    Duet 3 Disconnects from SBC
    Firmware installation
    1.5k
      If the pi is connected to the duet via usb you can use bossa to flash the duet. That may be a better option if it's too much hassle getting everything disconnected to get it to a PC to flash. But if you have a laptop or PC nearby that might be easier if you're not comfortable with the pi environment.
      mrenz999undefined 2 Replies Last reply Reply Quote 0
      • mrenz999undefined
        mrenz999 @Phaedrux
        @Phaedrux I have a laptop. Do I need to disconnect everything from the board or just plug in and do it ?
        • mrenz999undefined
          mrenz999 @Phaedrux
          @Phaedrux Verify failed
          Page errors: 1115
          Byte errors: 564485
          This was the response when I used BOSSA through the pi
            A Former User @mrenz999
            @mrenz999 said in Duet 3 Disconnects from SBC:
            Unhandled exception. System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requested address /var/run/dsf/dcs.sock
            Aborted
            This is the result of it.
            so that could be why it didn't upgrade with apt, as pi and duet aren't communicating over the spi link and that also prevent duet web control working.
            seeing as bossac failed, maybe try different usb cable or from a computer instead (or disconnect any power hungry peripherals to eliminate usb power supply issues)
            • mrenz999undefined
              mrenz999 @Phaedrux
              @Phaedrux Ok I got it updated using BOSSA through the pi. 2 failed prints later.
              m122
              RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
              Board ID: 08DJM-956L2-G43S8-6J1FA-3SJ6P-1B06G
              Used output buffers: 1 of 40 (13 max)
              Static ram: 154604
              Dynamic ram: 163364 of which 20 recycled
              Exception stack ram used: 536
              Never used ram: 74692
              Tasks: NETWORK(ready,1972) HEAT(blocked,1188) CanReceiv(suspended,3820) CanSender(suspended,1420) CanClock(blocked,1436) TMC(blocked,68) MAIN(running,2868) IDLE(ready,76)
              Owned mutexes:
              Last reset 10:16:20 ago, cause: software
              Last software reset at 2020-09-05 05:11, reason: User, spinning module LinuxInterface, available RAM 75124 bytes (slot 3)
              Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
              Error status: 0
              MCU temperature: min 40.5, current 40.8, max 43.9
              Supply voltage: min 23.9, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
              12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
              Driver 0: standstill, reads 56301, writes 8 timeouts 0, SG min/max 0/591
              Driver 1: standstill, reads 56300, writes 8 timeouts 0, SG min/max 0/646
              Driver 2: standstill, reads 56301, writes 8 timeouts 0, SG min/max 0/99
              Driver 3: standstill, reads 56300, writes 8 timeouts 0, SG min/max 0/97
              Driver 4: standstill, reads 56300, writes 8 timeouts 0, SG min/max 0/78
              Driver 5: standstill, reads 56304, writes 4 timeouts 0, SG min/max 0/847
              Date/time: 2020-09-05 15:27:29
              Slowest loop: 5.84ms; fastest: 0.15ms
              === Storage ===
              Free file entries: 10
              Hiccups: 0(0), FreeDm: 375, MinFreeDm: 292, MaxWait: 9557402ms
              === MainDDARing ===
              Scheduled moves: 41108, completed moves: 41108, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
              === AuxDDARing ===
              Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
              Segments left: 0
              Movement lock held by null
              HTTP* is ready with "M122" in state(s) 0
              Telnet is idle in state(s) 0
              File* is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is assembling a command in state(s) 0
              Queue* is idle in state(s) 0
              LCD is idle in state(s) 0
              SBC is idle in state(s) 0
              Daemon* is idle in state(s) 0 0, running macro
              Aux2 is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Slowest loop: 2.13ms; fastest: 0.01ms
              HTTP sessions: 0 of 8
              • Ethernet -
                State: disabled
                Error counts: 0 0 0 0 0
                === CAN ===
                Messages sent 91415, longest wait 0ms for type 0
                === Linux interface ===
                State: 0, failed transfers: 309
                Last transfer: 16ms ago
                RX/TX seq numbers: 20337/20313
                SPI underruns 118, overruns 118
                Number of disconnects: 0
                Buffer RX/TX: 0/0-0
                === Duet Control Server ===
                Duet Control Server v3.1.1
                Code buffer space: 4096
                Full transfers per second: 32.45
                Does it fail on every print now?
                Can you share the gcode file you're printing?
