    Temprature sensor error unknown temperature sensor channel
    Firmware installation
    4.9k
      Phaedrux Moderator @JTM
      @JTM said in Temprature sensor error unknown temperature sensor channel:
      M558 M558 P9 H5 F100 T2000 ; set Z probe type to bltouch and the dive height + speeds
      Does that line in your config.g actually have double M558 at the start?
      Can you post your full config.g?
      JTMundefined 1 Reply Last reply Reply Quote 0
      • JTMundefined
        JTM @Phaedrux
        @Phaedrux copy and pasted full config.g file :
        M550 P"My Printer" ; set printer name
        M552 S1 ; enable network
        M586 P0 S1 ; enable HTTP
        M586 P1 S0 ; disable FTP
        M586 P2 S0 ; disable Telnet
        M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
        M906 X1200 Y1200 Z1500 E1200 I30 ; set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M208 X500 Y450 Z500 S0 ; set axis maxima
        M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
        G31 X0 Y0 Z0 P25 ; set Z probe trigger value, offset and trigger height
        M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
        M307 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
        M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs1
        M950 H1 C"e0_heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1
        ;Miscellaneous
        M575 P1 S1 857600
        Phaedruxundefined droftartsundefined 4 Replies Last reply Reply Quote 0
          You've got M558 in there twice. Take one of them out.
            M575 P1 S1 857600
            That should be B57600 not 8
              droftarts administrators @JTM
              This post is deleted!
              • JTMundefined
                JTM @Phaedrux
                @Phaedrux Thanks for the help mate, did as you suggested and went to home all axis and got
                G28 X
                Operation has been cancelled
                  I suggest going through this guide to ensure endstops are working and motors are moving are going the right direction.
                  https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
                  • JTMundefined
                    JTM @Phaedrux
                    @Phaedrux Thanks for all your help Mate, still going through the checks, the motors and end stops seem to all be wired correctly and moving the right way, i keep getting this message when homing z
                    G28 Z
                    Error: in file macro line 9: G30: Z probe 0 not found
                    Error: Homing failed
                    i will keep looking 🙂 the M280 deploy and retract macros work but homing doesnt activate the probe so im guessing the Gcode for homing is missing something?
                      A Former User
                      please post your revised config so we can see your current M558 line that configures your z probe
                      • JTMundefined
                        JTM @A Former User
                        @bearerthis is the config.g file
                        ;Miscellaneous
                        M575 P1 S1 B57600
                        M501
                          A Former User
                          i think you might need C"^zprobe.in" added to the line with M558?
                          M558 P9 C"^zprobe.in" H5 F100 T2000 ; set Z probe type to bltouch and the dive height + speeds
                          edit: presuming thats where your zprobe is connected?
                          JTMundefined 1 Reply Last reply Reply Quote 1
                          • JTMundefined
                            JTM @A Former User
                            @bearer said in Temprature sensor error unknown temperature sensor channel:
                            C"^zprobe.in"
                            Genius ! thanks mate did the trick now homes all axis ! temp sensor works, extruder works all i need now is to calibrate i think 🙂 woohoo !! thanks so much to everyone for your help !
                              Can't believe I didn't catch that!
                              • JTMundefined
                                JTM @Phaedrux
                                @Phaedrux you guys are awesome ! appreciate the help as i'm as green as it gets almost ! lol
                                Ive calibrated my steps so now all axis move the perfect distance, extruder extrudes exactly 100mm when i tell it too, only issue i have is homing Z. I have used the test and calibrate procedure in this link https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                                i have done the calibration several times i manually move the bed up to be catching a width of paper, send M92 Z0 comand to set sero. i then drop the bed down 10mm and send G30 S-1 and i consistently get an av figure of 1.8mm. Now i changed my congig.g code which was G31 X0 Y0 Z0 P25 to G31 X0 Y0 Z1.8 P25 and it still home 14mm high ? am i doing something wrong obviously?
                                  1.8mm trigger height sounds reasonable. 14mm high? Where is that coming from? How are you measuring that? After homing if you jog to z0 the nozzle should be touching the bed.
                                  JTMundefined 2 Replies Last reply Reply Quote 0
                                  • JTMundefined
                                    JTM @Phaedrux
                                    @Phaedrux i have a E3d super volcano on this machine so i measure from the bottom of the block with a ruler to the bed and it homes 14mm high every time. i can move the nozzle to the bed via the controls sure, but i thought it would home to the required printing height each time if set correctly?
                                    • JTMundefined
                                      JTM @Phaedrux
                                      @Phaedrux when i home Z it raises the bed hits the Zprobe then the bed drops 10mm or so?
                                        @JTM what height does DWC report Z is at after homing Z? If 0, but nozzle is off bed, post your homeall.g and homez.g
                                        • JTMundefined
                                          JTM @droftarts
                                          @droftarts its says 0 on the console
                                          homeall :
                                          generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 16 2020 07:34:10 GMT+1000 (Australian Eastern Standard Time)
                                          G91 ; relative positioning
                                          G1 H1 X-505 Y-455 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
                                          G1 H2 X5 Y5 F6000 ; go back a few mm
                                          G1 H1 X-505 Y-455 F600 ; move slowly to X and Y axis endstops once more (second pass)
                                          G90 ; absolute positioning
                                          G1 X15 Y15 F6000 ; go to first bed probe point and home Z
                                          ;G91 ; relative positioning
                                          ;G90 ; absolute positioning
                                          Home z:
                                          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 16 2020 07:34:11 GMT+1000 (Australian Eastern Standard Time)
                                          G1 X15 Y15 F6000 ; go to first probe point
                                            The print height gets set by the slicer.
                                            The important thing is that after homing you can do a G90 G1 Z0 move and the nozzle touches the bed. If that works, then when you start the print it will go to the right height.
                                            Maybe show a photo of what you mean with the 14mm if you still think something is wrong.
