Can you reset "Error: Z probe already triggered..."
When calibrating my Z probe (BLTouch), I accidentally sent a G30 command without ensuring that the head was high enough for the probe. Doing this causes the probe to go into a blinking failed state. I'm wondering if there is a g-code that I can send to reset the probe so I can raise the head and try again. I try sending M999 and that doesn't do anything. The only way I have found to reset the probe's error state is to power down the machine and power it back up.
I'm hoping there is a command that I can send without doing a power-cycle.
Thanks,
Preston -
@prestonthayne see this chart:
From about half way down the page: https://www.antclabs.com/bltouch-v3#So
M280 P[your BLTouch servo number] S160
should do it.Ian
@droftarts You rock!! Thank you.
It's not a bad idea to put one of those commands at the start of your homeall to clear any error states before trying to home.
