    Random Smart Effector flashes
    1.9k
    • sankafolaundefined
      sankafola
      sure here it is A5D23D63-45D9-4E43-8A8C-C9BCB945493C_1_105_c.jpeg DAD4CB33-CA84-4C4E-916A-758A37DD59CB_1_105_c.jpeg
        Is that a scuff on the traces of the strain gauge?
        If you inspect the surface of the PCB closely do you see any scratches?
          sankafola
          this is 60X 687C3679-82A8-4E9B-8259-0F92CE8FD4CB_1_105_c.jpeg D3BDC379-5504-40C9-820C-4B6CE885C1CB_1_105_c.jpeg 3FA23226-F3B4-4030-987A-F43F96D51375_1_105_c.jpeg
            That does look like some damage.
              sankafola
              that means i need to buy a new one or this can be fixed ?
                A Former User @sankafola
                @sankafola said in Random Smart Effector flashes:
                depends on how handy you are with a soldering iron; you could try to take some abrasive to the area and abrade off the blue layer getting down to the copper traces and soldering some bridges across.
                  Phaedrux Moderator @A Former User
                  @bearer That's more optimistic than my answer was going to be.
                    A Former User @Phaedrux
                    @Phaedrux said in Random Smart Effector flashes:
                    🙂 i've been around too much bob the builder watching little people - the optimism seems to rubs off no matter how hard i try to resist!
                    however no doubt about it, its fiddly work, but certainly possible.
                    sankafolaundefined 1 Reply Last reply Reply Quote 0
                      sankafola
                      this pic are x60 times the size , my iron is bigger than 2 lines no way to solder 😞
                        sankafola @A Former User
                        @bearer the idea is to solder the cut off lines right /?
                          if its just a hairline break in the trace you'd probably be okay with some tacky flux and just dragging the tip across with a little solder on to bridge the gap; but some experience would help
                            A Former User
                            if you have a meter you could try measuring the resistance across as shown on the back of the board? (power off)
                              sankafola
                              you mean U3 ? and U1 ?
                                A Former User
                                close up: (edit: maybe not having it mirrored helps..)
                                R11, and R14 as indicated by the tall elipses.
                                then compare to the other half of the bridge on R11 and R13 as indicated by the wide elipses?
                                B and T on the schematic are essientially 10k resistors in the form of PCB traces, and you're trying to measure if they are different:
                                sankafolaundefined 2 Replies Last reply Reply Quote 0
                                  sankafola
                                  31.5 ohms and 34 ohms
                                    @bearer R 11 red to black R 14 is 31.5 and red to R13 is 34 ohms
                                      to the top strain gauge is 31.5 and the bottom is 34; not convinced the traces in that strain gauge are broken - but probably best to see if the Duet people has something to say about it before drawing conclusions
                                      (I'm usually in the "know enough to be dangerous" category..:)
                                        T3P3Tony administrators
                                        Tf the top and bottom traces compete read ~30Ohms each then the score has not gone through them completely.
                                        Have you tried adjusting the sensitivity down to see if you can get a range that it triggers reliably when it taps on the bed (be careful, maybe hold a hard surface higher for initial tests and be prepared to cut power).
                                        https://duet3d.dozuki.com/Wiki/Smart_effector_and_carriage_adapters_for_delta_printer#Section_Programming_the_sensitivity
                                          sankafola
                                          it is working but sometimes it just flash by itself and i dont think any traces of touch on these gauge is doing it because if it is why its not doing it all the time ??!!
                                            sankafola @T3P3Tony
                                            @T3P3Tony am using SKR 1.4 Turbo not duet , so my MOD pin is not connected to anything right now ,
                                            let me just explain what is the issue i see , the smart effector works fine and do auto claib and all is good but all of sudden it start to flash even if its not doing anything , if i reboot the printer and it become normal again
