    RepPanel - A DIY alternative to the PanelDue with WiFi support
    Third-party software
    39
    243
    30.5k
    • pdundefined
      pd @seeul8er
      @seeul8er I finally had another go with this and have made some progress. I bought a new capacitive screen from buydisplay. Unfortunately I didn't realise it wasn't 3.3v version to start with but it was easy enough to short the JP bridge. I finally managed to get the reppanel to light up. The touch screen seems to work and I managed to find my router. However the one issue I have left is that I am unable to bring up the keyboard from the top right hand corner to change the password. Do you have any idea why this might happen. All the other Icons seem to open OK.
      @PCR Any news on the PCB front ?
      • PCRundefined
        PCR
        Still waiting for a display ;(
        • PCRundefined
          PCR
          Orderd again. PCB will follow!
          I_Jediundefined 1 Reply Last reply Reply Quote 0
          • I_Jediundefined
            I_Jedi @PCR
            @PCR When the PCB is done... sign me up for one! I love the idea of the RepPanel, but have limited skills and time to implement... so the more plug and play the better 🙂
            • PCRundefined
              PCR
              Plan is to put a prototype into production next week! Who would be in?
              appjawsundefined I_Jediundefined kingfisherundefined 3 Replies Last reply Reply Quote 0
              • seeul8erundefined
                seeul8er
                @pd Try to scroll down for the keyboard. It is hidden on the lower part of the page 🙂
                pdundefined 1 Reply Last reply Reply Quote 0
                • appjawsundefined
                  appjaws @PCR
                  @PCR yes please
                  appjaws - Core XYUV Duet Ethernet Duex5
                  firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
                  Ormerod 1-converted to laser engraver, Duet wifi
                  OpenSCAD version 2024.03.18
                  Simplify3D 5.1.2
                  • I_Jediundefined
                    I_Jedi @PCR
                    @PCR I'm in assuming it isn't stupid expensive -- Could I have more details on intended cost and functionality... is this an 'all in one kit'? DIY?
                    • PCRundefined
                      PCR
                      Would be a pcb only. But you would need a esp and the Display! But would be easy to assemble!
                      I_Jediundefined paralepsisundefined 2 Replies Last reply Reply Quote 0
                      • I_Jediundefined
                        I_Jedi @PCR
                        @PCR why not... I'll give it a go. Looking forward to it! So I should go ahead and order the board and display? Any parameters/features I should be looking for? i assume any ESP devboard should work... but what about the screen?
                        • kingfisherundefined
                          kingfisher @PCR
                          @PCR I'm in - Subject to costs (+Shipping)
                          • oliofundefined
                            oliof
                            @PCR yes please.
                            • pdundefined
                              pd @seeul8er
                              @seeul8er Thanks. I have now managed to connect the Reppanel to my router and it has been given an ip address. However I seem to be unable to connect to the duet. Further more after several tries at typing in the duet ip address the esp32 seem to go into a loop. I am unable to delete the data I've entered. I have tried reflashing the ESP32 but altho the flashing seems to work the old data persists. Is there anyway to delete the existing data?
                              • seeul8erundefined
                                seeul8er
                                @pd Strange crash. You can delete flash by calling idf.py -p PORT erase_flash
                                pdundefined 2 Replies Last reply Reply Quote 0
                                • pdundefined
                                  pd @seeul8er
                                  @seeul8er Yes I have tried this but I get a fatal error ESP32 ROM does not support function erase_flash. I am using a ESP32 devkitc v4. Where do you store these parameters?
                                  • pdundefined
                                    pd @seeul8er
                                    @seeul8er I am pleased to say I have found the problem. Basically this is because the Ubuntu version of esptool does not for some reason allow the erase-flash function. I had to download it from the python repository.
                                    So I have again managed to connect to the router. Please could you clarify the format of entry for the printer address. Should it anyway be discovered automatically in the same way as the SSID?
                                    • paralepsisundefined
                                      paralepsis @seeul8er
                                      @seeul8er Sorry if I'm being dense, but I'm not working out how to get the password changed!
                                      I've got v1.1.0 flashed, everything hooked up to the suggested ER-TFTM035-6 screen, it boots and sees available networks, all that good stuff. I'm able to select an appropriate WiFi network. But I need to type a password for that network.
                                      There's a cursor on the line for the password, and asterisks, but I cannot work out how to type in the right password. I have tried using the keyboard icon in the top-right, but that doesn't seem to be the right thing -- that seems to be strictly for sending gcodes?
                                      Sorry for the dumb question, hope it's an easy answer :).
                                      Thanks!
                                      Railcore II 300XL w/ Duet 3 & RRF 3.5rc4, Makerbot R2X w/ Duet 2 WiFi & RRF 3.4
                                      paralepsisundefined 1 Reply Last reply Reply Quote 0
                                        paralepsis @PCR
                                        @PCR Yes, interested in the PCB. Thanks!
                                          paralepsis @paralepsis
                                          Nevermind, discovered the scroll. Sorry for the distraction.
                                          • seeul8erundefined
                                            seeul8er
                                            @pd The following options are supposed to work for the address:
                                            • Auto discovery using the update/scan button
                                            • Manual IP entry: XXX.XXX.XXX.XXX
                                            • Manual mDNS address entry: XXXXX.local
                                            The prefix http:// or https:// is auto added if not existing. The text field shows .local by default, but there is more in there, the textfield just autoscrolled in that case. Make sure to delete the complete entry before entering your address.
