    Random Smart Effector flashes
    1.9k
    • sankafolaundefined
      sankafola @A Former User
      @bearer that is exact what i messuered i wish you put that first lool but i found it with my cheap microscope 🙂
        A Former User @sankafola
        @sankafola said in Random Smart Effector flashes:
        shouldn't listen to random strangers on the internet; btw I've got candy!
        (sorry, I just randombly stumped onto the post where it was assumed damaged, and worked back to look at a way to verify as repairs seemed unlikely)
          sankafola
          @T3P3Tony so what do you think it is ?
            Does it make any difference (to the random flashes) whether the motors are energised or not?
            Does it make any difference whether the heated bed is on or off, or how close to the bed the effector is?
            If you remove the effector from the printer, apply 3.3V or 5V to the Vcc and ground connections of the white 8-pin connector with nothing else connected, does the green LED still flash randomly when the effector is still?
              sankafola
              @dc42 i tried that and no flashing , i just did now auto delta calibration and went fine
              G32
              Calibrated 8 factors using 16 points, (mean, deviation) before (-0.174, 0.045) after (-0.000, 0.021)
              Auto calibration successful, deviation 0.021mm
              then did mesh level and it stopped saying
              G29
              Error: Z probe already triggered before probing move started
              then i just reboot the printer then i did G32
              G32
              Calibrated 8 factors using 16 points, (mean, deviation) before (-0.212, 0.042) after (0.000, 0.019)
              Auto calibration successful, deviation 0.019mm
              and then mesh 170/30
              G29
              101 points probed, min error -0.571, max error 0.685, mean 0.033, deviation 0.242
              Height map saved to file heightmap.csv
              so it does it every 2nd time i ask for mesh g29
              its random
                dc42 administrators @sankafola
                I presume you mean that when the effector is connected to 5V or 3.3V only, the random flashing ceases. That suggests that the problem is either mechanical interference (i.e. vibration - which is why I asked if turning the motors off made a difference) or electrical interference (most likely from stray magnetic fields - hence my question about the bed heater).
                Do you have an extruder mounted on the effector, or is it a bowden system?
                  sankafola
                  @dc42 its flaying extruder with 20 cm tube , the thing is if its the bed electromagnet it should affect it all the time not just random , here is my setup 53014114-37A0-4C43-A876-13321CB3C327_1_105_c.jpeg
                    Does the random flashing stop when you raise the effector well above the bed?
                    sankafolaundefined 2 Replies Last reply Reply Quote 0
                      sankafola
                      @dc42 no the random can happen also while its home which is very far from the bed
                        A Former User
                        the light shown is that led's on/near the effector? does it help to turn lights off?
                          sankafola
                          these lights of the smart effector why turn off? you think its related to the random flash ?
                            was just thinking if they were external leds and you're looking for a source of noise, it'd be worth looking into.
                              sankafola
                              its built in LED in the smart effector and i dont think its related because they are on while its working normal too its built that way
                                sankafola @dc42
                                @dc42 just to be sure the LED which flash random is the same LED which flashes 2 times when it turn on the printer
                                  sankafola @dc42
                                  @dc42 what do you think ? do you think the smart effector the card itself have something wrong ?
                                    We will authorize a warranty replacement on the Smart Effector. It's possible there is an issue with it causing it to be too sensitive. Please contact your vendor and initiate a warranty exchange. Include a link to this thread as authorization.
                                      sankafola
                                      @Phaedrux thank you will do