                Can you setup debugging info?
                https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Monitoring_optional
                mrenz999undefined 3 Replies Last reply Reply Quote 0
                • mrenz999undefined
                  mrenz999 @Phaedrux
                  @Phaedrux Yes every print. I have tried mulitple prints. I will setup debugging and share the Gcode this evening when I get back from work. Every print it just stops about 10% or so in. It has rebooted but on the status page it says it has completed the print.
                  • mrenz999undefined
                    mrenz999 @Phaedrux
                    @Phaedrux
                    Where can I upload the file I was printing ?
                    m122
                    Used output buffers: 1 of 40 (10 max)
                    Static ram: 154604
                    Dynamic ram: 163156 of which 20 recycled
                    Exception stack ram used: 528
                    Never used ram: 74908
                    Tasks: NETWORK(ready,1972) HEAT(blocked,1188) CanReceiv(suspended,3820) CanSender(suspended,1420) CanClock(blocked,1436) TMC(blocked,68) MAIN(running,2672) IDLE(ready,76)
                    Owned mutexes:
                    Last reset 00:28:11 ago, cause: power up
                    Last software reset at 2020-09-05 17:15, reason: User, spinning module LinuxInterface, available RAM 74692 bytes (slot 0)
                    Error status: 0
                    MCU temperature: min 36.1, current 41.6, max 41.7
                    Driver 0: standstill, reads 53593, writes 17 timeouts 0, SG min/max 0/216
                    Driver 1: standstill, reads 53594, writes 17 timeouts 0, SG min/max 0/165
                    Driver 2: standstill, reads 53594, writes 17 timeouts 0, SG min/max 0/104
                    Driver 3: standstill, reads 53594, writes 17 timeouts 0, SG min/max 0/98
                    Driver 4: standstill, reads 53595, writes 17 timeouts 0, SG min/max 0/103
                    Driver 5: standstill, reads 53595, writes 17 timeouts 0, SG min/max 0/210
                    Date/time: 2020-09-06 03:21:15
                    Slowest loop: 5.23ms; fastest: 0.14ms
                    === Storage ===
                    Hiccups: 0(0), FreeDm: 375, MinFreeDm: 340, MaxWait: 1539522ms
                    === MainDDARing ===
                    Scheduled moves: 1396, completed moves: 1396, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                    === AuxDDARing ===
                    Segments left: 0
                    === Network ===
                    Slowest loop: 2.14ms; fastest: 0.01ms
                    • Ethernet -
                      State: disabled
                      === CAN ===
                      Messages sent 6679, longest wait 0ms for type 0
                      State: 0, failed transfers: 2
                      Last transfer: 22ms ago
                      RX/TX seq numbers: 54222/54222
                      SPI underruns 3, overruns 3
                      Buffer RX/TX: 0/0-0
                      Full transfers per second: 14.09
                    • mrenz999undefined
                      mrenz999 @Phaedrux
                      @Phaedrux
                      Written by Christian Hammacher for Duet3D
                      Licensed under the terms of the GNU Public License Version 3
                      [info] Settings loaded
                      [info] Environment initialized
                      [fatal] Could not connect to Duet (Board is not available (no header))
                      [debug] System.OperationCanceledException: Board is not available (no header)
                      at DuetControlServer.SPI.DataTransfer.ExchangeHeader() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 1093
                      at DuetControlServer.SPI.DataTransfer.PerformFullTransfer(Boolean connecting) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 162
                      at DuetControlServer.SPI.DataTransfer.Init() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 102
                      at DuetControlServer.Program.Main(String[] args) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Program.cs:line 10
                      This is what i get when I try to run debug
                        Phaedrux Moderator @mrenz999
                        If it's small enough you can upload it here. If it's too large try zipping it and use dropbox or something like that to share it.
                        mrenz999undefined 1 Reply Last reply Reply Quote 0
                        • mrenz999undefined
                          mrenz999 @Phaedrux
                          @Phaedrux
                          https://www.dropbox.com/s/c1a8ve3eq0kahxr/CFFFP_lotus_nightlight.gcode?dl=0
                          Constant G28 network errors pop up.
                            What does this mean?
                            • mrenz999undefined
                              mrenz999 @Phaedrux
                              @Phaedrux It means everything I do pops that up on the bottom right of the screen. However, I completely redid the SBC and this morning everything seems to be working.
                                It says G28 network error?
                                Well glad to hear that it seems to be working now.
