904398
                  • bigdaveundefined
                    bigdave
                    Also, to clarify my intent.
                    I’d like to get a complete kit from you that will allow me to build a multi use control panel that will allow me to move my motors between a number of machines. Mill, lathe, router, 3D printer, scanner ect.
                    I’d like to be able to setup machine profiles in the software to drive the different systems.
                    I’ve probably gone overkill on the (350w x4), drivers and motors and installed them into a mobile cabinet.
                    I’ll be installing breakers, surge protection and line filters into the panel.
                    Your system seems to be very intuitive and from what I’ve seen if it could be done then you’d be the people doing it.
                    I’m happy to incorporate anything you think appropriate to ensure a good outcome.
                    Thanks and regards
                    Dave
                    • bigdaveundefined
                      bigdave @jay_s_uk
                      @jay_s_uk
                      That’s ok, I’m not in a rush. In the meantime I want to keep building so I’d like engage with you on the rest of the system so I get it right.
                      Can that be done offline? It would just be easier is all.
                      mccaw.d@gmail.com
                        Those stepper drivers need step and direction signals with a minimum signal level of 5V. As we don't yet have a Duet 3 board that supports external drivers, the best solution we can currently offer is Duet 2 WiFi or Duet 2 Ethernet, plus the Expansion Breakout Board.
                        We're planning a Duet 3 main board to support external drivers, but it probably won't be available this year.
                        • bigdaveundefined
                          bigdave @dc42
                          Is the duet 3 capable of driving the motors directly?
                            jay_s_uk
                            @bigdave not the ones you've linked to
                            • bigdaveundefined
                              bigdave @jay_s_uk
                              @jay_s_uk
                              I still have to install Ballscrews an mount my motors so I might try to wait it out
                              tenajaundefined 1 Reply Last reply Reply Quote 0
                                A Former User @bigdave
                                Duet3 6HC is rated for 4.45A RMS (6A peak) and the motors are 6A, so you'd not make full use of the motors, but unless the low resistance pr coils is a problem it ought be possible to drive them at 4.45A.
                                  jay_s_uk
                                  Except they have closed loop feedback which couldn't be used, which IMO would be a bit of a waste
                                    A Former User @jay_s_uk
                                    @jay_s_uk said in Cnc breakout board for 4 axis milling machine.:
                                    closed loop
                                    d'oh! yes!
                                    • mikedahlgrenundefined
                                      mikedahlgren
                                      @dc42 Looking forward to doing something similar, is there any update on the Duet 3 with external drivers might be available? Or should I buy a Duet 3 mini with 3 1XD's?
                                        I'm sorry, we don't yet have an update on when Duet 3 with external driver support on the main board will be available. We are aware that a number of users are waiting for this.
                                        The Duet 3 Mini can in theory support two external drivers using a breakout expansion board (as well as further external drivers using the 1XD expansion board).
                                        • tenajaundefined
                                          tenaja @bigdave
                                          @bigdave
                                          How is your project coming?
                                          I'm surprised you are using ball screws and a control without backlash compensation. Do you just need fast, without concern for precision? Is there something else drawing you to duet?
                                          If duet had backlash comp, I'd put it on one (or more) of my desktop machines, but without it, I'm sticking with the existing LinuxCNC. I suppose one could use a Marlin or Beagle board, but I haven't used either yet, so I don't have a favorite or a reason to migrate. (Like standardization.)
