    Temprature sensor error unknown temperature sensor channel
    Firmware installation
    4.7k
    • JTMundefined
      JTM @Phaedrux
      @Phaedrux version 3 now
        Alright, if 3.0 is installed you should try replacing the DWC files with the zip linked above. That may get you back on track.
        Once in the web interface, just upload the whole 3.0 zip file as is to the /sys folder in DWC. Then upload the 3.1.1 zip file. Don't extract them first.
        JTMundefined 1 Reply Last reply Reply Quote 0
        • JTMundefined
          JTM @Phaedrux
          @Phaedrux i cant get in the web interface it is just a blank screen? sorry to be such a pain .
            Phaedrux Moderator @Phaedrux
            @Phaedrux said in Temprature sensor error unknown temperature sensor channel:
            If the web interface wasn't updated along the way with the firmware, you can manually install the DWC files by extracting the DWC zip file into the /www folder on the SD card with your PC.
            https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/DuetWebControl-SD-3.1.1.zip
            You'll have to do this.
            • JTMundefined
              JTM @Phaedrux
              @Phaedrux im hopeless at this stuff ! i loaded that file onto the sd card and now i get this message from the web face
              Your Duet rejected the HTTP request: page not found
              Check that the SD card is mounted and has the correct files in its /www folder
              • Vetiundefined
                Veti @JTM
                @JTM said in Temprature sensor error unknown temperature sensor channel:
                you have to upack the zip file
                the content of the zip file has to be in the folder www on the sd card
                JTMundefined 2 Replies Last reply Reply Quote 0
                • JTMundefined
                  JTM @Veti
                  @Veti i extracted those files to the sd card www file? is that right?
                  • JTMundefined
                    JTM @Veti
                    @Veti i switched it on and off and now its working !!!! i have web interface again !
                    • JTMundefined
                      JTM
                      now my zprobe doesnt deploy 😞 on the bright side the temp probe is showing temp, but when i tried to heat the hotend i got an error it was too slow.
                        Alright you're getting somewhere.
                        Have you uploaded the 3.0 and 3.1.1 zip files?
                        • JTMundefined
                          JTM @Phaedrux
                          @Phaedrux yes mate, when sending the M115 command i now get firmware 3.1.1
                            The heaters will need to be PID tuned. That should get rid of the too slow error.
                            Here's how: https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s161
                            For the probe please post your config.g and deployprobe.g and retractprobe.g macros from the /sys folder. Also homeall.g
                            Copy and paste the text here.
                            • JTMundefined
                              JTM @Phaedrux
                              @Phaedrux the z probe code
                              M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
                              M558 M558 P9 H5 F100 T2000 ; set Z probe type to bltouch and the dive height + speeds
                              G31 X0 Y0 Z0 P25 ; set Z probe trigger value, offset and trigger height
                              • JTMundefined
                                JTM @Phaedrux
                                @Phaedrux deploy probe M280 P3 S10 I1 ; deploy BLTouch
                                retract probe M280 P3 S90 I1 ; retract BLTouch
                                homeall G91 ; relative positioning
                                G1 H1 X-505 Y-455 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
                                G1 H2 X5 Y5 F6000 ; go back a few mm
                                G1 H1 X-505 Y-455 F600 ; move slowly to X and Y axis endstops once more (second pass)
                                G90 ; absolute positioning
                                G1 X15 Y15 F6000 ; go to first bed probe point and home Z
                                ;G91 ; relative positioning
                                ;G90 ; absolute positioning
                                  In the deploy and retract files change the P3 to P0 and remove the I1
                                  • JTMundefined
                                    JTM @Phaedrux
                                    @Phaedrux i changed the macro test files to P0 and delted the I1 but didnt work, re added the I1 and the macros work, but when i try to home z i get this error message?
                                    G28 Z
                                    Error: in file macro line 9: G30: Z probe 0 not found
                                    Error: Homing failed
                                    • JTMundefined
                                      JTM
                                      thanks everyone for your help, it is really appreciated !
                                        Phaedrux Moderator @JTM
                                        Does that line in your config.g actually have double M558 at the start?
                                        Can you post your full config.g?
                                        • JTMundefined
                                          JTM @Phaedrux
                                          @Phaedrux copy and pasted full config.g file :
                                          M550 P"My Printer" ; set printer name
                                          M552 S1 ; enable network
                                          M586 P0 S1 ; enable HTTP
                                          M586 P1 S0 ; disable FTP
                                          M586 P2 S0 ; disable Telnet
                                          M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
                                          M906 X1200 Y1200 Z1500 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
                                          M84 S30 ; Set idle timeout
                                          M208 X500 Y450 Z500 S0 ; set axis maxima
                                          M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                                          M307 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
                                          M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs1
                                          M950 H1 C"e0_heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1
                                          ;Miscellaneous
                                          M575 P1 S1 857600
                                          Phaedruxundefined droftartsundefined 4 Replies Last reply Reply Quote 0
                                            You've got M558 in there twice. Take one of them out.
