Using HangPrinter geometry for Wall Plotter?
@JoergS5 said in Using HangPrinter geometry for Wall Plotter?:
I had some discussions in reprapforum about using wires. There were some interesting ideas to avoid the length deviation due to the take-up on a spindle.
This here eg: https://reprap.org/forum/read.php?14,815780,page=3@JoergS5 I remembered that there's this thread on the reprap forums https://reprap.org/forum/read.php?2,151871,177714#msg-177714 about using a tilted pulley to feed wire around a pulley. The incoming/outgoing wire is always on the same position, so there isn't an issue with it moving up and down the drive pulley, causing length deviation. Seem like they had problems getting it to work as a CoreXY though, possibly due to tension.
@droftarts I didn't mean moving up and down the axis position, but doubling (tripling etc.) the wires on the spindle when they are stacked, changing the radius and so steps/mm. This will result in a changing movement which is difficult to calculate.
The solution with two pulleys had a problem that the solution had too much friction. I think the solution with the stepper and 4 spindles/pulleys at the edges is a nice solution.For tension, there was also a lot of discussion what to take, like FireLine, Kevlar, steel etc.
One interesting addition was a formula how much friction is needed for wires:
https://reprap.org/forum/read.php?397,817525,826869#msg-826869
Unfortunately I didn't understand the formula... -
@JoergS5 Hey I saw on the other topic you are also building a new kinematic system. Can you help me to build the firmware? I tried to follow the BuildInstructions.md file but it seems some components are not availible for download...
At point 3. I get to this page: https://sourceforge.net/projects/gnuarmeclipse/
which tells me it is outddated -
@TC the BuidInstructions.md is a file in the github, your link is missing all the part http etc. in front of it.
The correct path to the file is:
https://github.com/Duet3D/RepRapFirmware/blob/v3.02-dev/BuildInstructions.md
Please take the one of the branch you're using, they may be different. (Change branch in github, the correct .md file will be shown then) -
@JoergS5 Yes I know but the download link in the BuildInstruction file in version 3.1.1 did not work. But the link in the file you posted worked
Now I followed the instruction and unfortunately am stuck trying to build CoreNG. I get this error:17:29:36 **** Incremental Build of configuration Default for project CoreNG ****
make all
make: *** No rule to make target 'all'. Stop.
"make all" terminated with exit code 2. Build might be incomplete.17:29:36 Build Failed. 1 errors, 0 warnings. (took 532ms)
@TC I don't build for all, so I don't know how to help. I use a specific target, Duet 3 e.g. and then build. When I build RepRapFirmware, it builds all dependent projects automatically (including CoreNG).
@JoergS5 I didn't intend to build for all. Do you know how just to build for Duet Wifi?
@TC in project RepRapFirmare, right click on project, then select Build Configuration - Select - and select your target.
I deleted the Duet 2 target in my project, so I cannot tell you how it's named, probably SAM4E8E (that's the name of the MCU).I checked, it's probably Duet2_RTOS.
@JoergS5 Ok I did not take the different branches into account. Now CoreNG and FreeRTOS work but RRFLibaries dont...
Do you use these branches?RepRapFirmware: v3-dev CoreNG: dev FreeRTOS: master RRFLibraries: dev DuetWiFiSocketServer: master CANlib : master
Or did anything change here that is not updated in the instruction?
@TC I had also some problems with the different branches. So now I always use tags, currently 3.1.0 tag for all projects (in github, when opening a project, there is a tag button). They compile well. I've not tested it, but RepRapFirmware has a 3.1.1 tag also, this could work also.
@JoergS5 yes now we are very close
Just one more error at the end of Firmware build:c:/program files/gnu arm eclipse/build tools/2.6-201507152002/bin//sh: crc32appender: not found
makefile:94: recipe for target 'post-build' failed
make[1]: [post-build] Error 127 (ignored)Did you see that before?
@TC in the reprapfirmware\Tools\crc32appender directory is this tool for different operating systems, this must be reachable. I expect it creates a signature or checksum information.
@JoergS5 hm but it is definitly there...
@TC see this thread https://forum.duet3d.com/topic/12275/crc32appender-now-needed-for-rrf
The folder that contains crc32appender needs to be in you PATH.Ian
@droftarts @JoergS5 Ah now its working. Thanks a lot!
This post is deleted! -
@TC you can make a fork of the Reprapfirmware in github and use it to add your files. The advantage would be, you can update easily with the newest updates of the original and check if anything breaks. Sometimes the method's signatures change.
@JoergS5 Oh thanks. I just noticed I can't upload the the files here
@TC maybe for security reasons
@JoergS5 I tried to fork the firmware. Hope I did it right...
https://github.com/TC1991/RepRapFirmware/blob/dev/src/Movement/Kinematics/VerticalPlotterKinematics.cpp
https://github.com/TC1991/RepRapFirmware/blob/dev/src/Movement/Kinematics/VerticalPlotterKinematics.hProberbly I will also have to add there the changes in Kinematics.cpp etc.
