Triple Z motors not correcting
440
    mrenz999
    When I run bed leveling it checks all lead screws and then seems to tilt the wrong way.
    ; bed.g
    ; generated by RepRapFirmware Configuration Tool v3.1.1 on Thu Jun 04 2020 11:20:24 GMT-0700 (Pacific Daylight Time)
    G28 ; home
    ;M401 ; deploy Z probe
    G30 P0 X20 Y250 Z-99999 ; probe near an adjusting screw
    G30 P1 X450 Y80 Z-99999 ; probe near an adjusting screw
    G30 P2 X450 Y420 Z-99999 S3 ; probe near an adjusting screw and calibrate 3 motors
    ;G29
    ;M402 ; retract probe
    Is there an order that should be setup for which is right or left ? Current configuration is 0,0 far left.
      nriviera
      You're correct in that the error is in your config file with the order in the M671. Annoyingly you can't make each Z axis move independent of the other to test that they are correct in the config. I just trial and error'd my way around until I got it correct.
      undefined 1 Reply Last reply 15 Sept 2020, 03:52 Reply Quote 0
        Phaedrux Moderator @nriviera
        @nriviera said in Triple Z motors not correcting:
        You can if you temporarily bind each Z motor driver to its own axis. Then you can move them independently manually. Just be careful not to rip your bed apart.
        @mrenz999 said in Triple Z motors not correcting:
        Far left as in rear left? That may be a bit of a problem as you're not using a right handed coordinate system. 0,0 should be in the front left, +X to the right, -X to the left, -Y to the front, +Y to the back.
        Regardless, this is the key part of the configuration that you're missing
        You must use the M671 command to define the X and Y coordinates of the leadscrews. The M671 command must come after the M584 command and must specify the same number of X and Y coordinates as the number of motors assigned to the Z axis in the M584 command; and these coordinates must be in the same order as the driver numbers of the associated motors in the M584 command. The M671 command must also come after any M667 or M669 command.
        https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
        undefined 1 Reply Last reply 15 Sept 2020, 04:17 Reply Quote 0
          mrenz999 @Phaedrux
          @Phaedrux A right handed system ? My endstops are Y to the far rear and x to the left. Therefore, Y + is towards the front and X+ is to the right.
            left_right_hand.gif dbot axis.png Cartesian-coordinate-system.png Bed Area.png
            With Y flipped like that you're likely to get mirrored prints.
            Your Y axis endstop is at the high end of travel in that case and when triggered would set the coordinate position to the M208 Y maxima, rather than 0.
            undefined 1 Reply Last reply 15 Sept 2020, 04:24 Reply Quote 0
              mrenz999 @Phaedrux
              @Phaedrux As my endstops are to the rear and left what should I change to make that flip without changing where the endstops are ?
                Post your config.g and homeall.g
                M574 Y2 and in homeall the direction of the Y homing move would be positive instead of negative.
                If this is corexy you'll also need to do some tests to verify your motor connections and rotation directions are correct.
                https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Testing_motor_movement
                undefined 1 Reply Last reply 15 Sept 2020, 04:31 Reply Quote 0
                  mrenz999 @Phaedrux
                  @Phaedrux
                  ; generated by RepRapFirmware Configuration Tool v3.1.1 on Thu Jun 04 2020 11:20:25 GMT-0700 (Pacific Daylight Time)
                  G91 ; relative positioning
                  G1 H1 X-450 Y-450 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                  G1 H1 X-450
                  G1 H1 Y-450
                  G1 H1 X-450 Y-450 F360 ; move slowly to X and Y axis endstops once more (second pass)
                  G1 X264 Y250 F9000 ; go to first bed probe point and home Z
                  G30 ; probe the bed
                  ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 16 2020 08:02:01 GMT-0700 (Pacific Daylight Time)
                  G21 ; Set units to MM
                  M550 P"Duet 3" ; set printer name
                  M669 K1 ; select CoreXY mode
                  ;Network
                  M552 S1 ; enable network
                  M586 P0 S1 ; enable HTTP
                  M586 P1 S0 ; disable FTP
                  M586 P2 S0 ; disable Telnet
                  M569 P0.0 S0 ; physical drive 0.0 goes forwards
                  M569 P0.1 S1 ; physical drive 0.1 goes backwards
                  M569 P0.2 S0 ; physical drive 0.2 goes forwards
                  M569 P0.3 S0 ; physical drive 0.3 goes forwards
                  M569 P0.4 S1 ; physical drive 0.4 goes backwards
                  M569 P0.5 S0 ; physical drive 0.3 goes forwards
