Random Smart Effector flashes
1.8k
    sankafola
    @dc42 i tried that and no flashing , i just did now auto delta calibration and went fine
    G32
    Calibrated 8 factors using 16 points, (mean, deviation) before (-0.174, 0.045) after (-0.000, 0.021)
    Auto calibration successful, deviation 0.021mm
    then did mesh level and it stopped saying
    G29
    Error: Z probe already triggered before probing move started
    then i just reboot the printer then i did G32
    G32
    Calibrated 8 factors using 16 points, (mean, deviation) before (-0.212, 0.042) after (0.000, 0.019)
    Auto calibration successful, deviation 0.019mm
    and then mesh 170/30
    G29
    101 points probed, min error -0.571, max error 0.685, mean 0.033, deviation 0.242
    Height map saved to file heightmap.csv
    so it does it every 2nd time i ask for mesh g29
    its random
    undefined 1 Reply Last reply 16 Sept 2020, 20:23 Reply Quote 0
      dc42 administrators @sankafola
      @sankafola said in Random Smart Effector flashes:
      I presume you mean that when the effector is connected to 5V or 3.3V only, the random flashing ceases. That suggests that the problem is either mechanical interference (i.e. vibration - which is why I asked if turning the motors off made a difference) or electrical interference (most likely from stray magnetic fields - hence my question about the bed heater).
      Do you have an extruder mounted on the effector, or is it a bowden system?
        sankafola
        @dc42 its flaying extruder with 20 cm tube , the thing is if its the bed electromagnet it should affect it all the time not just random , here is my setup 53014114-37A0-4C43-A876-13321CB3C327_1_105_c.jpeg
          Does the random flashing stop when you raise the effector well above the bed?
          undefined 2 Replies Last reply 17 Sept 2020, 13:34 Reply Quote 0
            sankafola
            @dc42 no the random can happen also while its home which is very far from the bed
              A Former User
              the light shown is that led's on/near the effector? does it help to turn lights off?
                sankafola
                these lights of the smart effector why turn off? you think its related to the random flash ?
                ? 1 Reply Last reply 17 Sept 2020, 12:20 Reply Quote 0
                  A Former User @sankafola
                  was just thinking if they were external leds and you're looking for a source of noise, it'd be worth looking into.
                    sankafola
                    its built in LED in the smart effector and i dont think its related because they are on while its working normal too its built that way
                      sankafola @dc42
                      @dc42 just to be sure the LED which flash random is the same LED which flashes 2 times when it turn on the printer
                        sankafola @dc42
                        @dc42 what do you think ? do you think the smart effector the card itself have something wrong ?
                          We will authorize a warranty replacement on the Smart Effector. It's possible there is an issue with it causing it to be too sensitive. Please contact your vendor and initiate a warranty exchange. Include a link to this thread as authorization.
                            sankafola
                            @Phaedrux thank you will do
                            40 out of 43
