    Random Smart Effector flashes
    1.9k
    • sankafolaundefined
      sankafola
      No it flashes while its standing still and when this happen i get this output after the G32 , i know during printing its normal to flash but while standing still doing nothing ?!!
      9/13/2020, 11:49:32 AM G32
      Error: Z probe already triggered at start of probing move
      Error: Z probe was not triggered during probing move
      Carloundefined 1 Reply Last reply Reply Quote 0
      • Carloundefined
        Carlo @sankafola
        @sankafola
        Normally caused by fan noise
        or it's a bad crimp/solder joint either end
          sankafola
          but that are the 2 things i mentioned in my post which i checked and its not that
          1-fan noise
          2-wire crimp of the wires on the 8 pin connectors
          anything else ?
            Give it the old disassemble and reassemble? While it's apart take some photos of both sides of the PCB for us to see?
              sankafola
              sure here it is A5D23D63-45D9-4E43-8A8C-C9BCB945493C_1_105_c.jpeg DAD4CB33-CA84-4C4E-916A-758A37DD59CB_1_105_c.jpeg
                Is that a scuff on the traces of the strain gauge?
                If you inspect the surface of the PCB closely do you see any scratches?
                  sankafola
                  this is 60X 687C3679-82A8-4E9B-8259-0F92CE8FD4CB_1_105_c.jpeg D3BDC379-5504-40C9-820C-4B6CE885C1CB_1_105_c.jpeg 3FA23226-F3B4-4030-987A-F43F96D51375_1_105_c.jpeg
                    That does look like some damage.
                      sankafola
                      that means i need to buy a new one or this can be fixed ?
                        A Former User @sankafola
                        @sankafola said in Random Smart Effector flashes:
                        depends on how handy you are with a soldering iron; you could try to take some abrasive to the area and abrade off the blue layer getting down to the copper traces and soldering some bridges across.
                          Phaedrux Moderator @A Former User
                          @bearer That's more optimistic than my answer was going to be.
                            A Former User @Phaedrux
                            @Phaedrux said in Random Smart Effector flashes:
                            🙂 i've been around too much bob the builder watching little people - the optimism seems to rubs off no matter how hard i try to resist!
                            however no doubt about it, its fiddly work, but certainly possible.
                            sankafolaundefined 1 Reply Last reply Reply Quote 0
                              sankafola
                              this pic are x60 times the size , my iron is bigger than 2 lines no way to solder 😞
                                sankafola @A Former User
                                @bearer the idea is to solder the cut off lines right /?
                                  if its just a hairline break in the trace you'd probably be okay with some tacky flux and just dragging the tip across with a little solder on to bridge the gap; but some experience would help
                                    A Former User
                                    if you have a meter you could try measuring the resistance across as shown on the back of the board? (power off)
                                      sankafola
                                      you mean U3 ? and U1 ?
                                        A Former User
                                        close up: (edit: maybe not having it mirrored helps..)
                                        R11, and R14 as indicated by the tall elipses.
                                        then compare to the other half of the bridge on R11 and R13 as indicated by the wide elipses?
                                        B and T on the schematic are essientially 10k resistors in the form of PCB traces, and you're trying to measure if they are different:
                                        sankafolaundefined 2 Replies Last reply Reply Quote 0
                                          sankafola
                                          31.5 ohms and 34 ohms
                                            @bearer R 11 red to black R 14 is 31.5 and red to R13 is 34 ohms