                  M584 X0.0 Y0.1 Z0.2:3:4 E0.5 ; set drive mapping
                  M92 X80.00 Y80.00 Z400.00 E405.18 ; set steps per mm
                  M566 X600.00 Y600.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
                  M203 X20000 Y20000 Z600 E2000.00 ; set maximum speeds (mm/min)
                  M201 X3000.00 Y3000.00 Z600.00 E5000.00 ; set accelerations (mm/s^2)
                  M906 X1600 Y1600 Z1600 E1600 I30 ; set motor currents (mA) and motor idle factor in per cent
                  M84 S30 ; Set idle timeout
                  M671 X20:20:430 Y110:365:240 S9 ; leadscrews at rear left, front middle and rear right
                  M208 X-20 Y-15 Z0 S1 ; set axis minima
                  M208 X500 Y500 Z465 S0 ; set axis maxima
                  M574 X1 S1 P"!io0.in" ; configure active-high endstop for low end on X via pin !io0.in
                  M574 Y1 S1 P"!io1.in" ; configure active-high endstop for low end on Y via pin !io1.in
                  ;M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
                  ;M558 P9 C"^io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds height + speeds
                  ;G31 P500 X-40 Y-10 Z6 ; set Z probe trigger value, offset and trigger height
                  M557 X20:430 Y15:410 S20 ; define mesh grid
                  Z-Probe
                  M558 P8 C"^io7.out"
                  G31 P500 X-20 Y-15 Z2
                  M308 S0 P"temp0" Y"thermistor" T100000 B4008 ; configure sensor 0 as thermistor on pin temp0
                  M308 S1 P"temp1" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin temp1
                  M143 H1 S300
                  M307 H0 A188.5 C683.1 D0.2 S1.0 V24.1 B0
                  M307 H1 A351.2 C120.5 D7.2 S1.0 V24.1 B0
                  M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
                  M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
                  M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
                  M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
                  M950 F2 C"out9" Q500 ; create fan 2 on pin out9 and set its frequency
                  M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
                  T0
                  M501
                    Veti
                    are you sure thats correct? this would mean the leadscrews are inside the bed.
                    undefined 1 Reply Last reply 15 Sept 2020, 04:36 Reply Quote 0
                      mrenz999 @Veti
                      @Veti It's the probe spot. On the bed where it can probe closest to the leadscrew.
                      undefined 1 Reply Last reply 15 Sept 2020, 04:42 Reply Quote 0
                        G1 H1 X-450
                        G1 H1 Y-450
                        G30 ; probe the bed
                        In your homeall switch the direction of all the Y moves as shown here. Also the move to position the probe should probably be defined in absolute coordinates.
                        G1 H1 X-450 Y450 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                        G1 H1 X-450
                        G1 H1 Y450
                        G1 X5 Y-5 F6000 ; go back a few mm
                        G1 H1 X-450 Y450 F360 ; move slowly to X and Y axis endstops once more (second pass)
                        G90 ; absolute position
                        G30 ; probe the bed
                        Then in config.g you'd need to change the M574 for the Y axis to tell it the endstop is at the high end. That's Y2 instead of Y1
                        M574 Y2 S1 P"!io1.in" ; configure active-high endstop for low end on Y via pin !io1.in
                        The order and position of the lead screws will need to change, first to match the order of the motors defined in M584 but also the coordinates will be different now that your Y axis is flipped.
                        And as Veti says, try to estimate where the lead screws are actually positioned in absolute space relative to the 0,0 position in the front left corner even if they are outside the reachable area. It's only the points defined in the bed.g that need to be within the reachable area.
                        Which leads us to the bed.g points. You'll need to amend those as well now that the Y axis is flipped.
                        Also, don't forget to do those motor movement tests for corexy I linked.
                        Oh and your Z probe offset will need to be redone to reflect the new Y axis direction.
                        Oh and you might want to edit homey.g as well to change the directions of the homing moves.
                          Veti @mrenz999
                          those go in the bed.g not the M671 command.
                          the M671 are the actual positions of the leadscrew.
                          9 out of 12
