    How to specify exact probing points in config.g
    831
    • PCRundefined
      PCR
      and where is the probe located ?
      The Value of X0:218 is calculated with the offset of the probe. So if you have the probe on the left side of the printer it trys to prope at 218mm but you head is then over the limit of the x axis.
      so if your probe is 20mm to the left try
      X0:198
      • deonholtundefined
        deonholt @PCR
        @PCR
        G31 P500 X-45 Y-12.20 Z2.965
        • PCRundefined
          PCR
          then try
          M557 X0:173 Y20:219 P3
          Vetiundefined deonholtundefined 2 Replies Last reply Reply Quote 0
          • deonholtundefined
            deonholt @Veti
            @Veti
            This is my offset:
            So, I need to know how to enter a single probe position so that I can see where it probes. I want to use X110 Y110 as a test.
            • Vetiundefined
              Veti @PCR
              @PCR said in How to specify exact probing points in config.g:
              dont forget the y
              so
              M557 X0:173 Y0:205 P3
              • PCRundefined
                PCR
                @deonholt
                @Veti is right try
                M557 X0:173 Y0:219 P3
                • Vetiundefined
                  Veti @PCR
                  @PCR
                  his bed is 218 so 218-12.2=205
                  PCRundefined 1 Reply Last reply Reply Quote 1
                  • deonholtundefined
                    deonholt @PCR
                    @PCR
                    Thanks, will quickly try it. 🤞
                    Update: It probed 6 points. It started off promising but stopped after 6 with these errors:
                    G32
                    Warning: Skipping grid point (0.0, 219.0) because Z probe cannot reach it
                    Warning: Skipping grid point (86.5, 219.0) because Z probe cannot reach it
                    Warning: Skipping grid point (173.0, 219.0) because Z probe cannot reach it
                    6 points probed, min error -0.011, max error 0.049, mean 0.013, deviation 0.022
                    Height map saved to file heightmap.csv
                    • Vetiundefined
                      Veti @deonholt
                      @deonholt
                      use the values i posted
                      deonholtundefined 1 Reply Last reply Reply Quote 0
                      • PCRundefined
                        PCR @Veti
                        @Veti long day 😉 You are right !
                        • deonholtundefined
                          deonholt @Veti
                          @Veti
                          Thank you SO MUCH, guys.
                          M557 X0:173 Y0:205 P3 did it. I REALLY appreciate your time & patience. 👏 🏅
