    Duet 3 Disconnects from SBC
    Firmware installation
    1.5k
    • mrenz999undefined
      mrenz999 @Phaedrux
      @Phaedrux So it should just require a sudo apt-get update ?
        A Former User
        as of 3.0.0 apt should just-work(tm) for upgrades (but expansion- or tool-boards needs to be upgraded by M997 until the scripts from the reprapfirmware package takes care of that)
        mrenz999undefined 1 Reply Last reply Reply Quote 0
        • mrenz999undefined
          mrenz999 @A Former User
          @bearer Hmmm. Well it updated the Pi but not the Duet 3. Is there something else I should be doing ?
          • mrenz999undefined
            mrenz999
            Is there something else to do other than that sudo apt-get update and upgrade that needs to be done?
              Some of the older firmware didn't update properly with the normal apr-get update method. In these cases you'd need to update the board firmware separately. Once you're at 3.1.1 it should "just work" going forward.
              You should be able to update the board firmware by uploading the firmware zip file to the /sys folder in DWC just as you would normally with any other Duet.
              https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
              If that doesn't work, then you have the option of using Bossa to flash the firmware to the board over USB with a PC.
              https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Updating_Duet_3_main_board_firmware
                A Former User @mrenz999
                @mrenz999 said in Duet 3 Disconnects from SBC:
                not really, but it'd be helpfull to see the output from apt as it would allude to why the firmware failed.
                should be as simple as doing echo S997 | sudo /opt/dsf/bin/CodeConsole from ssh if the duet is communicating with the pi (if its not then thats why the upgrade failed, but afaik not been an issue after 3.0)
                • mrenz999undefined
                  @bearer pi@duet3:~ $ echo S997 | sudo /opt/dsf/bin/CodeConsole
                  Unhandled exception. System.Net.Internals.SocketExceptionFactory+ExtendedSocketException (99): Cannot assign requested address /var/run/dsf/dcs.sock
                  at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress)
                  at System.Net.Sockets.Socket.Connect(EndPoint remoteEP)
                  at DuetAPIClient.BaseConnection.Connect(ClientInitMessage initMessage, String socketPath, CancellationToken cancellationToken) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetAPIClient/BaseConnection.cs:line 98
                  at CodeConsole.Program.Main(String[] args) in /home/christian/Duet3D/DuetSoftwareFramework/src/CodeConsole/Program.cs:line 44
                  at CodeConsole.Program.<Main>(String[] args)
                  Aborted
                  This is the result of it.
                    Did you try uploading the Zip in DWC?
                    mrenz999undefined 2 Replies Last reply Reply Quote 0
                    • mrenz999undefined
                      mrenz999 @Phaedrux
                      @Phaedrux I did download it. However, I am unable to connect to DWC now for some reason. It says Failed to connect to Duet3.local DCS not started. I hard power reset both, unplugged and left off for a few mins and replugged them in. Is there a way to do it through the pi ?
                        If the pi is connected to the duet via usb you can use bossa to flash the duet. That may be a better option if it's too much hassle getting everything disconnected to get it to a PC to flash. But if you have a laptop or PC nearby that might be easier if you're not comfortable with the pi environment.
                        • mrenz999undefined
                          mrenz999 @Phaedrux
                          @Phaedrux I have a laptop. Do I need to disconnect everything from the board or just plug in and do it ?
                          • mrenz999undefined
                            mrenz999 @Phaedrux
                            @Phaedrux Verify failed
                            Page errors: 1115
                            Byte errors: 564485
                            This was the response when I used BOSSA through the pi
                              Aborted
                              so that could be why it didn't upgrade with apt, as pi and duet aren't communicating over the spi link and that also prevent duet web control working.
                              seeing as bossac failed, maybe try different usb cable or from a computer instead (or disconnect any power hungry peripherals to eliminate usb power supply issues)
                              • mrenz999undefined
                                mrenz999 @Phaedrux
                                @Phaedrux Ok I got it updated using BOSSA through the pi. 2 failed prints later.
