    [3.1.1] Issue Parsing Layer Change
    Firmware developers
    1.6k
      ;FLAVOR:Marlin
      Checking your gcode file again I notice that you have Cura set to marlin gcode flavor. Change that to reprap. In the printer profile. Cura may be inserting some unsupported gcodes that could be confusing things.
      Simulation behaves a bit differently than normal printing, so that's an interesting observation.
      • CCS86undefined
        CCS86
        Good eye! I'm not sure what happened there. My printer has always been set to Reprap flavor. That was just a test export, and maybe Cura reverted the setting.
        I just double checked the latest gcode file BBT32.gcode and it was definitely set to reprap.
        Here is the file, zipped. Just remove the txt extension and extract.
        BBT32.zip.txt
        • CCS86undefined
          CCS86
          Any updates on this guys?
          @dc42 @Phaedrux
          The issue persists.
            Does it still happen if you don't use the leveling mesh optimizer?>
            M557 X26.118:63.254 Y51.314:88.450 S10.000 ; Leveling mesh defined by LevelingMeshOptimizer
            CCS86undefined 1 Reply Last reply Reply Quote 0
            • CCS86undefined
              CCS86 @Phaedrux
              @Phaedrux said in [3.1.1] Issue Parsing Layer Change:
              Are you saying without an M557 command at all? I have not tried that. Could mesh leveling really bork DWC's layer parsing?
                I mean without running the preparser. Perhaps it's changing more than expected.
                  ;FLAVOR:RepRap
                  ;TIME:2524
                  ;Filament used: 0.926325m
                  ;Layer height: 0.15
                  ;MINX:26.118
                  ;MINY:51.314
                  ;MINZ:0.2
                  ;MAXX:63.254
                  ;MAXY:88.45
                  ;MAXZ:12.65
                  ;POSTPROCESSED
                  ;Generated with Cura_SteamEngine 4.6.2
                  T0
                  M82 ;absolute extrusion mode
                  ;//////// START GCODE \\\\\\\\
                  G90                                          ; abs pos
                  M82                                          ; abs ext
                  M106 S0                                      ; fan off
                  M104 S170                                    ; Set hotend
                  M140 R35     ; Set bed
                  G28                                          ; Home
                  M109 S170                                    ; Wait for hotend
                  M190 R35     ; Wait for bed
                  G29 S0                                       ; Load bed mesh
                  M376 H3                                      ; Mesh taper
                  G1 Z60.0 F5000                               ; Lift
                  G92 E0                                       ; Zero extruder
                  G1 X20 Y20 E-4 F4000
                  M109 S220   ; Wait for hotend
                  G1 X10 Y0 Z.3 F2000
                  G1 E0 F2000
                  G1 X50 E5 F1200
                  G1 X140 E11 F1200
                  G1 Y2 Z.1 F9000
                  G4 S2
                  G1 Y3 F9000
                  G1 X20 Z.07 F9000
                  G1 Z5 ;E
                  G92 E-.7                                      ; Comp for ooze
                  G92 E0
                  G92 E0
                  G1 F2100 E-2
                  ;LAYER_COUNT:84
                  ;LAYER:0
                  M107
                  G0 F4533.3 X34.449 Y54.369 Z0.2
                  ;TYPE:SKIRT
                  G1 F2100 E0
                  G1 F1200 X34.867 Y54.114 E0.00614
                  G1 X35.321 Y53.931 E0.01228
                  G1 X35.799 Y53.824 E0.01842
                  G1 X36.288 Y53.796 E0.02456
                  G1 X36.5 Y53.819 E0.02724
                  G1 X36.584 Y53.667 E0.02942
                  You've also got this big Z move in there
                  Maybe add a ;E after that one as well.
                  • CCS86undefined
                    CCS86 @Phaedrux
                    @Phaedrux
                    Does ;E have any special function? I thought DWC was just ignoring Z moves that had any comment attached.
                      It will ignore any G1 Z moves that have an extrusion parameter with them. That's why adding the ;E is a thing.
                      Another way around it is to place any start and end scripting in the start.g and stop.g files. Start.g gets run before the sliced gcode file starts, so you can move a lot of the prep there. And stop.g gets called by M0 which you would put in the slicer end gcode.
                      • CCS86undefined
                        CCS86 @Phaedrux
                        Cool, I might move my start/stop stuff there just to clean things up. I would only put M0 in my slicer end gcode?
                        The thing that sticks out to me is that when I simulate the same file it tracks layers just fine. If it was just syntax of my gcode, how could this happen?
                          Phaedrux Moderator @CCS86
                          @CCS86 said in [3.1.1] Issue Parsing Layer Change:
                          If you want. M0 will call stop.g so if you want to move all your end gcode into there you can.
                          • CCS86undefined
                            CCS86
                            Hmmm, I was looking at moving my start gcode, but realized I rely on the slicer's ability to pass bed and hotend temps into that code, so it doesn't seem practical to do so.
                              That's still doable, but may require splitting your start stuff into two sections. Here's what I do to preserve the slicer temp settings.
                              Start.g contains the print prep. Then passes off to the slicer for temp settings. And then a macro is called to do a prime line once temps are reached.
