USB Drivers
20
2.9k
    hblz
    Yeah, great advise! Thanks. It works. But now back to setting my Duet wifi to a fixed adress. M552 S1 Px.x.x.x does not work...
    undefined ? 2 Replies Last reply 4 Jun 2020, 16:53 Reply Quote 0
      jay_s_uk @hblz
      @hblz if possible, I would suggest you look at assigning a fixed IP from the router rather than the duet. That way there's no chance of another device getting assigned the same IP
      undefined 1 Reply Last reply 4 Jun 2020, 16:58 Reply Quote 0
        hmortensen @jay_s_uk
        @jay_s_uk If you know your own network segment, and assign static IP on the ESP, you shave around 1-2 sec in boot time.
          A Former User @hblz
          @hblz said in USB Drivers:
          i think it should, been awhile since i tried it. the other option is to store it with m587 Ix.x.x.x
          you may want to forget the old entry first for good measure.
          (also, what he said ☝ )
            hblz @dc42
            @dc42 I still can't get the USB driver working. Is there a way to clean the drivers up? Is there a difference between versions of the Duets wifi ? I would like to be able to connect the duet3d to my simplify 3d since this is sometimes easier and quicker then sending files to the duet.
              Do you see anything show up when the duet is connected if you go to view > show hidden devices?
              undefined 1 Reply Last reply 4 Jun 2020, 20:32 Reply Quote 0
                hblz @Phaedrux
                @Phaedrux Yes, it says 'unknown USB, device descriptor failed' (translated from dutch)
                  Can you delete that device and then replug the duet into a new port?
                  Do you have a powered usb hub to try with as well?
                  undefined 1 Reply Last reply 4 Jun 2020, 20:56 Reply Quote 0
                    hblz @Phaedrux
                    @Phaedrux Unfortunatedly deleting does not change a thing. Different cable doesnt help either.
                      M1sterd
                      Does this work over Wifi now as well? I know originally it was said that Windows 10 and 3D printers was around USB, but wondered if this had changed?.
                      undefined 1 Reply Last reply 6 Sept 2020, 22:11 Reply Quote 0
                        Phaedrux Moderator @M1sterd
                        @M1sterd said in USB Drivers:
                        I'm not exactly sure what you're asking here.
