    Fan Problem - Blown Board?
    Duet Web Control
    1.3k
      It sounds like the Fan0 mosfet got damaged when the fuse was blown.
      Garyundefined 1 Reply Last reply Reply Quote 0
      • Garyundefined
        Gary @Phaedrux
        @Phaedrux Yeah. Nothing physically obvious. What also confused me was the 2 Fans on the WebGUI. I didn't notice that one was Tool Fan and the other Fan 0, which are the same. I thought one was the heatsink fan, which thinking about it now wouldn't make sense as it's not speed controllable. Thanks for your help.
          You can post a close up high res well lit clear photo of the fan port area so we can see if there is any damage.
          • Garyundefined
            Gary @Phaedrux
            @Phaedrux Hope it's clear enough.
            ![0_1597559615949_20200816_072939.jpg](Uploading 100%)
            Getting:
            Error
            Input file contains unsupported image format
              Can you try putting the photo on dropbox or google drive or something like that?
              • Garyundefined
                Gary @Phaedrux
                  Nothing really visible, but it may still have failed.
                    A Former User
                    if you have a multimeter putting "multimeter mosfet" into google will show you how to test the mosfet properly its a little involved so doesn't make sense to repeat what google can tell you
                    • Garyundefined
                      Gary @A Former User
                      @bearer Thanks I will check as I have now visually blown P3. Also P1 stopped working. So all 3 now not working! Is there anywhere in the UK that I can send the board to get it fixed?
                      (I bought pre-wired connectors, but I didn't see that although the connectors were compatible at the hot end the polarity was reversed to the fan. I wouldn't have thought that switching the fan polarity would have blown anything - the fans would just spin the wrong way).
                        dc42 administrators @Gary
                        @Gary said in Fan Problem - Blown Board?:
                        Send me a PM, I can replace the mosfets.
                        (I bought pre-wired connectors, but I didn't see that although compatible at the hot end the polarity was reversed to the fan. I wouldn't have thought that switching the fan polarity would have blown anything - the fans would just spin the wrong way).
                        Unfortunately, brushless DC fans don't work like that. A few types just don't work when connected the wrong way round, but most of them present a short-circuit.
                        Garyundefined 1 Reply Last reply Reply Quote 1
                        • Garyundefined
                          Gary @dc42
                          @dc42 Thanks for the info about the polarity. That now makes sense! I bought some PMV20XNER MOSFETs, but the size of them is way beyond my capability.
                          I tried to PM you, but I get then message "This user has restricted their chat messages. They must follow you before you can chat with them"
                            Try now.