                              M106 P2 F15000 L0.1 X0.8 B0.5 T25:40 H100:101:102 C"Duet Fans"
                              M106 P0 F100 S0 H-1 B0.5 C"Part Cooling"                             ; Set fan 0 (Part cooling blower) G-code controlled. Thermostatic control is turned off
                              M140 S65		; set heated bed to 65 and release
                              T0			; Select Tool 0
                              M291 P"Print Started. Preheating and Homing." T10
                              G4 S1
                              M98 P"0:/macros/Musical Tunes/LuckyTune.g" ; Lucky tune to start print off on the right foot
                              G4 S1
                              M220 S100		; Set speed factor back to 100% in case it was changed
                              M221 S100		; Set extrusion factor back to 100% in case it was changed
                              M290 R0 S0		; clear babystepping
                              M106 S0			; Turn part cooling blower off if it is on
                              G10 P0 R0 S80		; Set extruder to 80 and release
                              M190 S65		; set heated bed to 65 and wait
                              G28			; home XYZ
                              G29 S1			; load heightmap
                              M400
                              G10 P0 R80 S180	; Set extruder to 180 and release
                              M98 P"0:/sys/ZSpeedsPrint.g"	; Load Z speeds for printing
                              M98 P"0:/sys/CurrentsPrint.g"	; Load print motor currents
                              ; Slicer Start Gcode begins.
                              ; Prusa slic3r start gcode
                              ; note that bed temp is inserted before this by the slicer since I haven't tried to define it here.
                              M109 S[first_layer_temperature]	; Set extruder to first layer temp and wait
                              G10 P0 R100 S[first_layer_temperature]  ; set temp and standby temp
                              M116 ; wait for temps
                              G28 Z
                              M98 P"0:/sys/PrimeNozzle.g"
                              ;M98 P"0:/sys/PrimeNozzle.g"
                              G90 			; Absolute positioning
                              G1 X1 Y270 F6000 	; Move to front left corner
                              M400 			; clear movement buffer
                              M116 			; Wait for temps
                              G1 Z0.3 F100		; Move Z to prime height
                              G91 			; Relative positioning
                              M83 			; Relative extrusion
                              G1 E5 F300 ; pre-prime nozzle
                              G1 X40 E10 F300 	; Prime line
                              G10			; Retract
                              G1 Y-1 X1 F10000 	; Wipe nozzle
                              M400
                              • CCS86undefined
                                CCS86
                                I put ;E comments on every line in my start gcode with a Z move, and even tried running code from Superslicer. The result is the same.
                                  65ecb416-4221-422e-9eae-f20167c9ba1e-image.png Screen Shot 2020-09-23 at 9.49.02 PM.png
                                  Here's what I get with a DuetWifi fw and DWC 3.1.1 sliced with Super Slicer. Again, I don't have any gcode commands in my start gcode section other than calling a macro and M0 at the end.
                                  I suggest trying to reflash your firmware and DWC version.
                                  Download this zip file and upload it as is to the sys folder. Don't extract it.
                                  https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
                                  • CCS86undefined
                                    CCS86
                                    Tried that, but it still doesn't seem to be working:
                                    It always seems to know the correct total layer count. It always seems to start at "layer 2". There seems to be an arbitrary time associated with this starting layer.
                                      Have you tried migrating to using start.g and stop.g yet?
                                      • CCS86undefined
                                        CCS86 @Phaedrux
                                        Not yet. But with this version RRF and DWC it was working fine in the past. I'm not sure if some subtle tweak to the start gcode broke it, or what.
                                        It would be awesome if a dev could run through debug with the gcode I posted. Maybe it is getting tripped up on something we haven't noticed.
                                        The only thing I can think of that I changed, is putting a larger SD card in. But, I am unsure if it was before/after layer parsing broke,.
                                          Can you show your current start and end gcode?
                                          • CCS86undefined
                                            CCS86
                                            G90                                          ; abs pos
                                            M82                                          ; abs ext
                                            M106 S0                                      ; fan off
                                            M140 R33                                      ; Set bed
                                            G28                                           ; Home
                                            M190 R33                                    ; Wait for bed
                                            G4 S10                                       ; Pause
                                            M557 X12:201 Y34:151 P12:9
                                            G29 S0                                      ; Probe bed mesh
                                            G1 Z60.0 F5000                              ; E
                                            M109 S210                                    ; Wait for hotend
                                            G1 X10 Y0 Z.3 F2000	                     ;E
                                            G1 E0 F2000
                                            G1 X50 E5 F1200
                                            G1 X140 E11 F1200
                                            G1 Y2 Z.1 F9000 		             ;E
                                            G4 S2
                                            G1 Y3 F9000
                                            G1 X20 Z.07 F9000 	                     ;E
                                            G1 Z5 			                     ;E
                                            ;////// END GCODE \\\\\\
                                            M400 ;wait for clear buffer
                                            G91 ;relative positioning
                                            M83 ;relative extruder
                                            G1 Z5 E-3 F4000
                                            G28 XY
                                            G1 E3 F1500
                                            M106 S128
                                            M104 S0 ;extruder heater off
                                            M140 S0 ;heated bed heater off
                                            M18 ;steppers off
                                            G4 S120
                                            M106 S0