                                m122
                                RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
                                Board ID: 08DJM-956L2-G43S8-6J1FA-3SJ6P-1B06G
                                Used output buffers: 1 of 40 (13 max)
                                Static ram: 154604
                                Dynamic ram: 163364 of which 20 recycled
                                Exception stack ram used: 536
                                Never used ram: 74692
                                Tasks: NETWORK(ready,1972) HEAT(blocked,1188) CanReceiv(suspended,3820) CanSender(suspended,1420) CanClock(blocked,1436) TMC(blocked,68) MAIN(running,2868) IDLE(ready,76)
                                Owned mutexes:
                                Last reset 10:16:20 ago, cause: software
                                Last software reset at 2020-09-05 05:11, reason: User, spinning module LinuxInterface, available RAM 75124 bytes (slot 3)
                                Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
                                Error status: 0
                                MCU temperature: min 40.5, current 40.8, max 43.9
                                Supply voltage: min 23.9, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                                12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
                                Driver 0: standstill, reads 56301, writes 8 timeouts 0, SG min/max 0/591
                                Driver 1: standstill, reads 56300, writes 8 timeouts 0, SG min/max 0/646
                                Driver 2: standstill, reads 56301, writes 8 timeouts 0, SG min/max 0/99
                                Driver 3: standstill, reads 56300, writes 8 timeouts 0, SG min/max 0/97
                                Driver 4: standstill, reads 56300, writes 8 timeouts 0, SG min/max 0/78
                                Driver 5: standstill, reads 56304, writes 4 timeouts 0, SG min/max 0/847
                                Date/time: 2020-09-05 15:27:29
                                Slowest loop: 5.84ms; fastest: 0.15ms
                                === Storage ===
                                Free file entries: 10
                                Hiccups: 0(0), FreeDm: 375, MinFreeDm: 292, MaxWait: 9557402ms
                                === MainDDARing ===
                                Scheduled moves: 41108, completed moves: 41108, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                                === AuxDDARing ===
                                Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                                Segments left: 0
                                Movement lock held by null
                                HTTP* is ready with "M122" in state(s) 0
                                Telnet is idle in state(s) 0
                                File* is idle in state(s) 0
                                USB is idle in state(s) 0
                                Aux is assembling a command in state(s) 0
                                Queue* is idle in state(s) 0
                                LCD is idle in state(s) 0
                                SBC is idle in state(s) 0
                                Daemon* is idle in state(s) 0 0, running macro
                                Aux2 is idle in state(s) 0
                                Code queue is empty.
                                === Network ===
                                Slowest loop: 2.13ms; fastest: 0.01ms
                                HTTP sessions: 0 of 8
                                • Ethernet -
                                  State: disabled
                                  Error counts: 0 0 0 0 0
                                  === CAN ===
                                  Messages sent 91415, longest wait 0ms for type 0
                                  === Linux interface ===
                                  State: 0, failed transfers: 309
                                  Last transfer: 16ms ago
                                  RX/TX seq numbers: 20337/20313
                                  SPI underruns 118, overruns 118
                                  Number of disconnects: 0
                                  Buffer RX/TX: 0/0-0
                                  === Duet Control Server ===
                                  Duet Control Server v3.1.1
                                  Code buffer space: 4096
                                  Full transfers per second: 32.45
                                  Does it fail on every print now?
                                  Can you share the gcode file you're printing?
                                  Can you setup debugging info?
                                  https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Monitoring_optional
                                  mrenz999undefined 3 Replies Last reply Reply Quote 0
                                  • mrenz999undefined
                                    mrenz999 @Phaedrux
                                    @Phaedrux Yes every print. I have tried mulitple prints. I will setup debugging and share the Gcode this evening when I get back from work. Every print it just stops about 10% or so in. It has rebooted but on the status page it says it has completed the print.
