    Temprature sensor error unknown temperature sensor channel
    Firmware installation
    4.7k
    • JTMundefined
      JTM
      now my zprobe doesnt deploy 😞 on the bright side the temp probe is showing temp, but when i tried to heat the hotend i got an error it was too slow.
        Alright you're getting somewhere.
        Have you uploaded the 3.0 and 3.1.1 zip files?
        @Phaedrux said in Temprature sensor error unknown temperature sensor channel:
        Alright, if 3.0 is installed you should try replacing the DWC files with the zip linked above. That may get you back on track.
        Once in the web interface, just upload the whole 3.0 zip file as is to the /sys folder in DWC. Then upload the 3.1.1 zip file. Don't extract them first.
        JTMundefined 1 Reply Last reply Reply Quote 0
        • JTMundefined
          JTM @Phaedrux
          @Phaedrux yes mate, when sending the M115 command i now get firmware 3.1.1
            The heaters will need to be PID tuned. That should get rid of the too slow error.
            Here's how: https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s161
            For the probe please post your config.g and deployprobe.g and retractprobe.g macros from the /sys folder. Also homeall.g
            Copy and paste the text here.
            JTMundefined 2 Replies Last reply Reply Quote 0
            • JTMundefined
              JTM @Phaedrux
              @Phaedrux the z probe code
              M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
              M558 M558 P9 H5 F100 T2000 ; set Z probe type to bltouch and the dive height + speeds
              G31 X0 Y0 Z0 P25 ; set Z probe trigger value, offset and trigger height
              • JTMundefined
                JTM @Phaedrux
                @Phaedrux deploy probe M280 P3 S10 I1 ; deploy BLTouch
                retract probe M280 P3 S90 I1 ; retract BLTouch
                homeall G91 ; relative positioning
                G1 H1 X-505 Y-455 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
                G1 H2 X5 Y5 F6000 ; go back a few mm
                G1 H1 X-505 Y-455 F600 ; move slowly to X and Y axis endstops once more (second pass)
                G90 ; absolute positioning
                G1 X15 Y15 F6000 ; go to first bed probe point and home Z
                ;G91 ; relative positioning
                ;G90 ; absolute positioning
                  In the deploy and retract files change the P3 to P0 and remove the I1
                  • JTMundefined
                    JTM @Phaedrux
                    @Phaedrux i changed the macro test files to P0 and delted the I1 but didnt work, re added the I1 and the macros work, but when i try to home z i get this error message?
                    G28 Z
                    Error: in file macro line 9: G30: Z probe 0 not found
                    Error: Homing failed
                    • JTMundefined
                      JTM
                      thanks everyone for your help, it is really appreciated !
                        Phaedrux Moderator @JTM
                        @JTM said in Temprature sensor error unknown temperature sensor channel:
                        Does that line in your config.g actually have double M558 at the start?
                        Can you post your full config.g?
                        • JTMundefined
                          JTM @Phaedrux
                          @Phaedrux copy and pasted full config.g file :
                          M550 P"My Printer" ; set printer name
                          M552 S1 ; enable network
                          M586 P0 S1 ; enable HTTP
                          M586 P1 S0 ; disable FTP
                          M586 P2 S0 ; disable Telnet
                          M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
                          M906 X1200 Y1200 Z1500 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
                          M84 S30 ; Set idle timeout
                          M208 X500 Y450 Z500 S0 ; set axis maxima
                          M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                          M307 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
                          M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs1
                          M950 H1 C"e0_heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1
                          ;Miscellaneous
                          M575 P1 S1 857600
                          Phaedruxundefined droftartsundefined 4 Replies Last reply Reply Quote 0
                            You've got M558 in there twice. Take one of them out.
                              M575 P1 S1 857600
                              That should be B57600 not 8
                                droftarts administrators @JTM
                                This post is deleted!
                                • JTMundefined
                                  JTM @Phaedrux
                                  @Phaedrux Thanks for the help mate, did as you suggested and went to home all axis and got
                                  G28 X
                                  Operation has been cancelled
                                    I suggest going through this guide to ensure endstops are working and motors are moving are going the right direction.
                                    https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
                                    • JTMundefined
                                      JTM @Phaedrux
                                      @Phaedrux Thanks for all your help Mate, still going through the checks, the motors and end stops seem to all be wired correctly and moving the right way, i keep getting this message when homing z
                                      G28 Z
                                      i will keep looking 🙂 the M280 deploy and retract macros work but homing doesnt activate the probe so im guessing the Gcode for homing is missing something?
                                        A Former User
                                        please post your revised config so we can see your current M558 line that configures your z probe
                                        • JTMundefined
                                          JTM @A Former User
                                          @bearerthis is the config.g file
                                          ;Miscellaneous
                                          M575 P1 S1 B57600
                                          M501
                                            A Former User
                                            i think you might need C"^zprobe.in" added to the line with M558?
                                            M558 P9 C"^zprobe.in" H5 F100 T2000 ; set Z probe type to bltouch and the dive height + speeds
                                            edit: presuming thats where your zprobe is connected?
                                            JTMundefined 1 Reply Last reply Reply Quote 1
