Temprature sensor error unknown temperature sensor channel
@Phaedrux i cant get in the web interface it is just a blank screen? sorry to be such a pain .
@Phaedrux said in Temprature sensor error unknown temperature sensor channel:
If the web interface wasn't updated along the way with the firmware, you can manually install the DWC files by extracting the DWC zip file into the /www folder on the SD card with your PC.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/DuetWebControl-SD-3.1.1.zip
You'll have to do this.
@Phaedrux im hopeless at this stuff ! i loaded that file onto the sd card and now i get this message from the web face
Your Duet rejected the HTTP request: page not found
Check that the SD card is mounted and has the correct files in its /www folder -
@JTM said in Temprature sensor error unknown temperature sensor channel:
you have to upack the zip file
the content of the zip file has to be in the folder www on the sd card
@Veti i extracted those files to the sd card www file? is that right?
@Veti i switched it on and off and now its working !!!! i have web interface again !
now my zprobe doesnt deploy on the bright side the temp probe is showing temp, but when i tried to heat the hotend i got an error it was too slow.
Alright you're getting somewhere.
Have you uploaded the 3.0 and 3.1.1 zip files?
Alright, if 3.0 is installed you should try replacing the DWC files with the zip linked above. That may get you back on track.
Once in the web interface, just upload the whole 3.0 zip file as is to the /sys folder in DWC. Then upload the 3.1.1 zip file. Don't extract them first.
@Phaedrux yes mate, when sending the M115 command i now get firmware 3.1.1
The heaters will need to be PID tuned. That should get rid of the too slow error.
Here's how: https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s161
For the probe please post your config.g and deployprobe.g and retractprobe.g macros from the /sys folder. Also homeall.g
Copy and paste the text here.
@Phaedrux the z probe code
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 M558 P9 H5 F100 T2000 ; set Z probe type to bltouch and the dive height + speeds
G31 X0 Y0 Z0 P25 ; set Z probe trigger value, offset and trigger height
M557 X15:215 Y15:195 S20 ; define mesh grid -
@Phaedrux deploy probe M280 P3 S10 I1 ; deploy BLTouch
retract probe M280 P3 S90 I1 ; retract BLTouch
homeall G91 ; relative positioning
G1 H1 X-505 Y-455 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-505 Y-455 F600 ; move slowly to X and Y axis endstops once more (second pass)
G90 ; absolute positioning
G1 X15 Y15 F6000 ; go to first bed probe point and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning -
In the deploy and retract files change the P3 to P0 and remove the I1
@Phaedrux i changed the macro test files to P0 and delted the I1 but didnt work, re added the I1 and the macros work, but when i try to home z i get this error message?
G28 Z
Error: in file macro line 9: G30: Z probe 0 not found
Error: Homing failed -
thanks everyone for your help, it is really appreciated !
Does that line in your config.g actually have double M558 at the start?
Can you post your full config.g?
@Phaedrux copy and pasted full config.g file :
M550 P"My Printer" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M906 X1200 Y1200 Z1500 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X500 Y450 Z500 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
M307 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs1
M950 H1 C"e0_heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
;Miscellaneous
M575 P1 S1 857600 -
M557 X15:215 Y15:195 S20 ; define mesh gridYou've got M558 in there twice. Take one of them out.
M575 P1 S1 857600
That should be B57600 not 8
This post is deleted!