                                    • mrenz999undefined
                                      mrenz999 @Phaedrux
                                      @Phaedrux
                                      Where can I upload the file I was printing ?
                                      m122
                                      Used output buffers: 1 of 40 (10 max)
                                      Static ram: 154604
                                      Dynamic ram: 163156 of which 20 recycled
                                      Exception stack ram used: 528
                                      Never used ram: 74908
                                      Tasks: NETWORK(ready,1972) HEAT(blocked,1188) CanReceiv(suspended,3820) CanSender(suspended,1420) CanClock(blocked,1436) TMC(blocked,68) MAIN(running,2672) IDLE(ready,76)
                                      Owned mutexes:
                                      Last reset 00:28:11 ago, cause: power up
                                      Last software reset at 2020-09-05 17:15, reason: User, spinning module LinuxInterface, available RAM 74692 bytes (slot 0)
                                      Error status: 0
                                      MCU temperature: min 36.1, current 41.6, max 41.7
                                      Driver 0: standstill, reads 53593, writes 17 timeouts 0, SG min/max 0/216
                                      Driver 1: standstill, reads 53594, writes 17 timeouts 0, SG min/max 0/165
                                      Driver 2: standstill, reads 53594, writes 17 timeouts 0, SG min/max 0/104
                                      Driver 3: standstill, reads 53594, writes 17 timeouts 0, SG min/max 0/98
                                      Driver 4: standstill, reads 53595, writes 17 timeouts 0, SG min/max 0/103
                                      Driver 5: standstill, reads 53595, writes 17 timeouts 0, SG min/max 0/210
                                      Date/time: 2020-09-06 03:21:15
                                      Slowest loop: 5.23ms; fastest: 0.14ms
                                      === Storage ===
                                      Hiccups: 0(0), FreeDm: 375, MinFreeDm: 340, MaxWait: 1539522ms
                                      === MainDDARing ===
                                      Scheduled moves: 1396, completed moves: 1396, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                                      === AuxDDARing ===
                                      Segments left: 0
                                      === Network ===
                                      Slowest loop: 2.14ms; fastest: 0.01ms
                                      • Ethernet -
                                        State: disabled
                                        === CAN ===
                                        Messages sent 6679, longest wait 0ms for type 0
                                        State: 0, failed transfers: 2
                                        Last transfer: 22ms ago
                                        RX/TX seq numbers: 54222/54222
                                        SPI underruns 3, overruns 3
                                        Buffer RX/TX: 0/0-0
                                        Full transfers per second: 14.09
                                      • mrenz999undefined
                                        mrenz999 @Phaedrux
                                        @Phaedrux
                                        Written by Christian Hammacher for Duet3D
                                        Licensed under the terms of the GNU Public License Version 3
                                        [info] Settings loaded
                                        [info] Environment initialized
                                        [fatal] Could not connect to Duet (Board is not available (no header))
                                        [debug] System.OperationCanceledException: Board is not available (no header)
                                        at DuetControlServer.SPI.DataTransfer.ExchangeHeader() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 1093
                                        at DuetControlServer.SPI.DataTransfer.PerformFullTransfer(Boolean connecting) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 162
                                        at DuetControlServer.SPI.DataTransfer.Init() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/SPI/DataTransfer.cs:line 102
                                        at DuetControlServer.Program.Main(String[] args) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Program.cs:line 10
                                        This is what i get when I try to run debug
                                          Phaedrux Moderator @mrenz999
                                          If it's small enough you can upload it here. If it's too large try zipping it and use dropbox or something like that to share it.
                                          • mrenz999undefined
                                            mrenz999 @Phaedrux
                                            @Phaedrux
                                            https://www.dropbox.com/s/c1a8ve3eq0kahxr/CFFFP_lotus_nightlight.gcode?dl=0
                                            Constant G28 network errors pop up.
