    Temprature sensor error unknown temperature sensor channel
    Firmware installation
    4.7k
    • JTMundefined
      JTM @Phaedrux
      @Phaedrux deploy probe M280 P3 S10 I1 ; deploy BLTouch
      retract probe M280 P3 S90 I1 ; retract BLTouch
      homeall G91 ; relative positioning
      G1 H1 X-505 Y-455 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 H2 X5 Y5 F6000 ; go back a few mm
      G1 H1 X-505 Y-455 F600 ; move slowly to X and Y axis endstops once more (second pass)
      G90 ; absolute positioning
      G1 X15 Y15 F6000 ; go to first bed probe point and home Z
      ;G91 ; relative positioning
      ;G90 ; absolute positioning
        In the deploy and retract files change the P3 to P0 and remove the I1
        JTMundefined 1 Reply Last reply Reply Quote 0
        • JTMundefined
          JTM @Phaedrux
          @Phaedrux i changed the macro test files to P0 and delted the I1 but didnt work, re added the I1 and the macros work, but when i try to home z i get this error message?
          G28 Z
          Error: in file macro line 9: G30: Z probe 0 not found
          Error: Homing failed
          • JTMundefined
            JTM
            thanks everyone for your help, it is really appreciated !
              Phaedrux Moderator @JTM
              @JTM said in Temprature sensor error unknown temperature sensor channel:
              M558 M558 P9 H5 F100 T2000 ; set Z probe type to bltouch and the dive height + speeds
              Does that line in your config.g actually have double M558 at the start?
              Can you post your full config.g?
              • JTMundefined
                JTM @Phaedrux
                @Phaedrux copy and pasted full config.g file :
                M550 P"My Printer" ; set printer name
                M552 S1 ; enable network
                M586 P0 S1 ; enable HTTP
                M586 P1 S0 ; disable FTP
                M586 P2 S0 ; disable Telnet
                M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
                M906 X1200 Y1200 Z1500 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
                M84 S30 ; Set idle timeout
                M208 X500 Y450 Z500 S0 ; set axis maxima
                M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
                G31 X0 Y0 Z0 P25 ; set Z probe trigger value, offset and trigger height
                M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                M307 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
                M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs1
                M950 H1 C"e0_heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1
                ;Miscellaneous
                M575 P1 S1 857600
                Phaedruxundefined droftartsundefined 4 Replies Last reply Reply Quote 0
                  You've got M558 in there twice. Take one of them out.
                    M575 P1 S1 857600
                    That should be B57600 not 8
                      droftarts administrators @JTM
                      This post is deleted!
                      • JTMundefined
                        JTM @Phaedrux
                        @Phaedrux Thanks for the help mate, did as you suggested and went to home all axis and got
                        G28 X
                        Operation has been cancelled
                          I suggest going through this guide to ensure endstops are working and motors are moving are going the right direction.
                          https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
                          • JTMundefined
                            JTM @Phaedrux
                            @Phaedrux Thanks for all your help Mate, still going through the checks, the motors and end stops seem to all be wired correctly and moving the right way, i keep getting this message when homing z
                            G28 Z
                            i will keep looking 🙂 the M280 deploy and retract macros work but homing doesnt activate the probe so im guessing the Gcode for homing is missing something?
                              A Former User
                              please post your revised config so we can see your current M558 line that configures your z probe
                              • JTMundefined
                                JTM @A Former User
                                @bearerthis is the config.g file
                                ;Miscellaneous
                                M575 P1 S1 B57600
                                M501
                                  A Former User
                                  i think you might need C"^zprobe.in" added to the line with M558?
                                  M558 P9 C"^zprobe.in" H5 F100 T2000 ; set Z probe type to bltouch and the dive height + speeds
                                  edit: presuming thats where your zprobe is connected?
                                  JTMundefined 1 Reply Last reply Reply Quote 1
                                  • JTMundefined
                                    JTM @A Former User
                                    @bearer said in Temprature sensor error unknown temperature sensor channel:
                                    C"^zprobe.in"
                                    Genius ! thanks mate did the trick now homes all axis ! temp sensor works, extruder works all i need now is to calibrate i think 🙂 woohoo !! thanks so much to everyone for your help !
                                      Can't believe I didn't catch that!
                                      • JTMundefined
                                        JTM @Phaedrux
                                        @Phaedrux you guys are awesome ! appreciate the help as i'm as green as it gets almost ! lol
                                        Ive calibrated my steps so now all axis move the perfect distance, extruder extrudes exactly 100mm when i tell it too, only issue i have is homing Z. I have used the test and calibrate procedure in this link https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                                        i have done the calibration several times i manually move the bed up to be catching a width of paper, send M92 Z0 comand to set sero. i then drop the bed down 10mm and send G30 S-1 and i consistently get an av figure of 1.8mm. Now i changed my congig.g code which was G31 X0 Y0 Z0 P25 to G31 X0 Y0 Z1.8 P25 and it still home 14mm high ? am i doing something wrong obviously?
                                          1.8mm trigger height sounds reasonable. 14mm high? Where is that coming from? How are you measuring that? After homing if you jog to z0 the nozzle should be touching the bed.
                                          JTMundefined 2 Replies Last reply Reply Quote 0
                                          • JTMundefined
                                            JTM @Phaedrux
                                            @Phaedrux i have a E3d super volcano on this machine so i measure from the bottom of the block with a ruler to the bed and it homes 14mm high every time. i can move the nozzle to the bed via the controls sure, but i thought it would home to the required printing height each time if set correctly?
